Home » Eclipse Projects » Eclipse Platform » M3: PDE: NoClassDefFoundError: org/eclipse/swt/widgets/Dialog
M3: PDE: NoClassDefFoundError: org/eclipse/swt/widgets/Dialog [message #142007] Fri, 10 October 2003 04:17 Go to next message
Originally posted by: tcn.spamgourmet.com
Hi!
I completely new to plugin development.
So, I switched to the PDE perspective and created a TeetPlugin with a
SampleView using the Wizard. When I try to run it as Run-time Workbench
that exception is thrown:
java.lang.NoClassDefFoundError: org/eclipse/swt/widgets/Dialog
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:16 10)
at java.lang.Class.getConstructor0(Class.java:1922)
at java.lang.Class.newInstance0(Class.java:278)
at java.lang.Class.newInstance(Class.java:261)
org.eclipse.core.internal.plugins.PluginDescriptor.createExe cutableExtension(PluginDescriptor.java:138)
org.eclipse.core.internal.plugins.PluginDescriptor.createExe cutableExtension(PluginDescriptor.java:167)
org.eclipse.core.internal.plugins.ConfigurationElement.creat eExecutableExtension(ConfigurationElement.java:103)
org.eclipse.core.internal.runtime.InternalPlatform.loaderGet Runnable(InternalPlatform.java:584)
org.eclipse.core.internal.runtime.InternalPlatform.checkVers ionPrompt(InternalPlatform.java:508)
org.eclipse.core.internal.runtime.InternalPlatform.loaderChe ckVersion(InternalPlatform.java:484)
org.eclipse.core.internal.boot.InternalBootLoader.checkVersi on(InternalBootLoader.java:873)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:842)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
at org.eclipse.core.launcher.Main.basicRun(Main.java:295)
at org.eclipse.core.launcher.Main.run(Main.java:751)
at org.eclipse.core.launcher.Main.main(Main.java:587)
Well, eclipse uses SWT so why are those classes not distributed with M3???
Or what is going wrong here?
Re: M3: PDE: NoClassDefFoundError: org/eclipse/swt/widgets/Dialog [message #142157 is a reply to message #142007] Fri, 10 October 2003 05:36 Go to previous message
Timo Nentwig wrote:
> Hi!
and: org.eclipse.swt.gtk_3.0.0/ws/gtk/swt.jar was added to class path by the
wizard.
Previous Topic:How to indent Button controls?
Next Topic:New Wizard for a java project
Current Time: Fri Jul 18 00:29:21 EDT 2025
Powered by FUDForum. Page generated in 0.08496 seconds
