Home » Eclipse Projects » GEF » problem with Reconnecting a connection
problem with Reconnecting a connection [message #12961] Wed, 10 July 2002 10:44 Go to next message
i have a editparts on my canvas which are nodes in a graph, an i would
like my users to be able to drag a connection that was created between two
nodes to other node. i tried to do it the same way as in the logic
example, but i coulnd't underastand there something. after a change in the
source of a logic element, a property change is fired with the type
"source", i couln't find anybody that listens to this type, but somehow it
works. i tried to do it the same way, but in my app it doesn't, the
connection returns to it's original source after the mouse is released.
any ideas
thanks
yoav
Re: problem with Reconnecting a connection [message #12991 is a reply to message #12961] Tue, 09 July 2002 23:39 Go to previous messageGo to next message
Originally posted by: none.ibm.com
The LogicSubpart (which is a Node for a connection) fires INPUTS or OUTPUTS
changed. The LogicEditPart listens for these changes, and refreshes
source/target connections.
"Yoav Rubin" <yoav@il.ibm.com> wrote in message
news:aghh8b$875$1@rogue.oti.com...
> Hi
> any ideas
> thanks
> yoav
Re: problem with Reconnecting a connection [message #13020 is a reply to message #12991] Wed, 10 July 2002 12:33 Go to previous messageGo to next message
after verifying stuff in my code, i found out that the command that is
returned from getReconnectSourceCommand in the editpolicy, and from some
reason (which i couldn't find) does not get executed. any ideas?
(the canExecute method returns true)
thanks
yoav
> > Hi
> > any ideas
> > thanks
> > yoav
Re: problem with Reconnecting a connection [message #13047 is a reply to message #13020] Wed, 10 July 2002 01:54 Go to previous messageGo to next message
Put a breakpoint in ConnectionEndpointTracker.handleButtonUp() and debug it.
Is this command compounded with any other commands perhaps?
news:aghnk7$c4k$1@rogue.oti.com...
> Hi
> thanks
> yoav
OUTPUTS
> > > Hi
two
the
somehow it
released.
> > > any ideas
> > > thanks
> > > yoav
Re: problem with Reconnecting a connection [message #13073 is a reply to message #13047] Thu, 11 July 2002 06:38 Go to previous message
this command is not compounded with other commands.
> > Hi
> > thanks
> > yoav
> OUTPUTS
> > > > Hi
> two
> the
> somehow it
> released.
> > > > any ideas
> > > > thanks
> > > > yoav
Previous Topic:GEF and MultipageEditorPart
Next Topic:Toolbar EditPartAction disabled
Current Time: Sun Aug 31 23:41:22 EDT 2025
Powered by FUDForum. Page generated in 0.03716 seconds
