Home » Language IDEs » ServerTools (WTP) » Lost console view
Lost console view [message #140314] Thu, 22 September 2005 22:02 Go to next message
I want to active the console view, but when I do so (View->Show
View->Console), nothing happens... I tried this several times, but it
didn't work.
Any tips???
Thank you!
Re: Lost console view [message #140496 is a reply to message #140314] Sat, 24 September 2005 00:14 Go to previous messageGo to next message
On Thu, 22 Sep 2005 22:02:34 -0400, Nicolas Laplante <nicolas.laplante@g=
> didn't work.
> Any tips???
Does a wild trial-and-error guess technicque count as a 'tip'?
You might try "reset perspective" and see if it helps ... I'd guess
it would take a different code path so might work.
(Check the log for exceptions).
And, actually, are you sure its not really there, somewhere? Perhaps
accidently made a fast view? Perhaps accidently moved a view whee it usu=
ally
is not (e.g. normally outline area view).
I hate it when that happens.
Re: Lost console view [message #140567 is a reply to message #140496] Sat, 24 September 2005 19:42 Go to previous message
>> didn't work.
>> Any tips???
> usually
Thanks to you, the reset perspective did the trick. I don't know where
it has gone though... :)
Thanks!
Previous Topic:Cannot publish the developent document?
Next Topic:WebTools XML Editor Performance
Current Time: Sun Aug 31 06:21:47 EDT 2025
Powered by FUDForum. Page generated in 0.03428 seconds
