Home » Archived » Test and Performance Tools Platform (TPTP) » Problem with using TPTP's API Recorder
Problem with using TPTP's API Recorder [message #140315] Thu, 12 February 2009 10:04 Go to next message
I'm very new to using TPTP. And i've got problem with launching my app
with API Recorder agent - JVMPI isn't supported.
I've spent some time on reading news of this group but haven't found out
aswer:
Is there any possibility launch API Recorder agent with Java 1.6?
My configuration:
- Eclipse Platform 3.4.1 running on windows (IA32)
- TPTP Plugin version 4.5.1 (API Recorder version 4.3.0)
- Java 1.6.0_11
Thank you in advance,
Ihor.
Re: Problem with using TPTP's API Recorder [message #140626 is a reply to message #140315] Fri, 20 February 2009 08:48 Go to previous messageGo to next message
Hi Ihor,
The API Recorder builds on the TPTP ProbeKit, which supports Java 1.6.
However, after testing this configuration, the API Recorder hangs during
recording in a Java 1.6 run-time. Please open a TPTP defect
(Test.Agents.Recorder component) at:
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=TPTP%20T esting
As a work-around, please use Java 1.5, since this run-time has been tested
in TPTP 4.5.x.
Paul
"Ihor " <ihorko@i.ua> wrote in message
news:b04f7204d3cbd2bdc5c4b58fa54e8171$1@www.eclipse.org...
> aswer:
> My configuration:
> - Java 1.6.0_11
> Ihor.
Re: Problem with using TPTP's API Recorder [message #140825 is a reply to message #140626] Mon, 02 March 2009 10:52 Go to previous message
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=266676.
Thanks Ihor for opening this defect.
"Paul Slauenwhite" <paules@ca.ibm.com> wrote in message
news:gnmcba$o6p$1@build.eclipse.org...
> Hi Ihor,
> in TPTP 4.5.x.
> Paul
>> aswer:
>> My configuration:
>> - Java 1.6.0_11
>> Ihor.
Previous Topic:Getting full XML trace from Eclipse plugged-in TPTP
Next Topic:TPTP v4.5.3 will be renaming to TPTP v4.6 and JRE 1.4 support will be removed
Current Time: Sun Aug 31 17:40:52 EDT 2025
Powered by FUDForum. Page generated in 0.05151 seconds
