Lost console view [message #140314] |
Thu, 22 September 2005 22:02  |
I want to active the console view, but when I do so (View->Show
View->Console), nothing happens... I tried this several times, but it
didn't work.
Any tips???
Thank you!
Re: Lost console view [message #140567 is a reply to message #140496] |
Sat, 24 September 2005 19:42  |
David Williams wrote:
> On Thu, 22 Sep 2005 22:02:34 -0400, Nicolas Laplante
>> didn't work.
>> Any tips???
> Does a wild trial-and-error guess technicque count as a 'tip'?
> You might try "reset perspective" and see if it helps ... I'd guess
> it would take a different code path so might work.
> (Check the log for exceptions).
> And, actually, are you sure its not really there, somewhere? Perhaps
> accidently made a fast view? Perhaps accidently moved a view whee it
> usually
> is not (e.g. normally outline area view).
> I hate it when that happens.
Thanks to you, the reset perspective did the trick. I don't know where
it has gone though... :)
Thanks!
FUDForum. Page generated in 0.02665 seconds
