Home » Archived » BIRT » help: datetime feilds are always truncating the time to 00:00
help: datetime feilds are always truncating the time to 00:00 [message #140432] Tue, 07 March 2006 05:36 Go to next message
If I do something like this:
select sysdate as mydate from dual
in toad, it returns:
07/03/2006 11:23:05
If I then take this row and drop it into a report item (row["mydate"], it
shows
7-Mar-2006 00:00
In the data set, Im seting the type to
If I use the Property Editor to edit the data, and change the "format
dateTime" to say "07 March 2006 11:26:11 CET", then preview the report, it
shows:
07 March 2006 00:00 CET.
Im having the same problem going the other way, if my sql is something like:
select
created
from
myrecord
where
created between ? and ?
then pass in a 2 parameters which are formattted (using the custom format
string) to something like 07/03/06 01:01:01 and 07/03/06 23:59:59 I get no
rows back, but If I change it to 07/03/06 01:01:01 and 08/03/06 23:59:59 I
just get the rows back for the day of the 7th. I have tried lots of formats,
including the default ones.
So the time is getting truncated in input also.
Any ideas?
Birt.
Re: datetime feilds are always truncating the time to 00:00 [message #140455 is a reply to message #140432] Tue, 07 March 2006 05:44 Go to previous messageGo to next message
Interestingly, in the "output columns" of the dataset, it shows the type as
"Date".
There seems to be no way to change this. I dont know if this is a java
scirpt Data object, a Java Date object or a birt Date object.
I have no filters, no aliases, no computed columns.
When I do "preview results" in the data set editor, it shows 00:00 for all
dates, even though I know tha these dates have proper times.
"birt" <birt@ohds.co.uk> wrote in message news:dujno8$12c$1@eclipse.org...
> 07/03/2006 11:23:05
> shows
> 7-Mar-2006 00:00
> shows:
> like:
> select
> created
> from
> myrecord
> where
> formats, including the default ones.
> Any ideas?
> Birt.
Re: datetime feilds are always truncating the time to 00:00 [message #140509 is a reply to message #140432] Tue, 07 March 2006 06:38 Go to previous messageGo to next message
I am using trial and error to get a datetime into a report. E.g. using
something like the following:
select to_char(sysdate, 'DD/MM/YY HH24:MI:SS') as mydate from dual
When I do this, the dataa set preview shows the right date and time, ( I
guess its not doing anything with date objects), but in my report the
date/time string comes out blank.
Ive tried lots of formats, but as Birt hangs for nearly 10 minutes each time
I open the data set for editing, this is a long and tedious process which
will take days (and cost thousands of pounds).
Has anyone manged to get a date & time (including seconds) out of oracle
into a report?
What format is it expecting from the DB?
Is noone out there using brit for datetimes?
Birt.
> 07/03/2006 11:23:05
> shows
> 7-Mar-2006 00:00
> shows:
> like:
> select
> created
> from
> myrecord
> where
> Any ideas?
> Birt.
Re: datetime feilds are always truncating the time to 00:00 [message #141981 is a reply to message #140509] Thu, 09 March 2006 07:02 Go to previous message
Originally posted by: r.budner.abg.com.pl
I have to admit that you're right. I have spent some time to find any
workaround, but with no success. It looks like major bug in BIRT release
2.0. I propose reporting it in Bugzilla.
Previous Topic:genReport.bat not executing rptdesign build on FlatFile datasource
Next Topic:BIRT Examples plugin
Current Time: Tue Jul 22 21:22:35 EDT 2025
Powered by FUDForum. Page generated in 0.07509 seconds
