Re: Convert to Field Refactoring Gone in M7? [message #142321 is a reply to message #142194] |
Mon, 16 February 2004 10:36  |
Originally posted by: robwms63.yahoo.com
Something weird happened. In the file I was in it was not showing
imports inside quickfix either. When I closed Eclipse and reopened it, I
went back and both things were working.
Rob
Markus Keller wrote:
> Rob Williams wrote:
>> The last choice on the menu was to convert a local variable to a class
>> field. Now, the last choice is 'Introduce Parameter'...??
> Are you talking about the workbench main menu or the context menu?
> The 'Refactor' submenu in the java editor's context menu is now context
> sensitive, i.e. it only shows refactorings applicable to the current
> selection / position.
> If you have a test case where your text curor is really on a local
> variable and the refactoring doesn't appear, please file a bug report
> against JDT/UI and include your test case.
> Markus
FUDForum. Page generated in 0.28076 seconds
