RE: delete an editPart [message #140383] |
Mon, 28 June 2004 07:18  |
Originally posted by: jerome.lafon.bull.net
do you know where i can find a tutorial or simple example on how to use
keyhandlers because i don't understand at all why it doesn't work.
however I have followed the logic example.
thanks
Jerome
jerome lafon wrote:
> I want to know if Somedody can explain me how to catch a keyboard
> event, like del key pressed and assign a method to his event ?
> Actually I have:
> a GraphicalEditorWithPalette, with a KeyHandler, a method with
> sharedKeyHandler.put( KeyStroke.getPressed(SWT.DEL, 127, 0),
> getActionRegistry().getAction(ActionFactory.DELETE.getId())) ;
> and a method createActions((IWorkbenchPart)this) {
> action = new DeleteAction((IWorkbenchPart)this);
> registry.registerAction(action);
> getSelectionActions().add(action.getId());
> The topEditPart with a LAYOUT_ROLE and a CONTAINER_ROLE
> I have an editpart with a COMPONENT_ROLE edit policy, this policy
> implements createDeleteCommand(GroupRequest deleteRequest).
> With this state, I can't delete an editpart.
> I am not sure to understand how it should work. When I register the
> DeleteAction in the ActionRegistry, GEF automatically call
> createDeleteCommand() ?
> Thanks
> Jerome Lafon
Re: delete an editPart [message #140463 is a reply to message #140383] |
Mon, 28 June 2004 13:01  |
Did you step through the code? And did you try the other approach of
overriding keyPressed(KeyEvent)?
"jerome lafon" <jerome.lafon@bull.net> wrote in message
news:40DFFE78.CE32B90B@bull.net...
> thanks
> Jerome
> jerome lafon wrote:
> > Hi,
> > Actually I have:
> > Thanks
> > Jerome Lafon
FUDForum. Page generated in 0.04147 seconds
