Home » Eclipse Projects » DSDP - Target Management » RSEG1066U (RSE 2.0.0.1)
RSEG1066U (RSE 2.0.0.1) [message #13079] Tue, 24 July 2007 09:09 Go to next message
Hello all,
Any idea in witch case this error is throw? This happen when I try to
connect to a Linux server using Dstore, this exception is throw with and
without a Dstore daemon started, so it's not a server side problem.
That have already worked here but I think that I don't have try it with
the last update.
Alphonse
The stack trace:
org.eclipse.rse.connectorservice.dstore.DStoreConnectorServi ce.internalConnect(DStoreConnectorService.java:761)
org.eclipse.rse.core.subsystems.AbstractConnectorService.con nect(AbstractConnectorService.java:412)
org.eclipse.rse.ui.operations.SystemFetchOperation.execute(S ystemFetchOperation.java:243)
org.eclipse.rse.ui.operations.SystemFetchOperation.run(Syste mFetchOperation.java:128)
org.eclipse.rse.ui.view.AbstractSystemViewAdapter.fetchDefer redChildren(AbstractSystemViewAdapter.java:1970)
org.eclipse.ui.progress.DeferredTreeContentManager$1.run(Def erredTreeContentManager.java:196)
Re: RSEG1066U (RSE 2.0.0.1) [message #13138 is a reply to message #13079] Tue, 24 July 2007 10:52 Go to previous message
Hello Alphonse,
The DStoreConnectorService has not been changed since 2.0 so getting a
later update is unlikely to help.
The backtrace seems to indicate that RSE is trying to run a
ServerLauncher of an unknown type. This might happen if your profile was
incorrectly read from disk.
Does this happen reproducably or intermittently? - If reproducably, it
could help getting your profile -- zip up the contents of
${workspace}\.metadata\.plugins\org.eclipse.rse.core\profile s
Other than that, I think the only possibility for understanding what
happens here is debugging the issue. Just set a breakpoint in
DStoreConnectorService line 761 -- the code should never go there. If it
does go there, investigate the variables. Another breakpoint could be in
DStoreConnectorService line 356.
At any rate, please file a bug since this issue is certainly not known
yet, and attach any information you can get.
Martin Oberhuber
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
Alphonse Van Assche wrote:
> Hello all,
> the last update.
> Alphonse
> The stack trace:
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
Re: RSEG1066U (RSE 2.0.0.1) [message #569215 is a reply to message #13079] Tue, 24 July 2007 10:52 Go to previous message
Hello Alphonse,
Martin Oberhuber
> Hello all,
> the last update.
> Alphonse
> The stack trace:
> at
> at
> at
> at
> at
> at
Previous Topic:Ftp access rights
Next Topic:Ftp access rights
Current Time: Thu Sep 04 18:44:38 EDT 2025
Powered by FUDForum. Page generated in 0.03702 seconds
