Home » Language IDEs » Java Development Tools (JDT) » content assistant bypasses StyledText widget
content assistant bypasses StyledText widget [message #142204] Mon, 16 February 2004 07:00 Go to next message
I posted this on the swt group with no response, but maybe it is more
appropriate here...
3.0M5
Can anyone speak to the Eclipse philosophy on VerifyListeners?
I have a StyledText widget that I have called addVerifyListener() on. I use
this listener to enforce readonly behavior on certain portions of the text.
However, the CompletionProposalPopup calls AbstractDocument.replace(int pos,
int length, String text) directly on the document instead of calling
StyledText.replaceTextRange(int start, int length, String text). This
bypasses the VerifyListener notification and modifies the text directly.
Therefore, I have no hook to prevent edits selectively. It seems like
applying
a proposal is a UI event like Paste or keystrokes (for which I receive
verify events), but it is not
treated the same way.
My ideal situation would be that I could bring up the content assistant and
see what it suggests, but selecting one of the options would be subject to
the verify listener.
Is this the way completion proposals "should" work? Has anyone found a good
way around this?
Re: content assistant bypasses StyledText widget [message #142238 is a reply to message #142204] Mon, 16 February 2004 08:36 Go to previous messageGo to next message
> applying
StyledText is just a controller for the underlying model, in this case
an instance of IDocument. Not all document modifications are performed
through the StyledText. Examples are code completion, but also
refactoring and really any of the advanced editing capabilities not
directly supported by StyledText. The distinction between UI and non-UI
events is not so clear e.g. with refactoring.
IDocument informs its registered IDocumentListeners about changes to its
model - however, it does not support validation / vetoing of a change.
Validation of read/write is done by the editor framework on a
per-document basis (see AbstractTextEditor.validateEdit), but not for
specific text regions.
-> You will probably have to implement your own Document that provides
the read-only regions.
-tom
Re: content assistant bypasses StyledText widget [message #142313 is a reply to message #142238] Mon, 16 February 2004 10:10 Go to previous messageGo to next message
Tom,
Thank you very much for the response. I will work at it from the Document
subclass angle.
Ernest
"Tom Eicher" <eclipse@tom.eicher.name> wrote in message
news:c0qgqr$e3r$1@eclipse.org...
use
text.
pos,
> > applying
> -tom
Re: content assistant bypasses StyledText widget [message #142391 is a reply to message #142238] Mon, 16 February 2004 14:21 Go to previous messageGo to next message
OK, I'm stumped. Is there a way to hook in to create my own Document
subclass instead of a PartiallySynchronizedDocument instance? Without
having to replace the .java file association or copy a lot of code from
TextFileDocumentProvider and TextFileBufferManager.
use
text.
pos,
> > applying
> -tom
Re: content assistant bypasses StyledText widget [message #142496 is a reply to message #142391] Tue, 17 February 2004 03:09 Go to previous messageGo to next message
What you want to do (an form-like editor with non-editable areas) sounds
not like something you can accomplish inside the standard editors -
you'll probably need your own editor type where you can either enforce
the write-protected areas in your document or in your viewer.
-tom
Re: content assistant bypasses StyledText widget [message #142594 is a reply to message #142496] Tue, 17 February 2004 08:43 Go to previous message
Well, I am attempting to create a java editor that's exactly like the normal
java editor (including being hooked into all the normal tools that the java
editor is hooked into) except that the parts where I generate code are
readonly. So the best situation for me is to subclass the existing document
and view so that I don't lose all the normal behavior. I've already
subclassed the view, so it sounds like I'll need to see if I can come up
with an acceptable solution without subclassing the document.
Thanks for your response.
Ernest
news:c0si1p$nl6$2@eclipse.org...
> -tom
Previous Topic:command line
Next Topic:Force source file to compile
Current Time: Mon Jul 21 23:54:18 EDT 2025
Powered by FUDForum. Page generated in 0.26740 seconds
