Home » Language IDEs » C / C++ IDE (CDT) » debug problem using cygwin
debug problem using cygwin [message #140379] Wed, 09 March 2005 04:13 Go to next message
hello.
i am using cdt2.1 with eclipse3.01 and cygwin (gcc, gdb, ..). I've
created a configuration for running a console-application. it works fine
(output appears in the Console-Window).
But if i try to debug it, a popup appears:
"Unable to set temporary breakpoint in main.
target request failed: no symbol table is loaded.
Use the "file" command..
Continue?"
what could be the reason for that? if i choose "Yes" to continue, the
output appears in a little external shell-window. i've compiled using -g3
flag. In the settings i've chosen "Cygwin gdb" as debugger and set "Stop
at main() on startup".
with kind regards,
watzlaw
Re: debug problem using cygwin [message #140386 is a reply to message #140379] Wed, 09 March 2005 05:38 Go to previous messageGo to next message
watzlaw wutz wrote:
> hello.
> Continue?"
> with kind regards,
> watzlaw
Did you also linked with -g3 ?
Re: debug problem using cygwin [message #140410 is a reply to message #140386] Wed, 09 March 2005 10:14 Go to previous messageGo to next message
Cavit Cahit VURAL wrote:
> watzlaw wutz wrote:
>> hello.
>> fine (output appears in the Console-Window).
>> Continue?"
>> -g3 flag. In the settings i've chosen "Cygwin gdb" as debugger and set
>> "Stop at main() on startup".
>> with kind regards,
>> watzlaw
yes. debugging using command-line gdb works fine. its seems to be cdt
which can not communicate with gdb. other hints?
Re: debug problem using cygwin [message #140415 is a reply to message #140410] Wed, 09 March 2005 11:20 Go to previous messageGo to next message
>> watzlaw wutz wrote:
>>> hello.
>>> Continue?"
>>> with kind regards,
>>> watzlaw
What's your GDB version.
(You can learn by 'gdb --version')
It must be 5.2.1 at least. 6.3 is preferred.
CC Vural
Re: debug problem using cygwin [message #140483 is a reply to message #140415] Thu, 10 March 2005 01:38 Go to previous messageGo to next message
>>> watzlaw wutz wrote:
>>>> hello.
>>>> Continue?"
>>>> the output appears in a little external shell-window. i've compiled
>>>> using -g3 flag. In the settings i've chosen "Cygwin gdb" as debugger
>>>> and set "Stop at main() on startup".
>>>> with kind regards,
>>>> watzlaw
> What's your GDB version. (You can learn by 'gdb --version')
GNU gdb 6.3.50_2004-12-28-cvs (cygwin-special).
Re: debug problem using cygwin [message #140525 is a reply to message #140379] Thu, 10 March 2005 11:46 Go to previous messageGo to next message
Originally posted by: mikhailk.qnx.com
This also may happen if a wrong executable is passed to gdb. Check the
executable name in the launch configuration dialog.
"watzlaw wutz" <watzlawwutz@gmx.net> wrote in message
news:d0menh$917$1@www.eclipse.org...
> hello.
> i am using cdt2.1 with eclipse3.01 and cygwin (gcc, gdb, ..). I've created
> a configuration for running a console-application. it works fine (output
> Continue?"
> with kind regards,
> watzlaw
Re: debug problem using cygwin [message #140563 is a reply to message #140379] Fri, 11 March 2005 17:41 Go to previous message
hi.
it was no cdt-bug, but my nonability to write a makefile: A little
"install -s" stripped all my symbol tables away.
thank you for your friendly and fast help.
with kind regards,
watzlaw wutz
Previous Topic:Can't get C/C++ reference-declaration search to work.
Next Topic:add new keywords to cdt editor
Current Time: Sat Jul 12 17:45:06 EDT 2025
Powered by FUDForum. Page generated in 0.04778 seconds
