| Using TM in an OSGi solution [message #12993] |
Mon, 23 July 2007 06:17  |
Originally posted by: martin.tomcat.org
We are developing a OSGi solution (Equinox based) and therefore I'm a bit
curious if the core TM can be operational
without Eclipse RCP / Platform ?
BR
M
| Re: Using TM in an OSGi solution [message #13022 is a reply to message #12993] |
Mon, 23 July 2007 09:08   |
there are some TM components that have minimal requirements:
* The Terminal only requires RCP and can easily be stripped down
to eRCP (basically, it needs SWT only)
* Discovery only requires EMF-core, eclipse.core.runtime and
org.eclipse.ui
* The RSE Services Layer (i.e. the plugins org.eclipse.rse.service.*)
only requires org.eclipse.core.runtime (except for dstore, which
also requires org.eclipse.ui)
Apart from these, unfortunately the current TM 2.0 still has too many
dependencies on Eclipse Platform / UI. We are working on more
componentization for TM 3.0 next year, see
http://wiki.eclipse.org/index.php/TM_Future_Planning
HTH,
Martin Oberhuber
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
Martin wrote:
> BR
> M
| Re: Using TM in an OSGi solution [message #13051 is a reply to message #13022] |
Mon, 23 July 2007 17:16  |
Thanks for info
BR
M
"Martin Oberhuber" <martin.oberhuber@windriver.com> skrev i meddelandet
news:46A4A859.2050209@windriver.com...
> Hello,
> org.eclipse.ui
> HTH,
> Martin Oberhuber
> Martin wrote:
>> BR
>> M
| Re: Using TM in an OSGi solution [message #569081 is a reply to message #12993] |
org.eclipse.ui
HTH,
Martin Oberhuber
Martin wrote:
> BR
> M
| Re: Using TM in an OSGi solution [message #569115 is a reply to message #13022] |
Thanks for info
BR
M
> Hello,
> org.eclipse.ui
> HTH,
> Martin Oberhuber
> Martin wrote:
>> BR
>> M
FUDForum. Page generated in 0.18350 seconds
