Home » Archived » M2M (model-to-model transformation) » Model format
| Model format [message #13085] |
Mon, 29 January 2007 05:25  |
Is it correct to say, that models in ATL are handled and stored in Ecore
format (which is based on XML)?
Metamodels are, but I ain't sure about models
| Re: Model format [message #13401 is a reply to message #13381] |
Tue, 30 January 2007 11:20   |
Hugo,
I don't really like the term "Ecore" format since that term would seem
to narrowly apply just to serializations of Ecore instances and likely
results in confusion (such as the EMF newsgroup thread where someone
suggested renaming My.library, a serialization of a Library model
instance, to Library.ecore, which should be a serialization of an Ecore
instance, not a serializaton of an instance of the Library Ecore
model). Ecore instances can also be serialized as EMOF using
EMOFResourceFactoryImpl and can conversely be deserialized directly from
an EMOF serialization. EMF generally uses XMI format for serialization
of models in general, although options like
OPTION_USE_ENCODED_ATTRIBUTE_STYLE result in a more concise
serialization that's not fully XMI conforming. Perhaps "EMF" format
would be less confusing...
Hugo Bruneliere wrote:
> Hi Gediminas
>> Ecore format (which is based on XML)?
> ATL has been designed for being potentially used with different
> model-handlers. Currently, two main drivers are provided: Ecore and MDR.
> The default (and most used) model-handler with ATL is of course Ecore,
> since ATL is an Eclipse/M2M component. So you can say that, in ATL,
> models (as well as metamodels) are stored in Ecore format which is a
> XMI format (and is thus expressed in XML).
> Best regards,
> Hugo
| Re: Model format [message #13415 is a reply to message #13401] |
Tue, 30 January 2007 11:53   |
Originally posted by: Hugo.Bruneliere.univ-nantes.fr
Ed,
Ed Merks a écrit :
> Hugo,
I fully agree with the fact that it is an abuse of language to reduce
Ecore to a "serialization format".
To summarize, can we say that EMF is a model-handler that provides
facilities including serialization ones (related to XMI formats for
example but not necessarily) and that Ecore is its metametamodel
(provided with the corresponding API)?
>> Hi Gediminas
>> Best regards,
>> Hugo
Hugo
Hugo Bruneliere - R&D Engineer
ATLAS Group (INRIA & LINA) - University of Nantes
2, rue de la Houssiniere
44322 Nantes Cedex 3 - France
office +33 2 51 12 58 10 /\ cell.+33 6 07 42 45 30
EMail: Hugo.Bruneliere@univ-nantes.fr
http://www.sciences.univ-nantes.fr/lina/atl/
| Re: Model format [message #14019 is a reply to message #13415] |
Tue, 30 January 2007 12:04  |
Hugo,
Comments below.
> Ed,
> Ed Merks a écrit :
>> Hugo,
>> seem to narrowly apply just to serializations of Ecore instances and
>> likely results in confusion (such as the EMF newsgroup thread where
>> someone suggested renaming My.library, a serialization of a Library
>> model instance, to Library.ecore, which should be a serialization of
>> an Ecore instance, not a serializaton of an instance of the Library
>> Ecore model). Ecore instances can also be serialized as EMOF using
>> from an EMOF serialization. EMF generally uses XMI format for
>> serialization of models in general, although options like
Yes, that sounds very precise. :-)
>>> Hi Gediminas
>>> MDR.
>>> Ecore, since ATL is an Eclipse/M2M component. So you can say that,
>>> in ATL, models (as well as metamodels) are stored in Ecore format
>>> which is a XMI format (and is thus expressed in XML).
>>> Best regards,
>>> Hugo
> Best regards,
> Hugo
Current Time: Sat Oct 25 03:33:26 EDT 2025
Powered by FUDForum. Page generated in 0.07297 seconds
