Re: why is the GMF diagram in the New/Example section [message #141960 is a reply to message #141948] |
Tue, 10 July 2007 11:19   |
Hi Jens,
I see. Perspective customization is only available in the RCP mode. For
the non-RCP version, it can be done either with custom templates or
manually (in the latter case, do not forget to omit the <?gmfgen
generated="true"?> processing instruction or specify <?gmfgen
generated="false"?> so that it is preserved by subsequent regenerations).
Boris
Jens Krause wrote:
> Boris Blajer wrote:
>>> I read something about an custom plugin, but i can't figure out how i
>>> could combine the gmf diagram plugin with the custom plugin so that
>>> it works for getting custom perspective and category for the
>>> NewWizard and so on.
>> Not sure I understand what you are talking about. Custom perspective,
>> wizard category and other associated options should be specified in
>> the gmfgen model, not by custom plugin.
> Thats my problem, i can't find "custom perspective" in the gmfgen file
> :). The category should be simple, but we want a custom perspective too.
> jens
Re: why is the GMF diagram in the New/Example section [message #141968 is a reply to message #141960] |
Tue, 10 July 2007 12:18  |
Well, and that is only available in GMF 2.0 :-(. As many feature i'd
like to have. But i once tried to migrate to 2.0 and i didn't work out.
jens
FUDForum. Page generated in 0.04272 seconds
