Home » Eclipse Projects » GEF » Null action registry from copied gef flow example
| Null action registry from copied gef flow example [message #141593] |
Tue, 06 July 2004 00:38  |
Originally posted by: RichardSpackmann.mafd.org
I am trying to set up a context menu for when I right click on an editpart
and am following the source code given in the flow example.
The problem is that I am getting a NullPointerException at the following
line:
menu.appendToGroup(GEFActionConstants.GROUP_UNDO, action);
of the FlowContextMenuProvider class.
In debugging the plugin, the action registry is empty. Thus, "action" is
null (which is also confirmed in debug mode).
I copied over all the relevant (at least what I thought was relevant) - but
it doesn't work.
From what I understand from the GraphicalEditor JavaDocs, the method
"getActionRegistry" should create the action registry - and I would assume
that all the "standard" actions (all the GEFActionConstants) would be part
of it.
Does anyone know what could be the culprit?
Spack
| Re: Null action registry from copied gef flow example [message #141787 is a reply to message #141770] |
Tue, 06 July 2004 14:29   |
Originally posted by: webmaster.mafd.org
I'm obviously missing something - but at this point, I do not know what. I
believe that I copied over the necessary code which consists of the
FlowContextMenuProvider class and the configureGraphicalViewer protected
method in the editor class (which instantiates the FlowContentMenuProvider
class) - I attached the code below. Since the flow example really doesn't do
anything special in terms of actions for the context menu - this should be
all that I need to do right?
public class MyEditor extends GraphicalEditorWithPalette {
private KeyHandler sharedKeyHandler;
private PaletteRoot _paletteRoot = null;
public MyEditor() {
setEditDomain(new DefaultEditDomain(this));
public void init(IEditorSite iSite, IEditorInput iInput) throws
PartInitException {
setSite(iSite);
setInput(iInput);
protected void createActions() {
super.createActions();
ActionRegistry registry = getActionRegistry();
IAction action;
action = new DirectEditAction((IWorkbenchPart)this);
registry.registerAction(action);
getSelectionActions().add(action.getId());
protected KeyHandler getCommonKeyHandler() {
if (sharedKeyHandler == null) {
sharedKeyHandler = new KeyHandler();
sharedKeyHandler.put(
KeyStroke.getPressed(SWT.DEL, 127, 0),
getActionRegistry().getAction(GEFActionConstants.DELETE));
KeyStroke.getPressed(SWT.F2, 0),
getActionRegistry().getAction(GEFActionConstants.DIRECT_EDIT ));
return sharedKeyHandler;
protected void initializeGraphicalViewer() {
getGraphicalViewer().setContents(new PlanDrawingModel());
protected void configureGraphicalViewer() {
super.configureGraphicalViewer();
getGraphicalViewer().setRootEditPart(new FreeformGraphicalRootEditPart());
getGraphicalViewer().setEditPartFactory(new GraphicalPartFactory());
getGraphicalViewer().setKeyHandler(new
GraphicalViewerKeyHandler(getGraphicalViewer())
.setParent(getCommonKeyHandler()));
((FigureCanvas)getGraphicalViewer().getControl()).setScrollB arVisibility(Fig
ureCanvas.ALWAYS);
ContextMenuProvider provider =
new FlowContextMenuProvider(getGraphicalViewer(), getActionRegistry());
getGraphicalViewer().setContextMenu(provider);
getSite().registerContextMenu(
"org.eclipse.gef.examples.flow.editor.contextmenu", //$NON-NLS-1$
provider,
getGraphicalViewer());
public void setActiveTool(Tool tool) {
getEditDomain().setActiveTool(tool);
protected PaletteRoot getPaletteRoot() {
if (_paletteRoot == null)
_paletteRoot = MerceePlanEditorPaletteFactory.createPalette();
return _paletteRoot;
//same except for extra println stmts in buildContextMenu
public class FlowContextMenuProvider extends ContextMenuProvider {
private ActionRegistry actionRegistry;
public FlowContextMenuProvider(EditPartViewer viewer, ActionRegistry
registry) {
super(viewer);
setActionRegistry(registry);
public void buildContextMenu(IMenuManager menu) {
if (menu == null) System.out.println("MENU IS @#$%& NULL!");
GEFActionConstants.addStandardActionGroups(menu);
IAction action;
action = getActionRegistry().getAction(GEFActionConstants.UNDO);
if (action == null) System.out.println("ACTION IS @#$%& NULL!");
action = getActionRegistry().getAction(GEFActionConstants.REDO);
action = getActionRegistry().getAction(IWorkbenchActionConstants.DELE TE);
if (action.isEnabled())
menu.appendToGroup(GEFActionConstants.GROUP_EDIT, action);
"Pratik Shah" <ppshah@us.ibm.com> wrote in message
news:cceovr$10a$1@eclipse.org...
> When are you doing this? The only thing I can think of that would cause
> this is trying to access the action before the editor's site is set, i.e.
> before the editor's init(IEditorSite, IEditorInput) method has been
invoked.
> The actions are added to the action registry in
initializeActionRegistry(),
> which is invoked when the above-mentioned method is executed.
> "Richard Spackmann" <RichardSpackmann@mafd.org> wrote in message
> news:ccdaa1$b5v$1@eclipse.org...
editpart
> > line:
> but
> > it doesn't work.
assume
part
> > of it.
> > Spack
| Re: Null action registry from copied gef flow example [message #141805 is a reply to message #141787] |
Tue, 06 July 2004 18:42   |
You are over-riding GraphicalEditor's init(IEditorSite, IEditorInput)
method, which invokes initailizeActionRegistry().
"Richard Spackmann" <webmaster@mafd.org> wrote in message
news:ccer01$4om$1@eclipse.org...
do
> public MyEditor() {
> PartInitException {
> setSite(iSite);
> setInput(iInput);
> IAction action;
> ureCanvas.ALWAYS);
> provider,
> registry) {
> super(viewer);
> IAction action;
i.e.
> invoked.
> editpart
following
> > > line:
action);
is
relevant) -
> > but
> > > it doesn't work.
> assume
> part
> > > of it.
> > > Spack
| Re: Null action registry from copied gef flow example [message #142042 is a reply to message #141805] |
Wed, 07 July 2004 10:41  |
Yup - that definately solved it - thanks again!
news:ccf9qr$rbv$1@eclipse.org...
I
doesn't
> do
be
> > public MyEditor() {
> > PartInitException {
> > setSite(iSite);
> > setInput(iInput);
> > IAction action;
> > ureCanvas.ALWAYS);
> > provider,
> > registry) {
> > super(viewer);
> > IAction action;
> > action =
cause
> i.e.
> > invoked.
> > editpart
> following
> > > > line:
> action);
"action"
> is
> relevant) -
> > > but
> > > > it doesn't work.
> > assume
be
> > part
> > > > of it.
> > > > Spack
Current Time: Sat Nov 08 06:01:15 EST 2025
Powered by FUDForum. Page generated in 0.03814 seconds
