Home » Archived » Visual Editor (VE) » Menus again
Menus again [message #12862] Fri, 26 December 2003 12:25 Go to next message
I've tried to move a JMenu (already created) inside to other JMenu, but
it seems to refuse this action. It only works when I put a new JMenu
inside to other JMenu.
I'm doing something wrong?
Vitor
Re: Menus again [message #12935 is a reply to message #12862] Mon, 29 December 2003 19:30 Go to previous messageGo to next message
Hi Vitor,
Are you using the Java Beans tree view of the graphical pane in the editor
? Right now we support dropping JMenu onto JMenuBar in the graphical pane,
and you can also move these around visually - you'll get a vertical bar
showing the insertion point of the new JMenu so you can re-order them. You
can't currently drop JMenu onto a JMenu on the visual pane, either for new
or for existing items. For this you must use the Java Beans tree view that
lets you drop JMenu for cascaded menus, as well as JMenuItem,
JRadioButtonMenuItem and JCheckboxMenuItem.
For visual menus we thought about doing this a while back but we couldn't
come up with a good visual metaphor for designing it. Usually in a GUI
builder you drop something down close to where you want it to be, and
afterwards you see it so you can select it and change it properties. With
JMenu on a JMenuBar this works, but not for items on the JMenu. These
would only be seen at runtime if the JMenu were selected and it was
exposed. If at design time we exposed the menu it'd be obscuring whatever
else was beneath it on the GUI.
> Am I'm doing something wrong?
Not at all. We need to work on visual composition of menus, so please open
a bugzilla feature request and we can engage a design discussion there are
to how it could be done. I know that Instantiations have done some nice
work in this area in the past with WindowBuilder and also CodePro Studio
that enhanced the Visual Editor with menu designer when it was part of
WebSphere Studio. Their approach was to use an enhanced tree that let you
quickly and easily move things between levels, although it maybe that we
need to do more work with the visual composition of menus or perhaps a
combination of the two.
Joe
Re: Menus again [message #13844 is a reply to message #12935] Sun, 04 January 2004 18:18 Go to previous messageGo to next message
Hi Joe,
Joe Winchester wrote:
> Hi Vitor,
I started a new visual class and put some jmenus inside a jmenubar. In
the Java Beans view, I try to move a jmenus inside other and appears a
horizontal bar with the mouse icon changed, but when I drop the jmenu
nothing happens.
Have you experienced a situation like this?
Vitor
Re: Menus again [message #13874 is a reply to message #13844] Mon, 05 January 2004 09:21 Go to previous messageGo to next message
Originally posted by: mendelgili.netscape.net
--------------030801030402050902060803
Content-Type: text/plain; charset=us-ascii; format=flowed
Vitor George wrote:
> Hi Joe,
>> Hi Vitor,
>> editor
>> pane,
>> them. You
>> new
>> that
> nothing happens.
> Vitor
The horizontal bar denotes that you are going to change the ordering of
the menus. See image1 before and image2 after the drop. The "Tools"
menu moved left.
If you drag the Tools menu on top of the "Files" menu (on the JB
viewer), it will become its child (fig. 3)
Content-Type: image/jpeg;
name="Image1.jpg"
Content-Disposition: inline;
filename="Image1.jpg"
/9j/4AAQSkZJRgABAQEAYABgAAD/2wBDAAUDBAQEAwUEBAQFBQUGBwwIBwcH Bw8LCwkMEQ8S
EhEPERETFhwXExQaFRERGCEYGh0dHx8fExciJCIeJBweHx7/2wBDAQUFBQcG Bw4ICA4eFBEU
Hh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4e Hh4eHh7/wAAR
CAHaAw4DASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS 0fAkM2JyggkK
FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1 dnd4eXqDhIWG
h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW 19jZ2uHi4+Tl
5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcI CQoL/8QAtREA
AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMz UvAVYnLRChYk
NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0 dXZ3eHl6goOE
hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU 1dbX2Nna4uPk
5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD6Ru/+QLZ/9hiL/wBOIrlf i/pOtanfaU2j
eFB4kljtbpDCWtx5JZoMSYndVP3SOCTz0IzXVXf/ACBbP/sMRf8ApxFcr8Yr /UdNutLu7Oz8
R3Uf2e6jK6Ol2xEhaEpv+zfNjCvjPGfTrW2WuSxEHG19d/T1X5meLSdGSab9 N9zD8GaHr2g+
ENH0HUdd0fwhqpF9PJZ3+hx36xh7q7uFdp0lEajylJ27+Ah5r0zwz5Z05Xiv 7HUVeOB/tllG
sdvclreImWNVZgEcncAGIwep615z8Prjxx/wiWjawNA0m61uP7aBdeJo71dR iU3lz5ab/Id1
TymTGSDhjxivTNHmvLmF7nUYooruXy2nWHf5Qk8mMOELqrFAwYAlQSB0FZZg 715t2vzPb1Zd
FWivQ5jT/G91cRWGuTaPDD4T1WSCLT9RW8LXDmd1S3kkt/LGyOVnQKQ7uPMj Lon7zyzxN8Sd
A0nw7pGtWrTajHq8drdWUcMExea1lubWBpVUIWJX7ZEwjxvYnaBnODT/AARd W8Vhoc2sQzeE
9Kkgl0/TlsytwhgdXt45LjzDvjiZEKgIjny4w7v+88zCj+Fep7NItJvFFm1j 4e05LLQ0TSmW
WPyrmznga5czkTYNjEHCLFuDPgpkY5dDXUuQfFLT7bXdYt9Z/wBGsbe4VLML ZXRvHRoNMKKb
cRsxcy6iEKnYy/INjfOy7r/EDwwtlFcLPqUskkjx/YotIu5L2MoFLF7VYjPG AJIiWZAMSxHO
JE3c5e/C26v/ABMfEF74ihN1JewXkyQ6eURnR9JdgoMrFQTpRxkkgT9Ts+c8 V/Ce11vxFe6+
8mhXt1cXsk8dvreiDULWJJLazhceX5qEyZskKybgAsjqVOQwNA1PRrG6tb6y gvbK5hurW4jW
WGaFw6SowyrKw4IIIII4INTVT0TT4dJ0Wx0q3bdDZW8dvGfLjjyqKFHyxqqL wOiqqjsAMCrl
SMKKKKACiiigAooooAKKKKACiiigAooooA57xJ4w0jw3rNhY6752n2l+GWHV J9q2YmHIgeTd
lHYZK7gFbBAYthTY8G+IrXxVow1mws76CwlkYWk11EI/tcQxtnjXJby252lg pYDcBtKk5vjr
wanjO5trHW9RkbwyiM11pEKtH9ulz8nmyq2TEvXywBlgCzEDadLwbpOp6Jow 0zUtdm1sQSMt
rc3EeLgQcbEmfcfNdeQZMKWGMgtlmCVe5iah/wAli0//ALBh/nLXb+Bf+QA3 /X/e/wDpVLXE
ah/yWLT/APsGH+ctdv4F/wCQA3/X/e/+lUtbw3EzhPHclj4d+GOt+Kbbw9om oasmqzJH9usx
KJXk1EwhT0YnDAAA9cVe+C2upeX+t+HrXVn1HT9LitZbT7RZTWtxAk3mjynS Y78DysjIGCWA
AVQq8d8VPAfiHW5Z7vTPCWqXGp20t0sbf2nbLZX1vJNOxSSJ3+Y+XcSqoYAZ fDYHzLz37P3h
Xxna/E60upNJ1TT9F0qKZXn1O3khlMcsZ/0RS+GmXzPKkD/MAIyH+cKzqrWl GcKcIXWrb669
O2lrrvd+hUIRcHJvXsdTd+OPi5oul+INR1/R7Kxhh1KwtbOVtOkugv2htNib EEMiu+DcXLiO
J7jMvmRCUCFDP08fxIm0DS7KbxPHe6v9rtr3UpLux0GTSl0+wtGhSeWe3u5z P8plDfIGZl+6
hwC3Z+NPD0PijQG0ia/vdP8A9JtrqK5s/L82KW3njnjZfMR0OHiXIZSCMiuf 1H4b2+r2N3b+
IPFPiDWJbnSNR0c3FwLSORLe9EAkCiGBF3L9nUqSpwWbO4bQupmQf8LOjk1S HRbPwX4mvNcP
2n7VpkTWSy2XkrbM3mO9ysTZS9tmHlu/D4OCrAU9A+K0OoP4h1NtIvbjwvY3 NkbTWrdI0g+z
XNtYy75lklEq7BdvM7mNUSFCSdykGbWfhvez/ElfFOi+KdT0NbmK9e+ktRbv MZpY9OiREWaC
RBFssMtn5txGDtJAur8P7XQtB1mx8IrCsF5pBs4tE1MCfTJpkto7eF59ytOV 8qGGJlD7Sik7
S5LEA6bQtbtdZm1NbOOYxaffNZNOwHlTuiIXMTAncqOzRN0IkikUjK15/efG fQtB8NadrXii
Cawivb7UbeQTTWVvJZi0unhkDRNdM07JjB+zeaXK5CKXRK7PRvCtrpOk6Bpt nqOprFo0pmZ/
PAfUHaKVHe6IUeazvK0zHgtKA5568YnwiW+8NahZX/iLU9Iu9civYtbXSGge O4hubq6ufs+6
4hc7YjeTosiLEzhizAfKqAHW2PjXSrzVLXS4re9+3z6ld6fJalF822+zqzNP Km7KQsohKvjk
XdscDzRVL4ZfEjw98QP7Qj0dtlzp/lNcQfbLW62pJv8ALbzLWaWLkxyDbv3j bkqAylrupeBf
Depaprt9f2Xn/wBu6b/Zt7FkIrRMpWVlKgOryp5SOwbLLbQDjy1o8J+En0PX NS1u88S61r1/
qFtbWry6itsvlxQNMyKot4Yh964kJJBPT0oA1tY/5Zfj/SvF/GvxS1fwD4mm 0HxJokOqXGsy
Y8HHTW8oahIXjj+xz+Yx8mRGlQmbPlshJAVl8s+0ax/yy/H+ledXPwx8K6le +I7zxFbzeIbj
xBH9muX1JlcwWoIZLWDaF8qNWG8bfnL4dmZgCMJW5nctbHUeD111dJ04eJpt Nl1jCm7bTonj
tw5OdsYdmYgcDJOWxnC52iTTvuXH/X5c/wDo56j8H6XJomk6dpMuralq7WoW MXmoyI9xKAeD
IyqoYgYG7GTjJJJJMmnfcuP+vy5/9HPUdBlmiiikMKKKKACiiigAooooAKKK KACiiigAoooo
AKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigA ooooAKKKKACi
iigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAMDVzKvhqFoGRJR qsZRnUsob+0O
CQCMjPbI+oq15HiL/oKaV/4LpP8A4/VbVP8AkXbf/sKx/wDpxq9r+laRq1h5 Ot2drdWsTedt
uFBRCARu56YBPPvVX0EReR4i/wCgppX/AILpP/j9V9RPiW1tfNj1DSZHMiIq tYSKCWcKMnzj
jr6Vw3wYuJ7XxFrenSf2La2c03mW8VojoJ2Cqu6IHgJhWJHJy2c4GT6TrX/H nH/182//AKOS
iWjsCdzO+zePP+evh0/SGb/4v/OR6ij7N48/56+HT9IZv/i/85HqKoeK/E2q aX8WNH0qKYvp
cvh/Ur64tVRCZZYXt9hDEFgcSOMA4O7kN1PM/CLxRLfeOItPk1Sd7W70czJD d6sbyR7jzctk
lQqyCNhmNBhR7lgeqlhJVYSmvsmE66hJRfU7u3tfF2x2u77Q4iCoURWcsmc5 65lGOnvnNP8A
I8Rf9BTSv/BdJ/8AH637n/Vtz3X/ANm/z/j1PnfjHXtS0zxVDpceqi0srtY5 JLp7dH+wjLKT
zgGM7SxZs7CCSdp+Tmtd2Rtc6XyPEX/QU0r/AMF0n/x+jyPEX/QU0r/wXSf/ AB+ub0HxJfw+
K7fQdRnu7n7UGVTd2S200cgRpMFVJG0op5OD0ruaTuhp3MryPEX/AEFNK/8A BdJ/8fo8jxF/
0FNK/wDBdJ/8fqtp/i3Rbm4u7O6uV0y+tJvKmtL50ilGSdjgbiGRwMqykg8j hlZV5jwRp5s/
iJqUiaVIBJ9uea9l0uW2lBa6RkRptxjulYFjGQMxogU4LEUagdh5HiL/AKCm lf8Aguk/+P0e
R4i/6Cmlf+C6T/4/WrXJ694i1GPVZ7HSxaxC1YJM9zE0m9mRX+UK64ADDkk5 JPAxkiTewPQ1
/I8Rf9BTSv8AwXSf/H6PI8Rf9BTSv/BdJ/8AH6XwprKa/oFvqqQNB5pdHjLb tro7IwB7jcpw
cDIwcDpWpSuwMryPEX/QU0r/AMF0n/x+jyPEX/QU0r/wXSf/AB+tWii4zK8j xF/0FNK/8F0n
/wAfo8jxF/0FNK/8F0n/AMfrVoouBleR4i/6Cmlf+C6T/wCP0eR4i/6Cmlf+ C6T/AOP1q0UX
AyvI8Rf9BTSv/BdJ/wDH6PI8Rf8AQU0r/wAF0n/x+tWii4HBsl6nxcsBfXFv PJ/Zxw0MBiUD
MvGCzc9ec/hWzpEl9DbCK11LWt093fOkFqtrtQLdOp5ljJ5JB6nqe1Z2of8A JYtP/wCwYf5y
1teGf+P2z/39T/8AS0/5/oelaXa2JC0vtTuxIbXVPEVwIpDFJ5Tac2xxjKnE fBGRkdeamD66
el34o59tP9v+mfuPzrkpvD2s6LNd+PfBsYuL2W+uxrGlFwkeqRpcSqG3HIWd VGFkPBHyOSuC
nd+EvEWleKtCg1nRp2mtpSVZXQpJFIDh45EPKOpyCp5B9c/M7y7kpplEPrp6 Xfijn20/2/6Z
+4/OgPrp6Xfijn20/wBv+mfuPzrjdb8T6x4Q13Udb8aX/iSHTYPt01pb2cWn vpt7HFBNOkMe
QbsTfZ4mkYyMkZlRwGKMivjaz8VdSVdJ1fWvD+saLbaVqM11erBFdpFfW66R qUxiU3cFs0jq
0AYqUKAmE7iSQC8u49D0sPrp6Xfijn20/wBv+mfuPzoD66el34o59tP9v+mf uPzrk9H+J+ua
isVg3gma11m8vY7SwF015a2M5aCedszXNpHLuVLaXISCQZkhG4732wr4v8ZQ 6l4jXVLWzSxs
/Eej6cj2l+GlgkuV0wSQKr2uJIc3UzGViJGDFQEyrAvLuGh2QfXT0u/FHPtp /t/0z9x+dAfX
T0u/FHPtp/t/0z9x+dcdL8VtUXSdLv08LWjf8JFb2t34fQ6o486Ce6s7cG6P kH7O4+3wttTz
wcSDdwDJ2/g3XrrWk1O11LT4bHU9JvRZXsVvcG4g8xoYp1McjIjOpjuI8kov zbhhhhpC8u4a
EIfXT0u/FHPtp/t/0z9x+dAfXT0u/FHPtp/t/wBM/cfnXSdffP8An+vv175+ Y6++f8/19+vf
PzF5dw0ObD66el34o59tP9v+mfuPzoD66el34o59tP8Ab/pn7j866Tr75/z/ AF9+vfPzHX3z
/n+vv175+YvLuGhzYfXT0u/FHPtp/t/0z9x+dVYrLUUDBJfFA3uznmw5Zm3E /c7lv1rruvvn
/P8AX3698/MdffP+f6+/Xvn5k7vcZyYtdUPSbxRz72Ht/se4/OkmtNSH2P8A 4nGt23n3DRMs
y2jNtEbPkbYiOoHf146Gut6++f8AP9ffr3z82Vrn/Hzpf/X4/wD6Ib/P9T1q XogRjzWOopqe
l2o8R6nsu7lopCY7bIAhlk4/ddcoPwzW5/wjVx/0M+s/98Wv/wAZqndf8h/w /wD9f7/+ks9d
bWkEmtRSepz3/CNXH/Qz6z/3xa//ABmj/hGrj/oZ9Z/74tf/AIzXQ0VfKuwr s57/AIRq4/6G
fWf++LX/AOM0f8I1cf8AQz6z/wB8Wv8A8ZroaKOVdguznv8AhGrj/oZ9Z/74 tf8A4zR/wjVx
/wBDPrP/AHxa/wDxmuhoo5V2C7Oe/wCEauP+hn1n/vi1/wDjNH/CNXH/AEM+ s/8AfFr/APGa
6GijlXYLs57/AIRq4/6GfWf++LX/AOM0f8I1cf8AQz6z/wB8Wv8A8ZroaKOV dguznv8AhGrj
/oZ9Z/74tf8A4zR/wjVx/wBDPrP/AHxa/wDxmuhoo5V2C7Oe/wCEauP+hn1n /vi1/wDjNH/C
NXH/AEM+s/8AfFr/APGa6GijlXYLs57/AIRq4/6GfWf++LX/AOM0f8I1cf8A Qz6z/wB8Wv8A
8ZroaKOVdguznv8AhGrj/oZ9Z/74tf8A4zR/wjVx/wBDPrP/AHxa/wDxmuho o5V2C7Oe/wCE
auP+hn1n/vi1/wDjNH/CNXH/AEM+s/8AfFr/APGa6GijlXYLs57/AIRq4/6G fWf++LX/AOM0
f8I1cf8AQz6z/wB8Wv8A8ZroaKOVdguznv8AhGrj/oZ9Z/74tf8A4zR/wjVx /wBDPrP/AHxa
/wDxmuhoo5V2C7Oe/wCEauP+hn1n/vi1/wDjNH/CNXH/AEM+s/8AfFr/APGa 6GijlXYLs57/
AIRq4/6GfWf++LX/AOM0f8I1cf8AQz6z/wB8Wv8A8ZroaKOVdguznv8AhGrj /oZ9Z/74tf8A
4zR/wjVx/wBDPrP/AHxa/wDxmuhoo5V2C7Oe/wCEauP+hn1n/vi1/wDjNH/C NXH/AEM+s/8A
fFr/APGa6GijlXYLs57/AIRq4/6GfWf++LX/AOM0f8I1cf8AQz6z/wB8Wv8A 8ZroaKOVdguz
nv8AhGrj/oZ9Z/74tf8A4zR/wjVx/wBDPrP/AHxa/wDxmuhoo5V2C7Oe/wCE auP+hn1n/vi1
/wDjNH/CNXH/AEM+s/8AfFr/APGa6GijlXYLs57/AIRq4/6GfWf++LX/AOM0 f8I1cf8AQz6z
/wB8Wv8A8ZroaKOVdguznv8AhGrj/oZ9Z/74tf8A4zR/wjVx/wBDPrP/AHxa /wDxmuhoo5V2
C7Oe/wCEauP+hn1n/vi1/wDjNH/CNXH/AEM+s/8AfFr/APGa6GijlXYLs57/ AIRq4/6GfWf+
+LX/AOM0f8I1cf8AQz6z/wB8Wv8A8ZroaKOVdguznv8AhGrj/oZ9Z/74tf8A 4zR/wjVx/wBD
PrP/AHxa/wDxmuhoo5V2C7Oe/wCEauP+hn1n/vi1/wDjNH/CNXH/AEM+s/8A fFr/APGa6Gij
lXYLs57/AIRq4/6GfWf++LX/AOM0f8I1cf8AQz6z/wB8Wv8A8ZroaKOVdguz nv8AhGrj/oZ9
Z/74tf8A4zR/wjVx/wBDPrP/AHxa/wDxmuhoo5V2C7OB1T/kXbf/ALCsf/px qfxjp9zqnhq8
sbQgTyKpUE4D7WDFc/7QGPxqLWYC+gxWwmeMtq6IJEA3L/xMcZGQRnvyCK17 nQTawNPc+LdV
hiXG55BaKoycDJMPrWKi3qU2ebW8Gp69q+kQwaXq+nrY3VvPN9rt/KhsxEMO sTHmQykEHy8L
hiW3cGvQda/484/+vm3/APRyUyK006WVIovHt1JI7BVVZbMliegA8rk1fPhi Y43eJNWcAggN
FaMMg5BwYex5qpRchJpHmHimfxt/w0t4blsvA8t3osOmXNsdVF7iBYpnt2ke T5DskUxsFj+b
zMqQcFiu38Z9RgspdGhOrz2V5eefDbI2pyWVpkhC008iOpKxjooOWL4Gc5bB 8YeLfEv/AAk9
5oPgvUZ7s6aGN9eXsdmsKFfvDPloFCngszfeBGOATc+HHifWdW8Ry+FfFOqX thrAUvA9tFaG
KYbd20AxNzsIYEMwYZPGBmYYimqijfX+uphRzCjGso79PK/a51/w/ltJfA1k 1lrN5rUKsyfb
7uQvJcMskgZskk43A4HZcdepp+J9BvrnWLLXtHltl1GzGBHdbvKlAOVBK8jB J5wetdM/h66Z
dp8TauBnPEVoP5QVx3ifXPDnhrUv7P1/4oW+kXLL5iQ397YwSMm4gMFeMEjK kZ6ZB9Kqaalz
HTKSk2zG8GeCdV0bxDp2oalHbTRwCVIktrkstqWTAY7lXeuNygDlN+BlT8np FZX9l33/AEMm
q/8Afu2/+M1FfWsljZT3t74tv7W1t42lmmmFqiRIoyzMxiwAACSTwAKzbuCV jmPij4G1LxLq
lnqek3VnBdwReSHuCwCLuJbgA+YrZwyHbnapDKyqy9H4AnuX8LWdpfWV7Z3u nxrZ3MdyCSZI
1UF0kwBKjcMHXrnBCsGVbP8AZd9/0Mmq/wDfu2/+M1dsdAup4i7+JtXBDY4j tf8A4zTSctBb
aliuc8S+ELLW7v7V/aGo6dKy7ZjZugE3GAXV1YZA4yACRgHIC46L/hGrj/oZ 9Z/74tf/AIzR
/wAI1cf9DPrP/fFr/wDGapU5IOZFfS7Cz0vT4bCwgWC2hGEQZPfJJJ5JJJJJ ySSSck1ZpP8A
hGrj/oZ9Z/74tf8A4zR/wjVx/wBDPrP/AHxa/wDxml7JhzIWik/4Rq4/6GfW f++LX/4zR/wj
Vx/0M+s/98Wv/wAZo9kw5kLRSf8ACNXH/Qz6z/3xa/8Axmj/AIRq4/6GfWf+ +LX/AOM0eyYc
yFopP+EauP8AoZ9Z/wC+LX/4zR/wjVx/0M+s/wDfFr/8Zo9kw5kLRSf8I1cf 9DPrP/fFr/8A
GaP+EauP+hn1n/vi1/8AjNHsmHMjjNQ/5LFp/wD2DD/OWt3wvFK09rKsUjRr JqSsyqSATetg
H64P5Hg1g6hYvp/xi0+F765vS2mFvMnEYYcyjHyKoxx6Z561FrlhZ6pY+HNO vdd1LS45/EN8
BFY3NxbvfEfb28gywOjIBtMuScEwherCm1bcEU/ib4R8QyeEtUjOu6peWN7P NHcWNrpzusFt
PLIwkWFCZJ5IpJIpHUsRLHDJGEAchu2+HB1J/AmjPq2hPot+1ohubIIv7qQj 5vuKF5JJIAGM
njrugm8OafLqV/qDXGsCa/tzbTKmr3SxKhUDMcYk2RPhR88YVgckHJJNP4cW U2neGDYzav8A
2t5Oo36x3BvpLtli+2TeXE8shLs8abY2DEkMhGTjNDqOW/8AX9WBRsXz4G8O y6nc397Z6jqT
3Pm74NSv7q8tl80MsmyCZ3ijysjp8ijCO6D5WYNDB8PPCiKouNKu9RYStIZN Tu7m+d8wzQFH
ed3Z4vLuZwImJQGWQhcklvO9F+NX9peG/C98vhry9U1jUba3vdO+3Z/s+2ne 2C3Pm+WFl+W+
sW8sYP8ApGOPLfb2uo/EHwlpbXo1fUptKWykWOaTULKe1Rg0yQb43lRVljEk kYaRCyKJELMA
wJXMwsX0+HvhkWMtq1rq8sksiyfbZtUvJL6MqGChLppDPGAJZQFVwAJZRjEj 75W8C+HHuRcP
Y37ufsrSB765ZZpLaSKSGaVS5EkymGIGZw0jKgVmZchsu5+IHhi2vbW0mn1J ZLmS2h3DSLsp
BLcFBDFO4i2wSN5kf7uUowEiEgBhmZ/HHhZNN03UW1T/AEfVNO/tKxIt5S1x BuhUFFC7i7Nc
wKseN7NIFVSeKXMwsWLT4c+EbZgY9IuXVJIXt45rq4ljtBFPHPHHbo7lbeIS RRExxBUIiQFS
qAHf0/S7Owu9Ru7S0kim1O5F1eNhz5soijhDYOQP3cUa4HHyk8kktyT/ABA8 MLZRXCz6lLJJ
I8f2KLSLuS9jKBSxe1WIzxgCSIlmQDEsRziRN3R2N1a31lBe2VzDdWtxGssM 0Lh0lRhlWVhw
QQQQRwQaOYLGthj/AMs5PxQ/57/z687jDH/lnJ+KH/Pf+fXndn0Uc47Ghhj/ AMs5PxQ/57/z
687jDH/lnJ+KH/Pf+fXndn0Uc4WNDDH/AJZyfih/z3/n153GGP8Ayzk/FD/n v/Przuz6KOcL
Ghhj/wAs5PxQ/wCe/wDPrzuy9cBFzpZKsM3jnkY/5YP/AJ/xqSqWo/8AH5pv /Xy3/omSk5XQ
WC6/5D/h/wD6/wB//SWeutrkrr/kP+H/APr/AH/9JZ662tqfwky3CiiirJCi iigAooooAKKK
KACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigA
ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA4nVP+Qd b/8AYbj/APTl
XR+J5I4tLWWV1jjS7tmZmOAoE8eST2Fc5qn/ACDrf/sNx/8ApyrtqiOzKZwN pd6+0sceteMv
CWrwvcWwit9M0t7abf8AaIju3NdzAqFDZUKDyDkYwe2RL4bd9xbHpuxAwz93 OPn46P8ATcvX
ad1iiqsSfN/jaE+D/Efi2x8SQXUWj+I5Wmg1C3QMFJl85QAxCkhiVZSwOBkc EZX4GeHn1T4k
W3iLRoL1fD+mCRlurtQDPI0TRbVxwfvsx25CgAEkkE/R9QpKTfSwbl2pEjgc ZGSw55zj5fQd
+TyByLBxVRTvs7nmxy2CqqpfZ3X5/myavEfGE82lfG+/1W4vvF9jYvpOnKo0 jQZL+C9aO5vW
eKVktpimA6cK0bYk69CPbqqvYQu7OWkyxycEf4V0zTex6aZ86arp3jKCx1jU LOTxeb42/ibU
YFF5duv2y2vsaYqRliuwxO+2ADy5lALI+1SM3ULbWvE2geJdM8ON4pv9bvb3 xLYait5NefYG
tf8AiYRW8cTXB+ygiUWajySHADA4US19N/2dB/ek/Mf4VDZ6Jp9nE0NpCtvG 0jyskSqoLu5d
2wB1ZmZiepJJPJqOWQ7o8Z1KO9ZtK0rwjquuxWXiayk0501O4vVv7BIpmeW8 jFx++iPlS3Ce
a4YeadPUAIefbNJ/49m/3z/IVTu9P0SHU7Ke7e3jv5fMtLKSUoJX3L5jxRkj JysO8qOoiyfu
5EOheJvCd/rN34f0jxNo+oarZlzdWNvfxS3EGxgj741O5drEKcjgnB5pxi09 QbN6iiobe7tb
ma5ht7mGaW1lENwkcgZoXKK4RwPutsdGwecMp6EVqSTUUVman4h0DS7G/vtT 1zTLK006VYb6
e4u0jjtXYIVSRmICMRJGQGwSHX+8KANOiqWiatpWuaXDqmianZanYT7vKurO dZopNrFTtdSQ
cMCDg9QRV2gAooooAKKhsru1vYWms7mG5iWWSFnikDqHjco6Ej+JXVlI6gqQ eRU1ABRRRQB5
v4m/5LXpv/YJ/wDZpqzdc1ZtGsfDl8+jTajajxDfLdSQaXNezWaH7fiaNIVZ 1JfZGW2kbZWB
+9kaXib/AJLXpv8A2Cf/AGaakvvEVh4W8E3Gsai4EUV3eYXOC5+1TE49AAGY scKqqzMVVWYY
1GldsuJpTeI9Pi1K/wBPa31gzWFubmZk0i6aJkCg4jkEeyV8MPkjLMTkAZBA 5v4ZeJ9Jvry6
8PWfh/WNFuB9p1byru1nVXin1C6USsZFDRvK0bTCJwpCyALuCttST4k2jeDN U8RWlilxNprQ
pPpwu1E4aaQRwndjy/LZj/rQ5jG2TLZjcLN8LviDaeOYJhFax2t3aqDdQLOX 8sklQRuRGA3J
KmHVGDROCoG0tzqrB2Se+xfKyKx+G9jaeENG0aO8/wBO0+30S2mv/Kb/AEiL TLhZ418vfhNx
EgyCSPM53bQK5yx+C/2bXrXUv7W0dfsvkjz4NE8u+vvLvrO78y9uPOP2iZvs e0ybFy0zvj+G
u71vx54L0W7vrLU/FOjwX1hbyXNzZfa0a6SJIjM7eSpMhxGC+ApOOa6OtLtE nnPjbwb4hkv5
7rQL6zlsdR8RaTquo2M9oTOWt57NXaKfzVVEWK1RthjdiVcA/MoXNuvhDdX+ n6fo+p6/pt5o
+jaUNN0q1fRySUS4s5ovtZaYrcD/AEGJXVUiDhnxsyMesUUXYWPJ7j4M2Ell Ystt4Ka8tpLl
vs8vhOJtLAnEAYparKrLJ/o0WJGlc/NKPusix+maJp8Ok6LY6VbtuhsreO3j Plxx5VFCj5Y1
VF4HRVVR2AGBU19dWtjZT3t7cw2trbxtLNNM4RIkUZZmY8AAAkk8ACqnh7X9 C8RWT3vh/WtN
1e1SQxPNY3STorgAlSyEgHDKcdcEetF2wNGiiikMKKKKACiiigAqlqP/AB+a b/18t/6Jkq7V
LUf+PzTf+vlv/RMlABdf8h/w/wD9f7/+ks9dbXJXX/If8P8A/X+//pLPXW10 U/hIluFFFFWS
FFFFABRRRQAUVS1vVtK0PS5tU1vU7LTLCDb5t1eTrDFHuYKNzsQBliAMnqQK ydM8e+BtUiab
TPGnhy9jVtrPb6pDIAeuCVY88j86qMZSdoq4m0tzo6KyB4o8Mt08RaQfpex/ 40v/AAk3hv8A
6GDSf/AyP/Gr9hV/lf3E+0h3Naisn/hJ/DX/AEMOk/8AgbH/AI0f8JP4a/6G HSP/AANj/wAa
PYVf5X9we0j3Naisn/hJ/DX/AEMOkf8AgbH/AI0f8JP4a/6GHSP/AANj/wAa PYVf5X9wc8e5
rUVk/wDCT+Gv+hh0j/wNj/xo/wCEn8Nf9DDpH/gbH/jR7Cr/ACv7g549zWor J/4Sfw1/0MOk
f+Bsf+NH/CT+Gv8AoYdI/wDA2P8Axo9hV/lf3Bzx7mtRWT/wk/hr/oYdI/8A A2P/ABo/4Sfw
1/0MOkf+Bsf+NHsKv8r+4OePc1qKyf8AhJ/DX/Qw6R/4Gx/40f8ACT+Gv+hh 0j/wNj/xo9hV
/lf3Bzx7mtRWT/wk/hr/AKGHSP8AwNj/AMaP+En8Nf8AQw6R/wCBsf8AjR7C r/K/uDnj3Nai
sn/hJ/DX/Qw6R/4Gx/40f8JP4a/6GHSP/A2P/Gj2FX+V/cHPHua1FZP/AAk/ hr/oYdI/8DY/
8aP+En8Nf9DDpH/gbH/jR7Cr/K/uDnj3Naisn/hJ/DX/AEMOkf8AgbH/AI0f 8JP4a/6GHSP/
AANj/wAaPYVf5X9wc8e5rUVk/wDCT+Gv+hh0j/wNj/xo/wCEn8Nf9DDpH/gb H/jR7Cr/ACv7
g549zWorJ/4Sfw1/0MOkf+Bsf+NH/CT+Gv8AoYdI/wDA2P8Axo9hV/lf3Bzx 7mtRWT/wk/hr
/oYdI/8AA2P/ABo/4Sfw1/0MOkf+Bsf+NHsKv8r+4OePc1qKyf8AhJ/DX/Qw 6R/4Gx/40f8A
CT+Gv+hh0j/wNj/xo9hV/lf3Bzx7mtRWT/wk/hr/AKGHSP8AwNj/AMaP+En8 Nf8AQw6R/wCB
sf8AjR7Cr/K/uDnj3Naisn/hJ/DX/Qw6R/4Gx/40f8JP4a/6GHSP/A2P/Gj2 FX+V/cHPHua1
FZP/AAk/hr/oYdI/8DY/8aP+En8Nf9DDpH/gbH/jR7Cr/K/uDnj3Naisn/hJ /DX/AEMOkf8A
gbH/AI0f8JP4a/6GHSP/AANj/wAaPYVf5X9wc8e5rUVkf8JR4Z/6GLSP/A2P /GkPinwwOviP
R/8AwNj/APiqPYVf5X9we0h3NiiuZ1T4h+ANLZF1Pxz4YsTJnYLjVoI92MZx uYZ6j866Cwu7
W/sbe+sbmG6tLmJZoJ4ZA8cqMMq6sOGUgggjgg1nKLi7NWKTT1RNRRRSGFFF FAHDXrFtItGY
5J1mIn/wYiu5rhbv/kC2f/YYi/8ATiK7qop7FSCiiirJCqUnntqEyW88aMIU OHUuBnzADtDj
HOOcDIBGT/BdqvG2dTnTdnEMZ27umWfnG7jp12jOOrYwqAHS+O7ZcWw67cwM cfexn5+eqfXa
3TcNtXxXFf3HhbVoNLMgv5LKZLUxybGEpQhMNkbTuxzkYrSooaurF05uElJd DiPhtY69a6tq
0up2WuWdlJbWa28Wqaqt6xlUS+cylXbaDlPTOM4H3V7eiilGPKrIqvWdabnL dnmfx4sdb1Ae
GrHw3rN7pWralc6jptvLFfzQRbpdIvmRpBGcHbLFC4YqzIVyuCTk13xCl54M k0DwvoXibRZr
H7Gt1Zx6Hc2v2awS5hS7it5kTy3dbcyhBayOxxmEsQprudau9A0qaHV9audM sZY4poYbu7kS
NlTZ50qK7YwuyDzGAOMQ7jwmRD4Y8WeFfFH2j/hGfEui639m2/aP7Ovorjyt 2du7Yx252tjP
XB9KoyPLPDmh6pr/AI1trO6n8cw+C0i1KXS2m1PUrKfAXSwgnculwW846jsW c527ig2BMc/o
Nl42/wCET1/VLlPE1j411y20i+uZfs14bf7GbXTIr9/IhZIlugYrseXGY7vC 4j25Q19GUUAe
GeCfDmv6xrmj2Guaz4zu/D622qTQzI+qaNhg2nCJXL3LXTfMb0r9pfccybF8 tYzWBpOj+K73
w7d32qWfiCLxrrV94Y1PdPZXb2IVP7HWeWW3jKW6ypPBOXT93MI42+7Hg19J UUAeM+PNC1/S
dPMdxqV602t6k+p6rq+kaZqjJFcR28FtDAlpp9ytyqPFHuLvM6B4TkZkjCZn gq28dXOgr4v1
lvFq+J/7X8PRGGWa6jg+zy22lrfH7FkQbQZb3c3l/Iwc5VowV9zsLu1v7G3v rG5hurS5iWaC
eGQPHKjDKurDhlIIII4INTUAeM/Aa28bR6403ijWdaurltNP9tW1zpV5Bbxa gWjPyTXNw8T4
P2gD7DGkBBJO0CBT6b4e/wCQv4j/AOQ1/wAhJP8Aj+/1P/Hpb/8AHr/0x9f+ mvn1s0UAfM3i
W98Zw+CZV0K78TC50a51z+xbuKHVtXlvriLUruOK2k+zzBV8pYLcBrxZkcS4 CkJIG9Nlg8cW
PifU7a1jvdUsNF+2a5pyG8eJ9UluUkEFg8zjyykcrXmUwBGg085OHr0awtLW wsbexsbaG1tL
aJYYIIYwkcSKMKiqOFUAAADgAUJd2r30tilzC13DEk0sAkBkRHLBHK9QrGNw CeCUbHQ0AeDe
DX8Zxf25YaZqPibUJY/sE2gTXek6tZW4v3+1iZbg6jLLI9qIkiMnz7QGHkqL goW9Gj1G6h8F
HTLJvFtjqE+kahcf2rf6abyeyuY2VWMka5WSUySl44ogYpFiYRfuwgPc1S1v VtK0PS5tU1vU
7LTLCDb5t1eTrDFHuYKNzsQBliAMnqQKAPCvh2L4fEG2F7YanbqLd1gnv72/ mkvUAYeeIr4m
4tlLBx5DkhSpKs6sHbrvEPhxPFHgldPF5JY3a6rcSWd3GNxgmN5MgYrkblKu ysuQSrMAynDB
L/VtK1j4x6dcaRqdlqEK6SmZLWdZVG9XlTlSR80ckbj1V1I4INa2lXunDSmt 5tTt7eaO/umw
ZkDowvJWHB/A8isKyUk0y4trVHjD+HNQ+DsF22oxaZqt1rlpcWttpcVq91ZQ WYaH7QPKYxmd
mLR7bYMgCCbYzfJFXU/AHWPDlzNcWGjaPaWM80TXzXdrPJNHqETeWqNukd3Q x42eWWKhShQ4
ZlTqPiFouheNNLittR8TLHc2snm2d0ksIeB+hyABvRhwyHgjBGGVWXC+FngT QfBWt6hrlx4p
s9U1K8V4w6qkEcSOys+1N7Hc5SMuc4Zk3YBLE8fJNVFy/Alt1/r5m3NGUG5f EZupTT2nwM1j
4ez6RrsvidPDN7azmHR7qWG9uzayGSZblYzFIZ3LSAl97NJhgJCyCbxHp2ra J4kk0i3k8Xy+
C1+w3OoPDeX13dfOmoLIIplZ7o/vY9O3JC3yg5ICPIW9R/tfSf8AoJ2X/f8A X/Gj+19J/wCg
nZf9/wBf8a6bmVjxe+/4TL+yrr7T/wAJf9s/s6b/AIQzyPtf/Hz9qvPs/wBt 8vj/AFH9m5+3
8ff3/N59Ta6vjN9R8WJo82u3krSfvNWaLUrdLS2N7CHtorJmWO4K2qzFbizZ ZGEeBtkkWST2
L+19J/6Cdl/3/X/Gj+19J/6Cdl/3/X/GjmCx5cmn69P+z/450+W51jWZbnTt Qj0tbjTbm3nd
GtMCNI7mWW6bMvmY847iThR5YjJwtbtvFF3LeajpGp+KZtMnksLfUNZ1DRLq G/aGNL5jAtta
ra3DRpNJasHhVWJnk3O8aOie3f2vpP8A0E7L/v8Ar/jR/a+k/wDQTsv+/wCv +NHMFjwvxrN4
9tPBNh9mu/Ef9pWGnXNzpV5Ho+pyy38xlkMMMlvb3DCLYiW2Gv8Azi4l/eKG WdT1/hnTtesd
a0jVzJ4je41DxVq9tqSXV5czQJYBr9rciGRjHCmYrTa6KuQVAOHIb0X+19J/ 6Cdl/wB/1/xo
/tfSf+gnZf8Af9f8aOYLF2iqX9r6T/0E7L/v+v8AjR/a+k/9BOy/7/r/AI0h l2iqX9r6T/0E
7L/v+v8AjR/a+k/9BOy/7/r/AI0AXapaj/x+ab/18t/6Jko/tfSf+gnZf9/1 /wAar3F9ZXWo
abHbXlvO4uGJWOUMQPKk5wDQBYuv+Q/4f/6/3/8ASWeutrkrr/kP+H/+v9// AElnrra6Kfwk
S3CiiirJCiiigAooooA82/aa0eHXvgnrmlXL7YJpbMycHlVu4WK8EYyFxntn NeN+HkgsLOGx
060hihjUKiRoMAAccCvd/jmM/C7Vh/tW/wD6UR15P4CSSKC/kRYMR26NK80i xgQ+agkUOzpt
ZkLKPmHLAEgEkfSZZNUcDUrKN2m/nZLT8Tkq0ViK8KTlZN79vMnea9tLbz7i 1eGIbMvJGVUb
yAvJ9SygeuRjrUTapKDgKn5Vvalef2hoWv2ev+KrXRori4u1aFBDISkiSQF0 UZZ0HmIThixO
4fJgCuNUkMI3aFmKLIrwyeZFLG2dssb/AMcbYOGwOhBCsrKOnLcX9ci3OHKz PNcs+oTUYz5l
1t0f9f8ADmgdWnz/AMsx7YFJ/a83rH+QrMMbE9P1pPLb0r0/ZR7HmWXc1P7X m9Y/yFH9rzes
f5Csvy29KPLb0o9lHsFl3NT+15vWP8hR/a83rH+QrL8tvSjy29KPZR7BZdzU /teb1j/IUf2v
N6x/kKy/Lb0o8tvSj2UewWXc1P7Xm9Y/yFH9rzesf5Csvy29KPLb0o9lHsFl 3NT+15vWP8hQ
dXm9U/IVl+W3pR5belHso9gsu5p/2xN6p/3zR/bE3qn/AHzWZ5belHlt6Uey j2HZdzT/ALYm
9U/75o/tib1T/vmszy29KPLb0o9lHsFl3NP+2JvVP++aP7Ym9U/75rM8tvSj y29KPZR7BZdz
T/tib1T/AL5o/tib1T/vmszy29KPLb0o9lHsFl3NP+2JvVP++aP7Ym9U/wC+ azPLb0o8tvSj
2UewWXc0/wC2JvVP++aQ6vN6r+VZvlt6UhRvQ0eyXYLLuaf9ry+q/lR/a8vq v5VmbG9D+VGx
vQ/lR7Jdgt5mn/a8vqv5Uf2vL6r+VZmxvQ/lRsb0P5UeyXYLeZp/2vL6r+VH 9ry+q/lWZsb0
P5UbG9D+VHsl2C3mbsl48PFxdwQuOGRo5CVPodqkZ/GoH1i3T72qWw/7YTf/ ABusjW7pvt96
iscLdSj/AMfNczfXNxkgMQM8Cuyhl8aiu3+X+RnKpys7yDV/tX/HlcxXY3iM +WrAhj0BDAHn
txzg+hqaS/EY/eahbKf+uch/UIQfwNcz8ORuubhh1+2WefzlrqfBd14Zj0S9 1DxRp91fwRSW
8EIgchlLrKT0deMJXLXoRpSmrNqNtrXd/wADWKulruVn1m2j+/qlsP8AthN/ 8bpbfVJbrYbK
WK5RyQsiAhcjls7gCMDk5HTnpWheaj8MNWsb+x0rw5q1vqH2C6lt5ZpW2I8c DyAn98f7vTBF
cl4J+XQ5XBx++vD/AOSyVnUhGNGVTkkmukrdn29DSnT5qijzXv2v5G/LdSx8 NqFoD7wy/wDx
uqsmoqgO/VLEf9sZv/jdafhy30bX7efRbi4NlrMzBrC6d/3MhxjyWHbJ6Hrn GOm1s/xdpOle
GtAGnanI134ouSkjpFL+70+PrtbHDOw7duCMAAv81LNqq6L7v+CfS08lwzly tyv/AFrtscj4
5t7HW9Jm07U7e3u7WePKuo4YZ+8vcEEexBHYivpr4Q2f9n/CbwfYeZ5v2bQr KHftxu2wIM47
dK+Zr5P+JBpzDnNvJx/23lr6k+HH/JPPDf8A2CbX/wBErXTm7VTDUqrWrOCF KNGpOEdk2b1F
FFfOmwUUUUAcLd/8gWz/AOwxF/6cRXdVwt3/AMgWz/7DEX/pxFd1UU9ipBRR RVkhVKTz21CZ
LeeNGEKHDqXAz5gB2hxjnHOBkAjJ/gu1XjbOpzpuziGM7d3TLPzjdx067RnH VsYVADpfHdsu
LYdduYGOPvYz8/PVPrtbpuG2r4riv7jwtq0GlmQX8llMlqY5NjCUoQmGyNp3 Y5yMVpUUNXVi
6c3CSkuhxHw2sdetdW1aXU7LXLOyktrNbeLVNVW9YyqJfOZSrttBynpnGcD7 q9vRRSjHlVkV
XrOtNzluzyD9qW21G58KWNvpTanJd30Wr6eLO0ml23Yk0XUHEbQodsreZFEV ypII+XGTnT8T
+FvEy3/hjT/+E58Z6nZ3mtldRlX7NbtDarYXpZS9rBEVSSQxKWb5lbyzGyPt au/u/wCyodUs
bi7+xR38nmWllJLtEr7l82SKMnk5WAOVHURZI+XIzNH8b+C9ZmtIdH8X+H9R lvJZYbVLXUoZ
WneJFeRECsdzIjKzAZIDAnAIqjI8T+KF38Qj4j1+bQR4mtL25ttVtW0+y0/V JUSGPTrr7LPH
dea1mHklitJFWCNJVeURliwl37PiDTPH2j3WsJ4Lk8TS3kOpXWmaT9svZ7qI 2p0N7mJmNyzR
t/xMSFE8mWBxDvCDy69m0rVtK1b7X/Zep2V/9juXtLr7NOsnkTpjfE+0na65 GVOCMjIq7QB5
n8C7bWLf+2Ptes61qWmt5H2b+0dK1Cz8ub955u3+0bia5fK+Tn7sQwNmXMuO s8OW0d74av7O
ZvECxT32oxO1/M8N0A11MCY3Qhki5/cspBEXlEEGtPW9W0rQ9Lm1TW9TstMs INvm3V5OsMUe
5go3OxAGWIAyepAqGyu9A8WeHWms7nTNe0W/ikhZ4pEuba5TlHQkZV14ZSOR 1BoA8A8P6t44
vbH4c6tFc+IFuzY+H4zss9Tvo9Ttphbm7uZZkl+xxNiW5VhPE8oEPmBhviKd mtt46s9G1mC6
bU72Lw/YnQrN1mujLfRzSRs+oybCslzLDafZyDCySNOt9GmC0bD1+igDwbwj L46bQbu20668
W3d/a6vNFpk8mnXVmsmmm2tXuCyam7sZRK8ogaZ3bzgACLYTqvc+Lr6SbwJe aRolx4m0dIdN
sJotTfSL2+leGWUqYdisLtptkRWQgrLGJlfcrcjurK7tb2FprO5huYllkhZ4 pA6h43KOhI/i
V1ZSOoKkHkVNQB4Zp9j8S7xLKHRre90NL/TUuYItS1e/vI7aSyubqVBLPKol H2p7jT90ciiQ
26XMbCNokFU9L0zxtrfi/RotZk8ZwaHqtzFqEyR3t5aNbQTnX7hIJXjZTE8a vp0ciBsKyQpk
gJn3+igD5t8fXfiPTvA3iufxLc+ObWLTdI1OPwxcWEmoqyTQXmoIklzJbcsv 2dNOYS3ZKsNz
hmJlY+5an4sstMW/kvtL8QLFaXy2Qa30e4uzcFoEm8yNYEdjEN5QuQAHRl64 zd1jw9oGs32n
32r6Hpmo3emy+dYT3Vokslq+VO+JmBKNlFOVwcqPQVde7tUvorF7mFbuaJ5o oDIBI6IVDuF6
lVMiAkcAuueooA+avgnoGs+GviAula7p01jdw6dpsTLIMqxj0ezhcowyrqJI 5E3KSMowzxXp
X9pXtrHBaWLXks01xeslvbvtLYu59zHJCqAMZZiB0GckA2fE3/Ja9N/7BP8A 7NNXO6z4js/C
2o2epXmDvi1OCBWbYjStfkgM/RRhWJPJwpwC2BXBmFWdKjKUFrp+djWklJpM 1n8UPayNBqmq
T6ZcqfmgvLoI+PUfMQw91JGcjqCBfl1x7awk1C51dobSKIzSTyXO2NIwMlyx OAoHOemK88Pj
e4mkJj8fTNM5+WCzt7Y5Y9EjUxMx5wFBLHgDJIzWx4d0m+svCN1aazHLrETW xjj0p47dsQhC
ogJwiOzDg7jt5xnALHzcux1XEtqaaS62a/OxtWpKn1Ok8OeLRrvn/Y5Ndi8j bu+3add2ed2c
bfPjTf0OduccZxkVryapcQy28b3F4xnkMaFFkcAhWbLEAhBhT8zYGSBnLAHx mTwz4uulS70W
PW9Fjs7uCTT7bWb5NQuoZ5Ibq1uLre80o8tI7qKURGQ7jbOoRfM3nK8XfDDx NLpuoWelWv2u
G2t5tK0yPzI0zZJpmqLbHLPn5X1CO1+b5j5HmscOdvr/ADMD6IS6uj/y8zf9 9mn3GpLZWVxe
31+tta28bSzTzTbEiRQSzMxOAAASSeABXiHjfwvp/hnUbnUBoGkW3gG2+wXF /pKva2tpeSYv
4pMxStHAXEk2nuTIVDeSmCzRqtbPw+0KTWfglb2ukWEOlD+3ZtW020lCJF5U WsPeW8e6Lcix
uiIokj3qFcMocYBXzA9I8N+KbbX/AD/sK65D5G3f9v0q7ss7s42+fGm/oc7c 44zjIzr+fP8A
89pP++jXmvi7+2PFlhYfbvh7rB07T9RWe/0e/lsJP7VhME6BFQXDRP5czQSk Ssg+QMu5lArk
Lf4ZatPczXl/4as5GP8AZkVgspgd7KwOs3ktzZA5IREsJ44XjQmNlBjUuoxV fMD3nz5/+e0n
/fRo8+f/AJ7Sf99Gvm6XwjqE3iXxLoH/AAhn2zWl0bydA1EG12+H0k1LV/sU qO8gkhRIzAyi
BWZFiACgqq1seM/AXiPUbDxBaaf4Yxrlx/bT3Gu+bbr/AGra3MF4trZeZv8A ObYZ7QbJVWJf
s3DYSPcW8wPefPn/AOe0n/fRo8+f/ntJ/wB9GvEfHnw1ujqVzZeGtC+xeEj9 guLjStHhsUW8
lVb9JttvcD7MzhpLB2MqgFYVKkvGgFRfhdqB0LxBO3h77Rq8PhVLfwzcX0tr JeWV4J9RljSK
SNUS2eMTWoHlBY49qqjsIw1HzA9t0jWoNWtHutPvZJoUuJ7Zm+ZcSwyvFIuD g8OjjPQ4yMjB
q558/wDz2k/76NeI6p4Elh0LWbEeCby5vpvEU+pTXFjBp0tvrKSz3U0CXUdx KhnhiEyKyPsY
OFMTfKJB6z4Wtbqx8M6VZXttptrdW9lDFNDpyFLWJ1QBlhU8iMEEKDyFAofq Bq+fP/z2k/76
NUdUkke70wPI7D7UeCc/8sZKtVS1H/j803/r5b/0TJU3Ywuv+Q/4f/6/3/8A SWeutrkrr/kP
+H/+v9//AElnrra6KfwkS3CiiirJCiiigAooooA4z42/8kz1P/rpbf8ApRHX lXhO9tNJW7vL
q0F0Rauqxnd8wOBIAFBJYx71UYI3Fc4HI9U+N2f+FZapjr5lt/6UR1594V8D +INa0W31Wzut
Ojgm3bFldww2sVOQFI6j1r6TLZ044GSqOycmvwRwYlT9rFwV2jH07XtFkjhh 1mbV7xIIvLgV
fD7wnOCgMkoidvljOMooJLMcZANRXcdlc6pcT6Z5x0/y447Xzo2jaJFX/Uor BT5aEkKSqEks
SpJMknaj4beJsc3uk5/66Sf/ABFI3w18T9r3Sf8Av5J/8RXRRq4KjLmjP+vu Ma8sTXjyyicR
9lPvR9lPvXZn4ZeKCf8Aj+0n/v5J/wDEUf8ACsfFH/P9pP8A38k/+Irp/tDD fzo5vqtbscZ9
lPvR9lPvXZ/8Kx8Uf8/2k/8AfyT/AOIo/wCFY+KP+f7Sf+/kn/xFH9oYb+dB 9VrdjjPsp96P
sp96p/G9PiR8PtO0JPC3gK38ZXd9NdG8eCxvbtbdEEHlD9wybSxaX7wOccdD XWa38PfiS2s3
x0jT/CI043EhtPO1q4WTytx2bgLRsNtxkbm57nrWKzfDczi5bdbafgX9SrWu c/8AZT70fZT7
1q/8K8+LP/QP8F/+D25/+QqP+FefFn/oH+C//B7c/wDyFVf2rhP5/wAH/kL6 lW7f195lfZT7
0fZT71q/8K8+LP8A0D/Bf/g9uf8A5CrF8Gjx94l+K/jHwlf/AA+h0HQ9P+1f 2NrEtlfQrceX
dxpHmWR2jffCXb5V5xkYAqZZvhk0lK9/Lb1vYawNazbJfsp96Psp967P/hWP ij/n+0n/AL+S
f/EUf8Kx8Uf8/wBpP/fyT/4itv7Qw386I+q1uxxn2U+9H2U+9dn/AMKx8Uf8 /wBpP/fyT/4i
j/hWPij/AJ/tJ/7+Sf8AxFH9oYb+dB9Vq9jjPsp96Psp967P/hWPij/n+0n/ AL+Sf/EUf8Kx
8Uf8/wBpP/fyT/4ij+0MN/Og+q1exxn2U+9H2U+9dn/wrHxR/wA/2k/9/JP/ AIij/hWPij/n
+0n/AL+Sf/EUf2hhv50H1Wr2OM+yn3o+yn3rs/8AhWPij/n+0n/v5J/8RR/w rHxR/wA/2k/9
/JP/AIij+0MN/Og+q1exxn2U+9H2U+9dn/wrHxR/z/aT/wB/JP8A4ij/AIVj 4o/5/tJ/7+Sf
/EUf2hhv50H1Wr2OM+yn3o+yn3rs/wDhWPij/n+0n/v5J/8AEUf8Kx8Uf8/2 k/8AfyT/AOIo
/tDDfzoPqtXscZ9lPvR9lPvXZ/8ACsfFH/P9pP8A38k/+Io/4Vj4o/5/tJ/7 +Sf/ABFH9oYb
+dB9Vq9jjPsp96Psp967P/hWPij/AJ/tJ/7+Sf8AxFH/AArHxR/z/aT/AN/J P/iKP7Qw386D
6rV7HGfZT70fZT712f8AwrHxR/z/AGk/9/JP/iKP+FY+KP8An+0n/v5J/wDE Uf2hhv50H1Wr
2OE0jUPDNp4y1g+KbG4vbPzp1SOFsMJPN4P3l4xu796rfEC/8E3y2n/CK6Zd 2Gzf9p+0OTvz
t24y7dMN6dR1r0ST4X+IpX3zN4bmfABeWEOxx0yTESaYfhXrh6xeFT/26L/8 areGa4WNVVOd
3XTmdtu1rClhK0oOFvw1+884+Fy+ZdXjDot3ZnP/AH9pvh7UtI/4R6703VLi 7t/NngmR4IFl
/wBWsqkEM6Y/1g9ehr0xPhh4ljUJDcaFAgO7bCGjXPrhYwM+9I/wu8QO7PIP DMjscsz24ZmP
qSYsk+9Oeb4WU5ycl71uu1vkEcJWSStseb2114W057m7g1LVLiY2dzBHG+nx opaWF4xlhMSA
N+eh6UngkFvDF3IBwJL3B/7dkr0c/CrWz1h8Kn/t0X/41UifDLxRHsEN3o0K p9xYiyKv0AjA
FZ4jNMNWpShz6vq/n2S7l0MNVpVFO23T7vXscX4R8Taf4f0y5u7W0MmvufLt rmTDR20ZHzMq
936jnjB9MhoPEXimy17wuttrVvJca3ZlUs9QRhmSLPKTZ5bHY9cnPHzbu2Pw t8REnjwsfrar
/wDGaP8AhVniLpjwt/4Cr/8AGa+Wlg6b/wCX0fx/yPq45pBS53Sd/U8wki3e GNPYj/l3k/8A
R8tfS/w4/wCSeeG/+wTa/wDola8U+IPg3XPDmijUNRudPlhkcW6rblsqdrEY BUADCnp7V7V8
Nju+HXhpvXSLU/8AkFa9DMnD6lSUJXS0v8jyYTc605NWu7/eb9FFFfPm4UUU UAcLd/8AIFs/
+wxF/wCnEV3VcLd/8gWz/wCwxF/6cRXdVFPYqQUUUVZIVSk89tQmS3njRhCh w6lwM+YAdocY
5xzgZAIyf4LtV42zqc6bs4hjO3d0yz843cdOu0Zx1bGFQA6Xx3bLi2HXbmBj j72M/Pz1T67W
6bhtq+K4r+48LatBpZkF/JZTJamOTYwlKEJhsjad2OcjFaVFDV1YunNwkpLo cR8NrHXrXVtW
l1Oy1yzspLazW3i1TVVvWMqiXzmUq7bQcp6ZxnA+6vb0UUox5VZFV6zrTc5b s4b4mXbaZ4o8
CamLnU44l1e6huYbSSd1uIf7MvZSjW8efOYPBGyjazAr8vLEHzmbwxrfib4n 3/ijSNOvbF5v
7R1LQL7ULOa1EdzHBoUUazK6CWFJXtbqJ1Kq8kPnbcqwY+2a1d6BpU0Or61c 6ZYyxxTQw3d3
IkbKmzzpUV2xhdkHmMAcYh3HhMgTxDoEk2lQprmmNLrMTTaWgu0LXyKgdnhG f3ihCGJXIAIP
SqMjwDUvCfiPw3qup6Rpt74g07wyNXkknv49N1G7uL+5/s3S1jnf+zpYLh2k Zb5nlyYjIH3j
eUI6bR9K8aQLe+INRu/Ftx4htvEGh2qebPMkElq8GmJev9jike125kvSzIHV GDlXygYe2UUA
fNviW78V6j4X8HaLPF45S+0TSLJfEU8ej3czLew6no5aZGeF47uVFiu3V0Ew IDsNysc6eoQ6
+2j3oU+JodN1PW3vB4hl0rVP7QujHZ2sKCey05raePcROgbZHEFtIyyM8qSt 7/UL3dql9FYv
cwrdzRPNFAZAJHRCodwvUqpkQEjgF1z1FAHmXwDh8XX0GoeIfG134g/tGaKw RLO9DQQRl9Ls
HuHSHaoDG480HghGSQIELS7+68Pf8hfxH/yGv+Qkn/H9/qf+PS3/AOPX/pj6 /wDTXz62aKAP
mbxLe+M4fBMq6Fd+Jhc6Nc65/Yt3FDq2ry31xFqV3HFbSfZ5gq+UsFuA14sy OJcBSEkDemyw
eOLHxPqdtax3uqWGi/bNc05DePE+qS3KSCCweZx5ZSOVrzKYAjQaecnD16NY WlrYWNvY2NtD
a2ltEsMEEMYSOJFGFRVHCqAAABwAKmoA8A8Gv4zi/tyw0zUfE2oSx/YJtAmu 9J1aytxfv9rE
y3B1GWWR7URJEZPn2gMPJUXBQt6NHqN1D4KOmWTeLbHUJ9I1C4/tW/003k9l cxsqsZI1yskp
klLxxRAxSLEwi/dhAezv7u1sLG4vr65htbS2iaaeeaQJHEijLOzHhVABJJ4A FTUAeDaPp3ji
9sdOtdOXxBpthqMt7o0t5NqWpvK6Si0c6kEvMz2TLFbXscSyFhHPJFgyJKZD S1O2+J+p6nbS
6q3iCCLU74RXsGlTXkEVuI7/AEK1nMZUhoon8jUpomDAmCV3yC0gH0NXP6n4 38F6XfX9jqfi
/wAP2V3p0SzX0FxqUMclqjFAryKzAopMkYBbAJdf7woA8q0C21HTvjpqmk3L am+nWJWLSXv5
pZ5Gt2tY5GImlLSSr58k43MzYIKAgIFHRxxhoczXvl/6Td7FW034X7XN1JkG TnPbpirXib/k
tem/9gn/ANmmqjBbJqOsWemzyTJbMNRuJBFIY2cpfOoUsCGC/vCTtIOVHONw PFja8aFOVSXS
xpTjzOyLSQxdtRb/AMAP/ttSpCM8aieP+nD/AO21zE2r6LbzumleILo2mcp5 ui3l6P8AgEy4
3ocZBy3Xg7cBZNJ1261zw1ePoiQprkFrtEd7bzR28V2Y8qjkqCVDYzt52kHu K48LjqeIfLFW
aNJ03Dc6pIWHTUR/4Af/AG2pkhm7ajGf+3A//Ha8p07xsfC1x5Pie88TM7yb rqPW0st9jai1
vLgXCfYYysgb7HKmwsWGzOAMb49b+L0llbRXI0WVJrOze6vbVLxceeltqrTW jMYjuEcumsnm
JjcSGBKgq/dZ9jO57CkNz21GH/wAP/x2p4ob3BC6jb/jYH/47Xn8njnW7TV0 8M3fhzTl8Szy
QC0hi1V3snSWO6kBecwB0IWxuMgQsM+Vz8zFL0XjXU5fh2dc/syzstUfWRov k+e1xBDMdS+w
ebnbG0iBv3m3CFgNuVzuCtrsB2vk3/8A0Ebb/wAAW/8AjtHk3/8A0Ebb/wAA W/8Ajtcneza1
4SWztU1rUvFmpa1erZ2EWryW1rDC6wzTuWktrYMoMcL/AMEhLBAAoLMMKT4q ans1e7h8L2bW
Ph7Tnvdcd9VZZY/KubyCdbZBARNg2MpQu0W4MmQmTirAek+Tf/8AQRtv/AFv /jtHk3//AEEb
b/wBb/47Xnmk+NvEVp4S1nVdTs9NvJE12/sNGQXM5mvRFfXEflmGC1d1McUW R5azFljZn2AM
wzdM+K+p6vrVlaaJoHnXmoeRai01G+a0ggmVtVE7Z+zGYc6awG9QSGTKRMHD OwHqvk3/AP0E
bb/wBb/47R5N/wD9BG2/8AW/+O15hf8AxiniuktLLwdqWo3VrHI+qQ2kV1cF DHdXFsyW5ht5
FkJktJ9vnG3DDyzkZcR6Vz8SNTj0K+1ceFfKtodZuNJguJ7xvs48ie4jlurh 4opDb2wEA/eM
pw7EMEjAmYt5Ad75N/8A9BG2/wDAFv8A47R5N/8A9BG2/wDAFv8A47TNEvP7 R0Wx1DfZv9qt
45t1ncefA25QcxyYXzE54bAyMHAzirlSBW8m/wD+gjbf+ALf/Haq3cdyt9pp mu4Zl+0thUtj
Gc+TJzku35YrzT9obxh4n0mG28M+GrB1u9Xkt4LXUILzZJFPJIwSMjGI9xRc O5If94oU7TXe
aEniCPSNAj8UyWEuspOy3Ulju8mQiOUBlDAEErgkYwCSBxg10zwzhRjVbWr2 vr6kRqXm422N
W6/5D/h//r/f/wBJZ662uSuv+Q/4f/6/3/8ASWeutpU/hHLcKKKKskKKKKAC iiigDi/jd/yT
LVP+ult/6UR1P8H/APknWl/9tv8A0c9QfG7/AJJlqn/XS2/9KI6n+D//ACTr S/8Att/6OevT
/wCZb/2//wC2mH/L/wCX6nmfw78V+Nm8DeHvE/iC48czjVItGDTXv9iR2Mj3 d5aRs0It0acK
RM+FkUHyywykm1lm+FHxY1K50fwhoZ8Pa1rW3TdItdU1MQ3k8v2m4s7eUyll t2gKKLiN5Hlu
I3AEh2NhPM9aj8LaFH4Y0zwyljjSdL+x/Y7fzX/dfZXje3+bO47WijPJOdvO QTnM074ceD9O
m057LTJoYtPit44LZb+4+zMYEVIJJYN/lzSoscQWWRWceVGQ2UTHmG51lef/ ABp1TxBp8XhW
08Oz61FNqetm1nXSEsjdyRCyu5tqG8Hkj5oUYlsHapA5OD6BWN4s8MaR4ot7 OHV0vf8AQrn7
VbS2d/PZyxS+W8e5ZIHRxlJZFIzghjmgDzL4meJvFml/DTxPomjre3Wrab4R l1XUdS1fUYrO
9s1nS58ry/scLRSTRm3lBCmNRsjw7FmZdP4deL/FGvfErWdMWOG40KzikEzX V2qz2zrqeq2w
aJY7cCVXFpEu12UoqDmRizN0Gr/DHwhq2ljTtQh1qaE2z2kzf2/fLLdQMzsY riUTB7hAZJNq
yswUO4UAMQdPTvBvh3TtWi1XT7Oa0u45biVmhvJkWYzyyzOJlD7ZlEk8zosg YRmRigXNAGZ8
Q/8Akbvhx/2Mk3/pp1GofjK2uW2hadfaH4o1PQ5f7X0+ylFpBayLMl1fW9u5 bz4ZMMqSOV24
GT8wYACsX47+N/B/grXfAd94t8Qw6RFBq9xeqJLa4maZFsbi3YJ5Ub4YPdxH 5toxuwSRivRt
Z0uw1izjtNRg8+GO5gulXey4lgmSaJsqQflkjRsdDjByCRQBxk3ja/0rVJbB tP8A7R0nSNSs
NC1LVLi8VL2S8uVthG626QiJ0Ju4C7b48Zl2xkKofmdc+I+q6tovh1xp39kQ +IbnSNU0a4td
RaSWWxOq6ckqXK+Wghdo7yIFEaVSGlUtgDf6Ne+DfDt54iXXp7OZrvzY5njW 8mW2mmjx5c0t
uHEMsq7I9sjozL5ceCPLTbTtPhx4PtmzHpkzKksElvHLf3EkdoIZ45447dGc rbxCSGE+VEEQ
iKMFSqKAAQfDLxtN4x/tBp9PstLe28php73kh1K2WTeVF7ayQxm2cqoIAaRW 5KsyhWY0j/kt
/ij/ALFvRv8A0p1Strwx4Y0jw79obTkvZJrnaJrm+v5724dVzsQyzu77FLOQ m7aC7kAFmJ4X
wP438H+Ifj74u0zRfEMN5qltpFrZXNiLa4SSB7K6u1nJZ4xGVDXcSjazEkNx gZIB6nRRRQAU
UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAebft
Ff8AIi2//X8v/oqWuo+Gf/JOPDH/AGCLT/0Slcv+0V/yItv/ANfy/wDoqWuo +Gf/ACTjwx/2
CLT/ANEpXqVf+RfD/EzGP8RnQ0UUV5ZsFFFFAHC3f/IFs/8AsMRf+nEV3VcL d/8AIFs/+wxF
/wCnEV3VRT2KkFFFFWSFUpPPbUJkt540YQocOpcDPmAHaHGOcc4GQCMn+C7V eNs6nOm7OIYz
t3dMs/ON3HTrtGcdWxhUAOl8d2y4th125gY4+9jPz89U+u1um4baviuK/uPC 2rQaWZBfyWUy
Wpjk2MJShCYbI2ndjnIxWlRQ1dWLpzcJKS6HEfDax1611bVpdTstcs7KS2s1 t4tU1Vb1jKol
85lKu20HKemcZwPur29FFKMeVWRVes603OW7PIP2pbbUbnwpY2+lNqcl3fRa vp4s7SaXbdiT
RdQcRtCh2yt5kURXKkgj5cZOcXx18P8AxRot7Zal4TWa91Gxvr6HwuiBZE0u 3fSdReNMOojh
U3c6QgcR+VBZIeU59m1q70DSpodX1q50yxljimhhu7uRI2VNnnSortjC7IPM YA4xDuPCZAni
HQJJtKhTXNMaXWYmm0tBdoWvkVA7PCM/vFCEMSuQAQelUZHifhnQ/EuoX+ka dNrvjO+8PT63
H9qZbbWNIaMLYX7PmW6unvNhkFnnLJDuEYTc7SgGqan420Xwp44gu4/Gcs13 ol7pnhk2tleX
cqz297qkcLbolZo3MD2BE8pUygK29yrEe/0UAY3iH/kL+HP+Q1/yEn/48f8A U/8AHpcf8fX/
AEx9P+mvkVwvxXuNXsvHVoNHOp3DX3hbUo7i2hu7ny0VbvT0+0rBE6s0sMdx O4EO2aQDYrBi
mPTUu7V76WxS5ha7hiSaWASAyIjlgjleoVjG4BPBKNjoaEtLVL6W+S2hW7mi SGWcRgSOiFii
FupVTI5APALtjqaAPDPCMvxGs9Bu9U0q61PVZbDV5tL0+DVtO1K2int7q2tf LuGguXe5ZYb0
/NLJI2yD7Xs48tVm8Ux+LdH8ceHrLTL3xM39l3Ok6bC8lpqV/wD2rZGWFbm6 uJ4pBZRPskuF
fz4Wk/deYGXfEU9tt7u1uZrmG3uYZpbWUQ3CRyBmhcorhHA+62x0bB5wynoR U1AHmfhXUNV0
n+1dU1Oy8Z39jZ6bNcaBayRNJNPZJhmjkTIZr1mChBcESGIxD/XfbKxfHen+ LdW8fa9pehXu
tT3N7ptxb2N15upaZaaCWsWWOTeg+y326dwcqPOiZ8jeI/3Xs1FAHgHjP/ha eo+HtQ1Gw/tq
z/tTTdR1+1t7b7THc2eNPubaGxZR/q5j52mzCEZ/0iK9cH5Ywbmo6Z4+sNDl 1jwvJ4mfxRqO
t+IbbZd3s81ukAXU2sSILhjbwp5kVjskCqCCoztkIb3Oobi7tbaa2huLmGGW 6lMNukkgVpnC
M5RAfvNsR2wOcKx6A0AeTfDzW7Cw8deJodFj8c3+lpY6Gq2mqjUpJ4pri7vI ZJlS/PmLEFET
O6/KFiY8lSKpfGCxbxv4r0yGz8PanqOnaZLFYaql3pE8cMgk1rSXIUSoFuIv KtbhmePegVMs
QGXPrPhvw9oHhqxex8OaHpmjWkkpmeCwtEt42cgAuVQAFsKoz1wB6Vp0AeIe HtA1Xw78T7Oz
1jW73V7lrJtk1zdNORBHvhg+ZgDvaKKOSXsZpJmHDABnimzbU4oo7XXILF45 b6G5jdBIssb3
kjGNxuU4O1CRnkcHIJB1n8Q6B4l+LthfeHNc0zWbSPTjC89hdpcRq4MpKFkJ AbDKcdcEetdZ
4S2jR7hyisRqN2Bkn/n5m9PpXNiKcaicZK60NItrVHl6aXqbkLN4u08Rnh/K sgj477WMhAPo
SDj0PSukgi0WLSG0qG5jgtTE0WIboxuAwO4iRWDhySTvBDZOc55rpk8WaI4Q xpcOHXchWxuT
vXj5hheRyORxyPWprbxHpNxeQ2ixyxzTsViE1pPEHYKWIBcAZ2qxx6A1yYfB 0MPf2UVG/ZFz
qyn8TucNYeHfB9rayW5lNz5lxb3DzXmqTXMzNbyrLCPNlkZ9iSDcE3bcs3Hz NmfV/DngfWI7
2PUo7SdL64kubgfbWXfI9mbNm4YYzbkpgYH8X3ua9G8xP+eEf5t/jR5if88I /wA2/wAa6beZ
B514w0LQNdiu7q11HTbPWpo7eOO/eeXMIhaQqV8maJ0O2eddyOhIlIYsuVq9 4K0jw7oPgkeF
rvVbLVbeT7Q139rmEi3DXEjyzBhIzsyFpHADs7bcBmc5Y9v5if8APCP82/xo 8xP+eEf5t/jR
bzA4VPDHggWUtq+r6hOryJKktx4nvJpoHUMA0Mrzl4SVd1YxspZWKtkHFTJ4 d8Appupacv2L
7Pqmnf2bfA37FriDdMxDsX3F2a5nZpM72aQszE812nmJ/wA8I/zb/GjzE/54 R/m3+NP5gcXd
+H/A1z9s3XQi+1XAuj9n1iaHyJvn3SwbJB9nd/Mk3tFsMnmPv3bjmHRPCvw9 0a9tL2waAXVp
J5sU02qyzPvJuiWZpJGLkm+uiS2STLz91cd15if88I/zb/GjzE/54R/m3+NH zA4W68K/D25b
MjQKryTSTxxarLGl2JZpJ5EuEWQLPGZJZT5coZAJXAUBmBuXWk+EJ9I/spNT ks7U3s18RY63
PaOZpZJJJCZIpVchnldtuduSMDgY67zE/wCeEf5t/jR5if8APCP82/xo+YGR Y3ugWNlBZWV3
plra28axQwwyIiRIowqqo4AAAAA4AFTf2vpP/QTsv+/6/wCNaPmJ/wA8I/zb /GjzE/54R/m3
+NKwGVFqOhxPK8V9pyPM++VllQF22hctzycKoyewA7VHcX1ldahpsdteW87i 4YlY5QxA8qTn
ANbPmJ/zwj/Nv8aprO76vcQ4VY0giZVHqWkBPr/CPyosMiuv+Q/4f/6/3/8A SWeutrkrr/kP
+H/+v9//AElnrra6KfwkS3CiiirJCiiigAooooA4v43f8ky1T/rpbf8ApRHX k/wj0XUvE0Hi
F28V6npsNhq4tIILax0+RQn2S2lJLT20j5LSt/FjpgCvWPjd/wAky1T/AK6W 3/pRHXA/s4/8
eHjH/sYh/wCm+yrvqu2Wf9v/APtph/y/+X6m7/wr+9/6H7X/APwV6N/8g0f8 K/vf+h+1/wD8
Fejf/INdxRXh8zOg4f8A4V/e/wDQ/a//AOCvRv8A5Bo/4V/e/wDQ/a//AOCv Rv8A5BruKKOZ
gcP/AMK/vf8Aoftf/wDBXo3/AMg0f8K/vf8Aoftf/wDBXo3/AMg13FFHMwPP te+D/g3xTptn
ZeOILnxUbGaaW0munW0eHzVjDqBZLAjA+UpyyluvOOBS174K+GtY1y/1e4uo 1mvrmS5kH/CO
aJJhnYsfnksWduT1dmY9SScmvTqKfPLuB5J/woTwp/z9x/8AhL6B/wDK+j/h QnhT/n7j/wDC
X0D/AOV9et0Ue0l3A8k/4UJ4U/5+4/8Awl9A/wDlfXRQ/CnwZYa9rviPQLCX Q/EGu+Z9u1O3
lM8jeZOk8mIrnzYBudB/yz4H3cV3NFHPLuBw/wDwr+9/6H7X/wDwV6N/8g0f 8K/vf+h+1/8A
8Fejf/INdxRS5mBw/wDwr+9/6H7X/wDwV6N/8g0f8K/vf+h+1/8A8Fejf/IN dxRRzMDh/wDh
X97/AND9r/8A4K9G/wDkGj/hX97/AND9r/8A4K9G/wDkGu4oo5mBw/8Awr+9 /wCh+1//AMFe
jf8AyDR/wr+9/wCh+1//AMFejf8AyDXcUUczA4f/AIV/e/8AQ/a//wCCvRv/ AJBo/wCFf3v/
AEP2v/8Agr0b/wCQa7iijmYHD/8ACv73/oftf/8ABXo3/wAg0f8ACv73/oft f/8ABXo3/wAg
13FFHMwOH/4V/e/9D9r/AP4K9G/+QaP+Ff3v/Q/a/wD+CvRv/kGu4oo5mBw/ /Cv73/oftf8A
/BXo3/yDR/wr+9/6H7X/APwV6N/8g13FFHMwOH/4V/e/9D9r/wD4K9G/+QaP +Ff3v/Q/a/8A
+CvRv/kGu4oo5mBw/wDwr+9/6H7X/wDwV6N/8g0f8K/vf+h+1/8A8Fejf/IN dxRRzMDh/wDh
13FFHMwPAPi1Yap4c17SdIbxPqOq2Op2N5czQ3VpZRBZLdoFjZfs8ERzi5lB znOR6Cve/hn/
AMk48Mf9gi0/9EpXiv7Rn/I6+FP+wTq3/oyxr2r4Z/8AJOPDH/YItP8A0Sle 69ctp/4mYr+K
zoaKKK881CiiigDhbv8A5Atn/wBhiL/04iu6rhbv/kC2f/YYi/8ATiK7qop7 FSCiiirJCqUn
ntqEyW88aMIUOHUuBnzADtDjHOOcDIBGT/BdqvG2dTnTdnEMZ27umWfnG7jp 12jOOrYwqAHS
+O7ZcWw67cwMcfexn5+eqfXa3TcNtXxXFf3HhbVoNLMgv5LKZLUxybGEpQhM NkbTuxzkYrSo
oaurF05uElJdDiPhtY69a6tq0up2WuWdlJbWa28Wqaqt6xlUS+cylXbaDlPT OM4H3V7eiilG
PKrIqvWdabnLdnkH7UttqNz4UsbfSm1OS7votX08WdpNLtuxJouoOI2hQ7ZW 8yKIrlSQR8uM
nOL46+H/AIo0W9stS8JrNe6jY319D4XRAsiaXbvpOovGmHURwqbudIQOI/Kg skPKc+za1d6B
pU0Or61c6ZYyxxTQw3d3IkbKmzzpUV2xhdkHmMAcYh3HhMgTxDoEk2lQprmm NLrMTTaWgu0L
XyKgdnhGf3ihCGJXIAIPSqMjxPwzofiXUL/SNOm13xnfeHp9bj+1MttrGkNG FsL9nzLdXT3m
wyCzzlkh3CMJudpQDVNT8baL4U8cQXcfjOWa70S90zwybWyvLuVZ7e91SOFt 0Ss0bmB7AieU
qZQFbe5ViPf6KAPP/DqW0Hx78YPb6Re232zRNL828/suaO3up4ZLvf8A6QUE cjrHNbDhicDa
P9WwXp7P/keNU/5DX/INs/8AW/8AHh/rbr/U/wDTb/nr/s/Z6mt/EOgXPiK5 8OW+uaZNrVrE
JrjTo7tGuYUO0h3iB3KvzpyRj5l9RWnQB4N4qk1p9V8WaNBe+IItLi8UtJ9v h/tbUZLRjpth
KtssNjPHcLE7XFxIDv8AJjMe3bl49u14Oh+Id+vha31i71OOLW7HTdc1i4lE kM9ncW0EQubQ
AKEhWaZbQ+Tt+ZTqOdp2CvUtK/sqP7XZ6X9iT7Pcv9qhtto8qeTEz71Xo7ea JDnk+YGP3sm7
QB4B4fu/FsnizUm1AeM7eC/024urzT7HT9SD6dqQurX7NBDdXcr2021pJ13Q iK1dEZpVMONn
pngnUNVs9PtLfxBZa1ca7fak9vqcixM9pbzi3aXzIiTtSyKxokZXJ3Ogl/fm Y12dFAHgGh/8
LCh0/wDtHR/7a1S9s9Sg36lqX9qW0erzT291bjfplxzbQwz3NrNL5P7oxozp taIRJS8caf8A
FOx0rUrewvfE1z/ZltNpFrJaS3LzXXk6Vq8sN2SB87v9o01HkGN11CwAGyMn 6MqG4u7W2mto
bi5hhlupTDbpJIFaZwjOUQH7zbEdsDnCsegNAHj/AIm0zWNC8TyaPbSeM5fA 6/YLnUngvdQv
Lv501JZBDOrPdnE0Wm7o4W+VTkgI8pba+D/iRI/BMSzQ+Jr62Fzr08V3c29z cyxW9rqUkccE
vmZuDMY2UJGylyInGMrg9/rek6VrmlzaXremWWp2E+3zbW8gWaKTawYbkYEH DAEZHUA1PYWl
rYWNvY2NtDa2ltEsMEEMYSOJFGFRVHCqAAABwAKAPCvDCzXHx613XDZ3ttZa zKl1Y/bLWS2l
kiSyht2ZopVWRP3kEoAdVJChhlWUn0rwp/yA7n/sJXX/AKUTVyj+IdA8S/F2 wvvDmuaZrNpH
pxheewu0uI1cGUlCyEgNhlOOuCPWur8Kf8gO5/7CV1/6UTVjU3LRV8IW8txp XhNIb24s2GjT
HfCqFiN1vx86sMfhnik8Y2dxbeJfCLTareXgOozALMsQC/6HPyNiKaqafo/i zTxZR2XiTSli
srdraAPpDsRGxQ/MfPGT8i84HfirJ0zxBe6tpt5rmt2F3Hp8zzxR22nNAxdo nj5YyvxhycY6
gc+sXVrCSZ5R+03/AMIzqFtN9g/se78UaZp2p/b/ACPLe+tLI6Nf483H7xIT JNF97C7pE7sM
6/8AwjOt+Dr7QtM0S78IaE3iDWVtLqfQPCqWTGFLG9lYMHmlDuCilGIwjDLL IpZD69RS5irH
z98Svib4j0jxBrg0jXrO3xb6pBFpV1e273tm9tYXMyXItBbiREeS2V1eSaVW jmU7B5i+Xr67
4p8beHLnVk0/VbzxFc2Go3OkWlpd2cLG6ddFfUo5GW3jjZpjLthAQqpjwNnm fvK9qop3XYLH
nPwV1zW9Y/tZNS8S6P4js4PJNvd2F+l9tkbzPMjaeG1t4eAsZEYVpF3Eudrx ivRqKKljCiii
gAooooAKKKKACqUP/Iduv+vaH/0KWrtUof8AkO3X/XtD/wChS0AF1/yH/D// AF/v/wCks9db
XJXX/If8P/8AX+//AKSz11tdFP4SJbhRRRVkhRRRQAUUUUAcX8bv+SZap/10 tv8A0ojrgf2c
f+PDxj/2MQ/9N9lXffG7/kmWqf8AXS2/9KI64H9nH/jw8Y/9jEP/AE32Vd9b /kV/9v8A/tph
/wAv/l+p6rRRRXhHSFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQA UUUUAFFFFABR
RRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAHiP7Rn/I6+FP8A sE6t/wCjLGva
vhn/AMk48Mf9gi0/9EpXiv7Rn/I6+FP+wTq3/oyxr2r4Z/8AJOPDH/YItP8A 0Sle9/zLaf8A
iZgv4rOhooorzzUKKKKAOFu/+QLZ/wDYYi/9OIruq4W7/wCQLZ/9hiL/ANOI ruqinsVIKKKK
skKpSee2oTJbzxowhQ4dS4GfMAO0OMc45wMgEZP8F2q8bZ1OdN2cQxnbu6ZZ +cbuOnXaM46t
jCoAdL47tlxbDrtzAxx97Gfn56p9drdNw21fFcV/ceFtWg0syC/kspktTHJs YSlCEw2RtO7H
ORitKihq6sXTm4SUl0OI+G1jr1rq2rS6nZa5Z2UltZrbxapqq3rGVRL5zKVd toOU9M4zgfdX
t6KKUY8qsiq9Z1puct2eQftS22o3PhSxt9KbU5Lu+i1fTxZ2k0u27Emi6g4j aFDtlbzIoiuV
JBHy4yc4vjr4f+KNFvbLUvCazXuo2N9fQ+F0QLIml276TqLxph1EcKm7nSED iPyoLJDynPub
2lq99FfPbQtdwxPDFOYwZERypdA3UKxjQkDglFz0FTVRkeAeGdD8S6hf6Rp0 2u+M77w9Prcf
2plttY0howthfs+Zbq6e82GQWecskO4RhNztKAapqfjbRfCnjiC7j8ZyzXei XumeGTa2V5dy
rPb3uqRwtuiVmjcwPYETylTKArb3KsR7NqvizwrpOh2mu6p4l0Ww0m82fZb6 5voo7efepdNk
jMFbcoLDBOQCRxRqvizwrpOuWmhap4l0Ww1a82fZbG5voo7ifexRNkbMGbcw KjAOSCBzQBxm
hX+nax8Q47S50PWtJi0fUrx9KtB4fu4beS6ImWe+luREID5gkn8tQ5VhKXct JIiQ9nZ/8jxq
n/Ia/wCQbZ/63/jw/wBbdf6n/pt/z1/2fs9bNQvd2qX0Vi9zCt3NE80UBkAk dEKh3C9SqmRA
SOAXXPUUAeGeKpNafVfFmjQXviCLS4vFLSfb4f7W1GS0Y6bYSrbLDYzx3CxO 1xcSA7/JjMe3
bl49u14Oh+Id+vha31i71OOLW7HTdc1i4lEkM9ncW0EQubQAKEhWaZbQ+Tt+ ZTqOdp2CvWbK
0tbKFobO2htomlkmZIowil5HLu5A/iZ2ZiepLEnk0Pd2qX0Vi9zCt3NE80UB kAkdEKh3C9Sq
mRASOAXXPUUAeDeH7vxbJ4s1JtQHjO3gv9NuLq80+x0/Ug+nakLq1+zQQ3V3 K9tNtaSdd0Ii
tXRGaVTDjZ6Z4J1DVbPT7S38QWWtXGu32pPb6nIsTPaW84t2l8yIk7UsisaJ GVydzoJf35mN
bXhjxZ4V8UfaP+EZ8S6Lrf2bb9o/s6+iuPK3Z27tjHbna2M9cH0rZoA8A0P/ AIWFDp/9o6P/
AG1ql7Z6lBv1LUv7Uto9Xmnt7q3G/TLjm2hhnubWaXyf3RjRnTa0QiSl440/ 4p2Olalb2F74
muf7MtptItZLSW5ea68nStXlhuyQPnd/tGmo8gxuuoWAA2Rk/RlY1r4p0K51 RNOhvt00lzPa
RMYnEUs8KhpYklI2O6gtlVYnMUwxmGUIAeZeJtM1jQvE8mj20njOXwOv2C51 J4L3ULy7+dNS
WQQzqz3ZxNFpu6OFvlU5ICPKW2vg/wCJEj8ExLND4mvrYXOvTxXdzb3NzLFb 2upSRxwS+Zm4
MxjZQkbKXIicYyuD3+t6TpWuaXNpet6ZZanYT7fNtbyBZopNrBhuRgQcMARk dQDU9haWthY2
9jY20NraW0SwwQQxhI4kUYVFUcKoAAAHAAoA8K8MLNcfHrXdcNne21lrMqXV j9stZLaWSJLK
G3ZmilVZE/eQSgB1UkKGGVZSfSvCn/IDuf8AsJXX/pRNWR4m/wCS16b/ANgn /wBmmrX8Kf8A
IDuf+wldf+lE1Y1Ny0V/B/hy11Twtpmo3eoaybi4tkkkK6nMoLEcnAbiotf0 xNC8QeG1sb7U
mW8vpYZ1nvZJVZBbTOBhiR95VOevFN8JeLrDSPDOnaZeaZ4hFza26RShNFun UMBzhgmD9RxU
es63B4i8R+Gxp+n6wgsr2Wad7rTZ7dFQ20yA7pFAPzMoxnPP1qXbl8yUc78a vFvibwVZw6xp
UmjzWL296ptbmykaXzodPvLtX81ZVGwm3RSmzOCx3DjEOj/ElbbSNe1PUdW0 LxNpulR2sg1f
RJIbS1keaR42tt1xctEJI9sbsTMCVnQbQdu/d8YeArTxY97HreuaxPYz280M FinkJFZvLbPb
PLGwi8wv5csoxI7rmQnbwu3Y8U6DDr1vaf6deadeWNx9psr208sy28vlvGWU SK8bZjlkQh1Y
YckYYKROhZyFt8YNBvLR9Q0/SdYv9LttOXUdR1C3a2aCwh824icufO3S7GtZ 8mAShggKF9y5
x/HXxo0GGw8W6LoV/wCTrmn6dqQsrjzraTN5awSuy+R5jTLsMUh3SxLG3l8M wdN/R6f8L9Gt
dC8Q6VLqusXn/CQadLYX9zM8IlZZZ7yZ5F2RqiuXvpv4doAT5eDmbUvh1YX1 lrGmSa9rsWj6
pHehtNhmiSGGS7Ennyqwj8xyWmlcLK7xhnyEGxNr0DU7WiiipGFFFFABRRRQ AUUUUAFUof8A
kO3X/XtD/wChS1dqlD/yHbr/AK9of/QpaAC6/wCQ/wCH/wDr/f8A9JZ662uS uv8AkP8Ah/8A
6/3/APSWeutrop/CRLcKKKKskKKKKACiiigDi/jd/wAky1T/AK6W3/pRHXA/ s4/8eHjH/sYh
/wCm+yrvvjd/yTLVP+ult/6UR1wP7OP/AB4eMf8AsYh/6b7Ku+t/yK/+3/8A 20w/5f8Ay/U9
VooorwjpCiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gAooooAKKKKA
CiiigAooooAKKKKACiiigAooooAKKKKACiiigDxH9oz/AJHXwp/2CdW/9GWN e1fDP/knHhj/
ALBFp/6JSvFf2jP+R18Kf9gnVv8A0ZY17V8M/wDknHhj/sEWn/olK97/AJlt P/EzBfxWdDRR
RXnmoUUUUAcLd/8AIFs/+wxF/wCnEV3VcLd/8gWz/wCwxF/6cRXdVFPYqQUU UVZIVSk89tQm
S3njRhChw6lwM+YAdocY5xzgZAIyf4LtV42zqc6bs4hjO3d0yz843cdOu0Zx 1bGFQA6Xx3bL
i2HXbmBjj72M/Pz1T67W6bht5b40Xtxp/wANtUvLW8mspI2t/wB/DKY3QGeM Nhl5HBI+hrsa
KmpDng43tc3w1ZUK0KrV+Vp272d7HhHwG8QX+qfEGa1l8QX2owDSp5Gilv3n RWE0ADYZiAcF
gD6E/U+70UVlhqDoU1Byv5s3zHGLG13WUeW9tP6sef8AxT8z+3NF/tX/AISb /hF/s139r/sD
7b9o+27oPs277D/pGzy/tef+Wedu75vLry34at8QNUufB2qX3iLxAWmsdFms 1TTb66jurM2d
q108twLhLJWaQ3m43Eb3AHzJuYwCvf8AxJ4e0DxLYpY+I9D0zWbSOUTJBf2i XEauAQHCuCA2
GYZ64J9a066DhPBtNshpX7M03w9g0rxbJ4jv/D82jNbXFlqFzGuo/YkhZFmk VoobfeyhXDrb
43FGwrEdz4R1FPC2oX2g65p+tPqupa3dXSX1tpFzd29zFPcMbdnuIo2RPLhM UBEpQoIAP9UI
3bp9V8WeFdJ0O013VPEui2Gk3mz7LfXN9FHbz71LpskZgrblBYYJyASOKgsv G/gu98RN4cs/
F/h+51pZZIW06LUoXuQ8eS6GINu3LtbIxkbTnpQB4zFbeMr3StJs4m8crfTx afF4zZ5r+EC+
bUtPEptXYhUi8o6luayIhCYJIXyq2rXQb60+LllJq0Xi2Xw9o19d2Gj3CXN/ PJuuItInjEsq
MZZrcype7nmLQqU2OQFRR7ZRQB82+H9N+I1zpQg1XW/Fs99dS6XF4gt7ew1K zEM7alZi4Mdz
JcspURfbAWsEjg2bmYqohFdNa6DfWnxcspNWi8Wy+HtGvruw0e4S5v55N1xF pE8YllRjLNbm
VL3c8xaFSmxyAqKPbKxtE8U6FrVxDBpt95z3Fs13bFonRbmASGMywswAlTdt O5Cw2yRNnbLG
WAPJfB3hnxhpfwg8PazqrfadT0/wjBpFpYWmnXNpcafb3AtRcvMFmM080KwI 4SHyHYxuqgO6
FKfw50jxL4h8Tw6V4h1HxnN4csv7T+yXKNrGjeZ8mlNFvMs32l8PJfBfOkfO 2TbhVCr7/RQB
88+Ej8T9R8S+HdS8Rav4gs9Rli0mVbRNDvDG8BtbZr0Ssk8dhCxlN6GWeJp1 A/dgn7Oo6DR/
m+Dvw706L/kZV1vT7aVhxL/aNvcFtXJl6FzHBqXmSbv3oMgBfzQH9mqlFpOl Q6pJqkWmWUd/
Ju8y6WBRK+5YlbL4ycrBCDzyIox/CMAF2iiigDzfxN/yWvTf+wT/AOzTVr+F P+QHc/8AYSuv
/SiasjxN/wAlr03/ALBP/s01a/hT/kB3P/YSuv8A0omrGpuWivpV54k1TTbb UbPQrE29zGJI
y+pFW2kZGR5XBqvb+IL0arZ2N7paw/arh7cPHJK6q6i4J+YxLG3NtJkK5YAo SoDCl8EeK7S0
8N6ZpQsrm5uYLVFkFvLA+0+XG/zDzMoSksbAMAcODiudiltLjxlo8i2sMF22 r3M77niM3lvH
ehdyqxcAmNwCRtJiYAnFZNpNJb/kJNnS674u0DQtXttM1i7msZLmN5I55rSZ bXCRySuGudvk
oRHDI5VnB2rnGCMzeG/Een6/5/2G31iHyNu/7fpF1ZZ3Zxt8+NN/Q525xxnG Rnm/HVnqGveI
NMtH8I3l5pejXE97cPO9q0GpRvYXMBtokaXcXZrkDEqxx4V8t93dy0/hnX7t Vebwvrt34Wgv
YJrjw1reqQ6hdXpEN2kjbpriSJo98ti6xyTABrZ2ChtvmOyKPZK5zxX4x0zw 3q2maZfQXkk2
o7fJaFFKrm7tLX5ssCPnvYjwD8queoAPCf8ACBXD2Hiq/tfDH2KW+1HTXtdO aWIbtMig077T
ZIiuYU8wW8sDJlUk2Rh2MaowyJPAXiOXXrC+0zwx/ZGjJqKT2ulebbp/ZsIv tEkdNkbmNdxs
r2fEbMDuycO5WmkgPUvCPjfw54r8v+xrm8bzrcXVv9r064tPtMJ2/vYfORPN Qb0yybgN6Zxu
XPR15D4d+H2u6X8KNMhu7m81bX4PDsGlNY3q2bpZ28ggF7bQBY1ikdkiCobg yJujj3NsaTdk
fD74YyzeJIU8VeD/ALR4atP7S/s+01y306T7N5qaXs2wWuYI90kN6R5ajqxb 5pCWLID3WivB
PC3w98XjxFoGreJYtdudYij0uQ363WnslosNtbrcwS3MiPeAvLHclkgJilE2 Cy+bKw97pNWA
KKKKQwooooAKpQ/8h26/69of/Qpau1Sh/wCQ7df9e0P/AKFLQAXX/If8P/8A X+//AKSz11tc
ldf8h/w//wBf7/8ApLPXW10U/hIluFFFFWSFFFFABRRRQBxfxu/5Jlqn/XS2 /wDSiOuB/Zx/
48PGP/YxD/032Vd98bv+SZap/wBdLb/0ojrgf2cf+PDxj/2MQ/8ATfZV31v+ RX/2/wD+2mH/
AC/+X6nqtFFFeEdIUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAFFF
FABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAeI/tGf8jr4U/wCw Tq3/AKMsa9q+
Gf8AyTjwx/2CLT/0SleK/tGf8jr4U/7BOrf+jLGvavhn/wAk48Mf9gi0/wDR KV73/Mtp/wCJ
mC/is6GiiivPNQooooA4W7/5Atn/ANhiL/04iu6rhbv/AJAtn/2GIv8A04iu 6qKexUgoooqy
QqlJ57ahMlvPGjCFDh1LgZ8wA7Q4xzjnAyARk/wXarxtnU503ZxDGdu7pln5 xu46ddozjq2M
KgB0vju2XFsOu3MDHH3sZ+fnqn12t03Dby3xovbjT/htql5a3k1lJG1v+/hl MboDPGGwy8jg
kfQ12NFTUhzwcb2ub4asqFaFVq/K07d7O9jwj4DeIL/VPiDNay+IL7UYBpU8 jRS37zorCaAB
sMxAOCwB9Cfqfd6KKyw1B0Kag5X82b5jjFja7rKPLe2n9WPP/in5n9uaL/av /CTf8Iv9mu/t
f9gfbftH23dB9m3fYf8ASNnl/a8/8s87d3zeXXlvw1b4gapc+DtUvvEXiAtN Y6LNZqmm311H
dWZs7Vrp5bgXCWSs0hvNxuI3uAPmTcxgFe/+JPD2geJbFLHxHoemazaRyiZI L+0S4jVwCA4V
wQGwzDPXBPrWnXQcJ4NptkNK/Zmm+HsGleLZPEd/4fm0Zra4stQuY11H7EkL Is0itFDb72UK
4dbfG4o2FYi6fDfjCy+FfjnUdO8R+Lba+aXxNNp+iwW1uil5Lm9MDxEQfadz FklQrLkllI+U
gV6nqvizwrpOh2mu6p4l0Ww0m82fZb65voo7efepdNkjMFbcoLDBOQCRxUGp +N/Bel31/Y6n
4v8AD9ld6dEs19BcalDHJaoxQK8iswKKTJGAWwCXX+8KAPLPjhH4t0bS4rbw 7e+JmvNM02a8
07UIrTUtSl1TUHZ2aKRLORIYtrJEQLiN4CJ9iRqkToaer6Z42gsNa1Gyk8Zm /Nt4p1O3UXt4
6/bbW/26UqRFimxoZH2wBfLmUAskmxSPcv7W0r+3P7C/tOy/tb7N9r+w+ev2 jyN2zzfLzu2b
vl3YxnjOau0AfPOsab8T73WfFsdjrfiBdani1mK3s4bC8hgEDR3C2BW8kuRY o3Nmwa3iE4bh
yP8ASHr0Ca50bUtd+Fsvg9YUtJIp763FtD9nUaN9hZCoBC4i86bTv3PXIjbb +7JX0auZ8E6t
4B1i4v7jwVqfhnUJl2/bpNInglYb5JZV8wxEn5pJJ3G7qzyHqWNAHTUUVjWv inQrnVE06G+3
TSXM9pExicRSzwqGliSUjY7qC2VVicxTDGYZQgBs0UUUAFFFFAHm/ib/AJLX pv8A2Cf/AGaa
tfwp/wAgO5/7CV1/6UTVkeJv+S16b/2Cf/Zpq1/Cn/IDuf8AsJXX/pRNWNTc tHOyWPgUsgbx
A6+SpSNB4kuFES8ZVVE2FHA4GBwPSruiWnhMahb/ANnar9ruIWZ4IW1mW5CM VYM6xtIw3EM+
Wxn5m55NKYYf+FMafN5UfmfZ7T59o3f62Mda0fHcMMPiHwh5UUcedTmztUDP +h3FZ6/15iTN
SivP/ijYX7+JfCk+i67qWkalqF7c6asyXMslugOm30iO1qXEMhWVY3yy5OxR nArm7LUfEHh/
xFaeENOih0vXtSvbcTzahrOoeILVLV7bUJUaPz5IXWQvZSKwGF2lDlzwpYq5 7JRXzN488Z6y
134k1COT7JqX9jTadJcWc00GJbOLxKvnxhXyu57VXCOZAm4clkWQdf4pt/Gl 5471PSoptY1H
XIPDtlJYXukXr6fplhdyXF+EnuLV7o+YnyQ7htn3CJvlwQhfKFz2qivG/Hnx R8S6DcatqGma
XDe6CsepW1hdTWaxot5Z2lzLIGcXRllAltJoyvkRAjkSEKpkueJfG/jjQdXH hJLXTdc165kt
Da3VjYeSipNHfSFTbzXShyo09+ftCAiUEDMe2RcoXPWKKwvAOralrXhW2v8A WLOGz1DzJoLi
GKaOQB4pniJ/dySKhOzJjDuYyShZipJ3aQwooooAKKKKACqUP/Iduv8Ar2h/ 9Clq7VKH/kO3
X/XtD/6FLQAXX/If8P8A/X+//pLPXW1yV1/yH/D/AP1/v/6Sz11tdFP4SJbh RRRVkhRRRQAU
UUUAcX8bv+SZap/10tv/AEojrgf2cf8Ajw8Y/wDYxD/032Vd98bv+SZap/10 tv8A0ojrgf2c
f+PDxj/2MQ/9N9lXfW/5Ff8A2/8A+2mH/L/5fqeq0UUV4R0hRRRQAUUUUAFF FFABRRRQAUUU
UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQ AUUUUAFFFFAB
RRRQB4j+0Z/yOvhT/sE6t/6Msa9q+Gf/ACTjwx/2CLT/ANEpXiv7Rn/I6+FP +wTq3/oyxr2r
4Z/8k48Mf9gi0/8ARKV73/Mtp/4mYL+KzoaKKK881CiiigDhbv8A5Atn/wBh iL/04iu6rhbv
/kC2f/YYi/8ATiK7qop7FSCiiirJCqUnntqEyW88aMIUOHUuBnzADtDjHOOc DIBGT/BdqvG2
dTnTdnEMZ27umWfnG7jp12jOOrYwqAHS+O7ZcWw67cwMcfexn5+eqfXa3TcN vLfGi9uNP+G2
qXlreTWUkbW/7+GUxugM8YbDLyOCR9DXY0VNSHPBxva5vhqyoVoVWr8rTt3s 72PCPgN4gv8A
VPiDNay+IL7UYBpU8jRS37zorCaABsMxAOCwB9Cfqfd6KKyw1B0Kag5X82b5 jjFja7rKPLe2
n9WPP/in5n9uaL/av/CTf8Iv9mu/tf8AYH237R9t3QfZt32H/SNnl/a8/wDL PO3d83l15b8N
W+IGqXPg7VL7xF4gLTWOizWappt9dR3VmbO1a6eW4FwlkrNIbzcbiN7gD5k3 MYBXv/iTw9oH
iWxSx8R6Hpms2kcomSC/tEuI1cAgOFcEBsMwz1wT61p10HCeDabZDSv2Zpvh 7BpXi2TxHf8A
h+bRmtriy1C5jXUfsSQsizSK0UNvvZQrh1t8bijYViLvxgsW8b+K9Mhs/D2p 6jp2mSxWGqpd
6RPHDIJNa0lyFEqBbiLyrW4Znj3oFTLEBlz6nqvizwrpOh2mu6p4l0Ww0m82 fZb65voo7efe
pdNkjMFbcoLDBOQCRxRN4s8KwaXqGqTeJdFisNMuTaX9099EIrScMqmKVy2E cMyjaxBywGOR
QB4l4p8D+NNA1O3vtNvtT1DWJNIvLO61jbNeSxafHf6VGiF02StKbOK4maON lkaeS6aAqzLj
T8E+HNf1jXNHsNc1nxnd+H1ttUmhmR9U0bDBtOESuXuWum+Y3pX7S+45k2L5 axmvc6KAPBvD
+ueOl8K2Vn4ig8W/8JHrOr+HL5Gj0y6McduU0wXqu8SeVbLvivt8LlOC5K4c bsb4eWviW08F
aI1vZ+LdTuNN8G/2ZejVtKnsJNFeVrJJEtBFFby3Kqkc8hEbSyk2kSpLG0oM nv8ArWvaZpE0
MF5LM1xPFNNFb21tJcTOkSb5HEcSsxUfKucYLPGgy0iK12wu7W/sbe+sbmG6 tLmJZoJ4ZA8c
qMMq6sOGUgggjgg0AeGfCq08Zal41sbTVNY8Wt4d02XUXglks7/T47sKukyQ pKLxnuCome8K
75CWEciA+TuirT0f5vg78O9Oi/5GVdb0+2lYcS/2jb3BbVyZehcxwal5km79 6DIAX80B/Zqp
RaTpUOqSapFpllHfybvMulgUSvuWJWy+MnKwQg88iKMfwjABdooooAKKKKAP N/E3/Ja9N/7B
P/s01a/hT/kB3P8A2Err/wBKJqyPE3/Ja9N/7BP/ALNNWv4U/wCQHc/9hK6/ 9KJqxqblowJb
Txn/AMIlD4bj07QGggSJFnbUpg7CNlYEr5BAzt6ZOM960LmPxPrGtaPc6vZa PZ2+m3Elxm1v
ZJnctDJFtw0Sgf6zOc9unPEun2GvaxoMWv2OtSQzXcfmQ2BjiECoRwNxQvvx zuJK7v4McVWs
5/EOi6lYafrqC4i1GdobeZrlJJUdYpJDu2RRqVxHgcAgnvniGnuJWLs3hbwz NqV/qc3hzR5L
7Ubc2t9cvZRmW6hKhTFI5GXQhVG1iRhQO1Y9/wDDPwLd2Gn6Z/wi+j2+l2Wo nUf7OgsIVtbi
YwSQZli2bWwsmc4ByiHPGKm8WeIdd0fxFounWWiabeWuryS2sM82pPC6XS21 xOqsggceWRAF
LhiwL/cOOafhLxlqt94d1LXfEWgQ6fa2l7PZomlT3GqTSvDcyW0h8pLZXxvj yNoYlSSwTBpa
lHSW2gaFbS2s1voumwyWcccVq8dqimBI0kSNUIHyhVllVQOAJHA4Y5ND0DQt CiEOiaLpulxi
MRBLO1SEbA7uFwoHAaWRgOmXY9WOeQT4oaKni66sriaYaOulWl5FeR6bcsLd 3nu4pxdOEK2w
j+zqG87yyhEu4/KQsvhP4j6TfJfw67cf2XcWmo6nb+dPZz29m8VrczoNtxIv lO4hh3sFckbJ
DgBGClmBvX3gzwffavPrF74U0K61K4jaKa8m0+J5pUaPymVnK7iDGShBOCpx 04q5q2gaFq8V
1Dq2i6bqEd3HHFcpdWqSiZI3Lxq4YHcFZmZQeAWJHJrHT4geGGspbhp9Sikj kSP7FLpF3Hey
FwxUpatEJ5ARHKQyoRiKU5xG+3itM+Les3VjrWpr4bs59L0O3udR1CaS6mtL lbSO+v4FEds8
LFphFYlisjxZdsHZzgswPWLG1tbGygsrK2htbW3jWKGGFAiRIowqqo4AAAAA 4AFTVzmt+N/D
miXd9b6vc3lj9it5LmWafTrhYHSOIzOIpSnlzOI1ZtkbM2Efj5GxCnxA8MNZ S3DT6lFJHIkf
2KXSLuO9kLhipS1aITyAiOUhlQjEUpziN9qsxnU0VT0bU7HWNNi1HTp/Ot5c gEoyMrKxVkdW
AZHVgysjAMrKVIBBFXKACiiigAqlD/yHbr/r2h/9Clq7VKH/AJDt1/17Q/8A oUtABdf8h/w/
/wBf7/8ApLPXW1yV1/yH/D//AF/v/wCks9dbXRT+EiW4UUUVZIUUUUAFFFFA HF/G7/kmWqf9
dLb/ANKI64H9nH/jw8Y/9jEP/TfZV6h8SdEvfEXgy+0fTnt0upzE0ZnYrHlJ Uc5IBPRT2NeG
ah+z5rWo3j3l/pPga6uZMb5Zg7u2BgZJgycAAfhXq0oUq+C9jKoovmvr6WMJ c0avMlfQ94or
5/8A+Gb77/oX/h//AN+m/wDjFH/DN99/0L/w/wD+/Tf/ABiuf+yaP/P+JXtZ fyn0BRXz/wD8
M333/Qv/AA//AO/Tf/GKP+Gb77/oX/h//wB+m/8AjFH9k0f+f8Q9rL+U+gKK +f8A/hm++/6F
/wCH/wD36b/4xR/wzfff9C/8P/8Av03/AMYo/smj/wA/4h7WX8p9AUV8/wD/ AAzfff8AQv8A
w/8A+/Tf/GKP+Gb77/oX/h//AN+m/wDjFH9k0f8An/EPay/lPoCivn//AIZv vv8AoX/h/wD9
+m/+MUf8M333/Qv/AA//AO/Tf/GKP7Jo/wDP+Ie1l/KfQFFfP/8Awzfff9C/ 8P8A/v03/wAY
o/4Zvvv+hf8Ah/8A9+m/+MUf2TR/5/xD2sv5T6Aor5//AOGb77/oX/h//wB+ m/8AjFH/AAzf
ff8AQv8Aw/8A+/Tf/GKP7Jo/8/4h7WX8p9AUV8//APDN99/0L/w//wC/Tf8A xij/AIZvvv8A
oX/h/wD9+m/+MUf2TR/5/wAQ9rL+U+gKK+f/APhm++/6F/4f/wDfpv8A4xR/ wzfff9C/8P8A
/v03/wAYo/smj/z/AIh7WX8p9AUV8/8A/DN99/0L/wAP/wDv03/xij/hm++/ 6F/4f/8Afpv/
AIxR/ZNH/n/EPay/lPoCivn/AP4Zvvv+hf8Ah/8A9+m/+MUf8M333/Qv/D// AL9N/wDGKP7J
o/8AP+Ie1l/KfQFFfP8A/wAM333/AEL/AMP/APv03/xij/hm++/6F/4f/wDf pv8A4xR/ZNH/
AJ/xD2sv5T6Aor5//wCGb77/AKF/4f8A/fpv/jFH/DN99/0L/wAP/wDv03/x ij+yaP8Az/iH
tZfyn0BRXz//AMM333/Qv/D/AP79N/8AGKP+Gb77/oX/AIf/APfpv/jFH9k0 f+f8Q9rL+U+g
KK+f/wDhm++/6F/4f/8Afpv/AIxR/wAM333/AEL/AMP/APv03/xij+yaP/P+ Ie1l/KfQFFfP
/wDwzfff9C/8P/8Av03/AMYo/wCGb77/AKF/4f8A/fpv/jFH9k0f+f8AEPay /lPoCivn/wD4
Zvvv+hf+H/8A36b/AOMUf8M333/Qv/D/AP79N/8AGKP7Jo/8/wCIe1l/KfQF FfP/APwzfff9
C/8AD/8A79N/8Yo/4Zvvv+hf+H//AH6b/wCMUf2TR/5/xD2sv5T6Aor5/wD+ Gb77/oX/AIf/
APfpv/jFH/DN99/0L/w//wC/Tf8Axij+yaP/AD/iHtZfyn0BRXz/AP8ADN99 /wBC/wDD/wD7
9N/8Yo/4Zvvv+hf+H/8A36b/AOMUf2TR/wCf8Q9rL+U0v2jP+R18Kf8AYJ1b /wBGWNe1fDP/
AJJx4Y/7BFp/6JSvDNP+AGvabK82m6d4KsZXQxtJbF42KnBIysA4yBx7CvoD whp0+j+EtH0m
5eN57KwgtpWjJKlkjVSQSAcZHcCt8TGlRwkKMZqTTb0FC7m5NWNSiiivLNgo oooA4W7/AOQL
Z/8AYYi/9OIruq4W7/5Atn/2GIv/AE4iu6qKexUgoooqyQqlJ57ahMlvPGjC FDh1LgZ8wA7Q
4xzjnAyARk/wXarxtnU503ZxDGdu7pln5xu46ddozjq2MKgB0vju2XFsOu3M DHH3sZ+fnqn1
2t03Dby3xovbjT/htql5a3k1lJG1v+/hlMboDPGGwy8jgkfQ12NFTUhzwcb2 ub4asqFaFVq/
K07d7O9jwj4DeIL/AFT4gzWsviC+1GAaVPI0Ut+86KwmgAbDMQDgsAfQn6n3 eiissNQdCmoO
V/Nm+Y4xY2u6yjy3tp/Vjz/4p+Z/bmi/2r/wk3/CL/Zrv7X/AGB9t+0fbd0H 2bd9h/0jZ5f2
vP8Ayzzt3fN5deW/DVviBqlz4O1S+8ReIC01jos1mqabfXUd1ZmztWunluBc JZKzSG83G4je
4A+ZNzGAV7/4k8PaB4lsUsfEeh6ZrNpHKJkgv7RLiNXAIDhXBAbDMM9cE+ta ddBwng2m2Q0r
9mab4ewaV4tk8R3/AIfm0Zra4stQuY11H7EkLIs0itFDb72UK4dbfG4o2FYj M8S/DTVb/wCH
Pja4jtL0Q3v/AAkt3Po4jbdfXy3V8LCUQbMS745w+45YtbWBQ4j59z1XxZ4V 0nQ7TXdU8S6L
YaTebPst9c30UdvPvUumyRmCtuUFhgnIBI4om8WeFYNL1DVJvEuixWGmXJtL +6e+iEVpOGVT
FK5bCOGZRtYg5YDHIoA8M8TW3xL+2eNLi31nxN/a32bW/KsrLSr/AGfZvJuR YeXcG4+yb/8A
jzZfssP2jfhW589q63U7bXfCXxBtV09vFtz4P0+WyvrzM17qcjmW31WCVQWM k0yiQaeTCu4I
dsm1cs9ev0UAeQfB+51G48f3t54gXUxLqNjfS6EuqQypOlums3pmCpKA8KmG fSvlYLuUQgAi
L5Os+CnzfDmxni/48Lm5vLnSgOFGnS3UslkEX+BBbNCFjwNi4XC7cDoNftNA v1tbHX7bTLpb
mWSG1gvY0cSu0EodEV/vMYTMCByUMmfl3VDdeKdCttUfTpr7bNHcwWkrCJzF FPMpaKJ5QNiO
wC4VmBzLCMZmiDgGzRRRQAUUUUAFFFFAHm/ib/ktem/9gn/2aatfwp/yA7n/ ALCV1/6UTVke
Jv8Aktem/wDYJ/8AZpqmTUpNG+H2u6xFam7ksZdQuVgBIMpSWdgmQrEZxjhS eeh6VlKLlKyK
Ww7wT448Had4R0qxvvE+k291BaoksUl0gZGA5UjPBHpUPiHxL4f8QeJ/CsOh 6zYajJBfzSSp
bTq7In2SddxA6DJAz6keteWyfHbxWkyovwqvpFKKxdX1DaCVBK82AOVJIPGM g4JGCfWfh54h
m8VeELLXbnTW0ya4Mqvas7MYykrxkZZEb+HOCqkZwRW+JweIw8F7VWT80/yb IhOMnZfkyO/0
DU9S8X6fql/qtmdL0q4N3YWcFkyTiY28kBMsxlZXTbNKdqxoclPmO0hsfVPh 99r8IHQv7Qs5
8azear5d/YfaLK4+0XE83k3FvvXzUTz8r86/vIo5P4dtdJqvinwzpOpDTNV8 R6PYXxt3uhbX
N7HFKYUVmaXYxB2AI5LYwAjHsam8Pa/oXiKye98P61pur2qSGJ5rG6SdFcAE qWQkA4ZTjrgj
1rj1NTzLSvg/qenaVqOjW/iXR4NL1nTpNO1S3t9CaLbDJdXs7C1xcbYMLfOi hllA2KcHla0r
r4W3Wq2V3omueIoZtBe91W8tobPTzBdRvfi6Vw8zSyI4VL2YDESncEJOAVb0 ys6z13SLrT21
CK/hW1W9ewMsp8sfaEuDbmP5sZPnKUH944xnIyXYWOE0j4XSaUsd9plx4W0r WLa9jurVtK8M
paWWVhnh/fQrL5spKXU3PnKARGQow4km8HfCnTNM16TX/EY0fxDqh/eQTyaS qfZJjfXl40kO
95Gj+a7VRhsjyVOTnj0aqes6ppmi6bLqes6jZ6bYw4825u51iiTLBRudiAMk gDJ6kCi7Cx5b
4v8Agv8A2/qt/df2to8H2r+0D9tfRPM1Q/a7W4g8uS784b4Y/tHyR7BhIYkz 8u473j74Z2vi
vX5dauJ9NmkEdmLe01LTBeWm+D7apaaIuvmArfPgAoVeNGywytdpo2qaZrWm xano2o2epWM2
fKubSdZYnwxU7XUkHBBBweoIq5RzMDI8G6HD4b8N2mjQCzVYN7FbOyjtIFZ3 Z2EcScIgLEAE
s2MbmdssdeiikMKKKKACqUP/ACHbr/r2h/8AQpau1Sh/5Dt1/wBe0P8A6FLQ AXX/ACH/AA//
ANf7/wDpLPXW1yV1/wAh/wAP/wDX+/8A6Sz11tdFP4SJbhRRRVkhRRRQAUUU UAFFFFABRRRQ
AUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAFF
FFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAcLd/8AIFs/+wxF /wCnEV3VcLd/
8gWz/wCwxF/6cRXdVFPYqQUUUVZIVSk89tQmS3njRhChw6lwM+YAdocY5xzg ZAIyf4LtV42z
qc6bs4hjO3d0yz843cdOu0Zx1bGFQA6Xx3bLi2HXbmBjj72M/Pz1T67W6bht 5b40Xtxp/wAN
tUvLW8mspI2t/wB/DKY3QGeMNhl5HBI+hrsaKmpDng43tc3w1ZUK0KrV+Vp2 72d7HhHwG8QX
+qfEGa1l8QX2owDSp5Gilv3nRWE0ADYZiAcFgD6E/U+70UVlhqDoU1Byv5s3 zHGLG13WUeW9
tP6sef8AxT8z+3NF/tX/AISb/hF/s139r/sD7b9o+27oPs277D/pGzy/tef+ Wedu75vLry34
at8QNUufB2qX3iLxAWmsdFms1TTb66jurM2dq108twLhLJWaQ3m43Eb3AHzJ uYwCvf8AxJ4e
0DxLYpY+I9D0zWbSOUTJBf2iXEauAQHCuCA2GYZ64J9a066DhPBtNshpX7M0 3w9g0rxbJ4jv
/D82jNbXFlqFzGuo/YkhZFmkVoobfeyhXDrb43FGwrEZniX4aarf/DnxtcR2 l6Ib3/hJbufR
xG26+vlur4WEog2Yl3xzh9xyxa2sChxHz7nqvizwrpOh2mu6p4l0Ww0m82fZ b65voo7efepd
NkjMFbcoLDBOQCRxRN4s8KwaXqGqTeJdFisNMuTaX9099EIrScMqmKVy2EcM yjaxBywGORQB
4Z4mtviX9s8aXFvrPib+1vs2t+VZWWlX+z7N5NyLDy7g3H2Tf/x5sv2WH7Rv wrc+e1dbqdtr
vhL4g2q6e3i258H6fLZX15ma91ORzLb6rBKoLGSaZRINPJhXcEO2TauWevX6 KAPE7Ka4u774
ca1qejeILi+XxlrksVzcaLdvPaWEx1CKESFo91vE3m2QCybBtVTjbGSs2sfL 8HfiJp0v/Iyt
reoW0THmX+0bi4DaQRL0DiOfTfLk3fugIwSnlEJ6nrHiHQNGvtPsdX1zTNOu 9Sl8mwgurtIp
Lp8qNkSsQXbLqMLk5YeorMv9T8Gp4nD3kdk2rW1zbWjXjWRb7PPIk3kRNcbd sblZpAqlgR9q
RcA3CBwDpqKKKACiiigAooooA838Tf8AJa9N/wCwT/7NNUwjkm+HuvQwxvJI 8uoKiIMsxMs4
AAHU1D4m/wCS16b/ANgn/wBmmrX8Kf8AIDuf+wldf+lE1Yz3KWxmar4lXWru OazsdZht7Oxu
7meC5kudNZ9hhIZSoy+AWGOnzdaZ4h0m70TTbe6tbP7GBqVmjNHrl1P8sl3E rjy3UK24OwOf
UnrWh4i0u/v/AJtOv7a0ke0ntJDPatMDHLs3YAkTDDYMHJHXimahaeJtViht dV1jSHtFuYLh
1ttLkikYxSpKoDNOwGWQZ+U8Z+tJSvuwsed/tDJd+JNEuNB0TStYvL7TrfUb mcJps4iZJNIv
YUEcpQRzOZLiJdkbM2WPHytg8dy694jkuPEPgmDWNMih04WF/cXGl3NtPcI1 5bO2yBhHcS+T
breEFNrA3BEDGRn2evUVFyrHglxD4rg8M2KDUfFOvRfbbk2Oliw1fS3vgUgV FN4Jpbm1CSGc
g3jbHLsMLGkUqGoaF4ibw9f2mq2GuzWFz4mnuLRNPE8ZtrePXmu52eOP94ZH gjMkU6k5AEcY
jkdTc+90U+YLHkMn9rf8JJH9g/4S/wC2f2jpn9heb9u+y/2RstftX2nf+587 H27P2n/SM7cf
N5VcV4dXxBrvgDwrL4am8U3clxZaPc6zcazFqF1D9vGoadJFNGtyw3xhReO/ 2dgm0AswHlkf
SdQ2Nra2NlBZWVtDa2tvGsUMMKBEiRRhVVRwAAAABwAKOYLHk/jjRNc0uwKX GoXjTazqL6jq
eq6Tp2pMkc8cENvDAlrYXC3AR4o9xdpXQNEcjMkYTO8HW3ja50NfFert4pXx J/augxmGSa5j
h+zy2+mren7HkQYBlvNzeX8jBzlWTK+30UuYLHkPwPt/GUetNL4l1fWLm4bT v+JxbXGl3cME
d8Wj+5LczvG+D54H2KNYSMk7R5IPr1FFDdxhRRRSAKpQ/wDIduv+vaH/ANCl q7VKH/kO3X/X
tD/6FLQAXX/If8P/APX+/wD6Sz11tcldf8h/w/8A9f7/APpLPXW10U/hIluF FFFWSFFFFABR
RRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFF FABRRRQAUUUU
AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQB wt3/AMgWz/7D
EX/pxFd1XC3f/IFs/wDsMRf+nEV3VRT2KkFFFFWSFV5orkzvLBPGm5AoDozg EB+cbgOrL0AJ
AIzyNtiigCu6Xx3bLi2HXbmBjj72M/Pz1T67W6bht5b40Xtxp/w21S8tbyay kja3/fwymN0B
njDYZeRwSPoa7GioqQ54ON7XN8NWVCtCq1fladu9nex4R8BvEF/qnxBmtZfE F9qMA0qeRopb
950VhNAA2GYgHBYA+hP1Pu9FFZYag6FNQcr+bN8xxixtd1lHlvbT+rHn/wAU /M/tzRf7V/4S
b/hF/s139r/sD7b9o+27oPs277D/AKRs8v7Xn/lnnbu+by68t+GrfEDVLnwd ql94i8QFprHR
ZrNU02+uo7qzNnatdPLcC4SyVmkN5uNxG9wB8ybmMAr3/wASeHtA8S2KWPiP Q9M1m0jlEyQX
9olxGrgEBwrggNhmGeuCfWtOug4TwbTbIaV+zNN8PYNK8WyeI7/w/NozW1xZ ahcxrqP2JIWR
ZpFaKG33soVw62+NxRsKxGZ4l+Gmq3/w58bXEdpeiG9/4SW7n0cRtuvr5bq+ FhKINmJd8c4f
ccsWtrAocR8/RlFAHzn4mtviX9s8aXFvrPib+1vs2t+VZWWlX+z7N5NyLDy7 g3H2Tf8A8ebL
9lh+0b8K3PntXW6nba74S+INqunt4tufB+ny2V9eZmvdTkcy2+qwSqCxkmmU SDTyYV3BDtk2
rlnr1+igDwaDWRqOlXOi+JNB8Ww2Oty6i2p6gfDGoXF1eaa2pXotrAFIWeFf JYk+ZtaOKVRE
oaTzIdPWPl+DvxE06X/kZW1vULaJjzL/AGjcXAbSCJegcRz6b5cm790BGCU8 ohPZqpS6TpU2
qR6pLpllJfx7fLumgUyptWVVw+MjCzzAc8CWQfxHIBdooooAKKKKACiiigDz fxN/yWvTf+wT
/wCzTVr+FP8AkB3P/YSuv/SiasjxN/yWvTf+wT/7NNWv4U/5Adz/ANhK6/8A Siasam5aOQ8P
aXY3lnaiXSp3Z0toYmtbHT2DubKKZtzTKXLHLsSTjp3pRarpvj3TbCPT2tAl xbyBpba1imYS
W2o7lJtwAUzBGQDzlc+lFl/wl2mpZx2Gk3cYtjFIwksracNKlqtsSG+3RkoV XIBUHPX0q1aw
eIdU8WWOratp1xFLHNGZZTBBBCsUUF2igKtzMxcvddeBhfXrTej1JSDx42tQ eLfCqaf4l1Kw
tdWvZtNuLWGG2ZAPsN5MsymSJnEivFGRlimFwUOTnkPC3xG8S2fgew1C/sod djsfCNj4l1zU
bm9W3uClws7ukEEVv5blFt3ChmjB+QFs5evR77wlot7q8+q3Q1KS6ljaNSdU uQluWj8svBGJ
NkEmwsvmRBXw7/N8zZp6d8PvCVhoF3oVvps39n3elLo88ct7PKWs187bDvdy wC/aJQCCCAwA
OFUDG6LOQh+IviLSfDtze6no8OqSXXibUNJ0Y28k8jzCG5vOJooLZ3jCRW21 TGsxYgF9gLMJ
pPitqY03V70eCLyFdH8Ovrd79suGtiu1rxBEqSRCX53tAyMyLmNyzBGVY36+ 78EeHLn7Zutr
yL7VcC6P2fUbiHyJvn3SwbHH2d38yTe0WwyeY+/duORPA/hZNN1LTl0v/R9U 07+zb4G4lLXE
G6ZiHYtuLs1zOzSZ3s0hZmJ5p3QGFqPj7VdJi1Ow1fQ9Nh8Q2kdrNbWVrf3F 1DdpO8yqqNHa
mcyAW1w7IkDgKgbdjeU8+1D4geI/EHiywk8PyeI7FdQ+xWlxYWAt/tCSRnXV nES3yrGuZLOM
lpEjkKRgFVb5B7JrfhHQNZvZr6+tJvtk0cEZuoLuaCaMQmYxmOSNlaMj7ROp ZCpZZGUkqcVT
0T4feEtGvbS9sNNmF1aSebFNNezzPvJuiWZpHYuSb66JLZJMvP3VwXQGR4a8 W6pa6o2g6zp2
pQwadpSapqmr67e2UUlvFJLdqBItsPKyPs6kFSF8ssXZXQLJj6b8V9a1DULf QrfwfDHr097D
CsN5c3lnbiKW3u5lk3z2aSk/6FKpAhK/MuHJ3BfR7jQtIub3ULu6sIbiTUrK OwvVmG9J7dDK
VjZDlSP38ueOQ2DkAYx9I+H/AIY0zV49Yhg1K41CKSOSO5vtXu7x1KRzxoAZ pW4C3VwNvTMh
OMgEK6A5CX4xsul2k0fhmaS81WOyutJgikmnEtrdxXMsLTeTBJLHIEs59yRx zKp2fOVLMnoP
g3WZvEHhu01a40u80uabeslrdQyRujI7ISFkVH2MV3KWRGKspKqSVGb/AMK+ 8JCygtYtNmt1
trK1sbaWC9nimghthKIRHKjh0IWeZSysGZZGViwOK3dG0yx0fTYtO06DybeL JALs7MzMWZ3Z
iWd2YszOxLMzFiSSTQ7dALlFFFIYVSh/5Dt1/wBe0P8A6FLV2qUP/Iduv+va H/0KWgAuv+Q/
4f8A+v8Af/0lnrra5K6/5D/h/wD6/wB//SWeutrop/CRLcKKKKskKKKKACii igAooooAKKKK
ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAo
oooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigDhbv8A5Atn/wBh iL/04iu6rhbv
/kC2f/YYi/8ATiK7qop7FSCiiirJCiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAK
KKKACiiigDzfxN/yWvTf+wT/AOzTVr+FP+QHc/8AYSuv/SiasjxN/wAlr03/ ALBP/s01
Re: Menus again [message #13888 is a reply to message #12935] Tue, 30 December 2003 00:00 Go to previous messageGo to next message
We done visual menu designing in our SWT Designer even before I've
heard anything about Instantiations. :-)
See for example: http://www.swt-designer.com/demos/demo4.html
SY, Konstantin.
Advanced Eclipse SWT Designer (http://www.swt-designer.com)
Re: Menus again [message #13897 is a reply to message #13844] Tue, 06 January 2004 08:23 Go to previous message
I openned a bug and Peter Walker show the correct way to move jmenus.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=49510
Thank you all
Re: Menus again [message #576206 is a reply to message #12862] Mon, 29 December 2003 19:30 Go to previous message
Hi Vitor,
> I've tried to move a JMenu (already created) inside to other JMenu, but
> it seems to refuse this action. It only works when I put a new JMenu
> inside to other JMenu.
Are you using the Java Beans tree view of the graphical pane in the editor
? Right now we support dropping JMenu onto JMenuBar in the graphical pane,
and you can also move these around visually - you'll get a vertical bar
showing the insertion point of the new JMenu so you can re-order them. You
can't currently drop JMenu onto a JMenu on the visual pane, either for new
or for existing items. For this you must use the Java Beans tree view that
lets you drop JMenu for cascaded menus, as well as JMenuItem,
JRadioButtonMenuItem and JCheckboxMenuItem.
For visual menus we thought about doing this a while back but we couldn't
come up with a good visual metaphor for designing it. Usually in a GUI
builder you drop something down close to where you want it to be, and
afterwards you see it so you can select it and change it properties. With
JMenu on a JMenuBar this works, but not for items on the JMenu. These
would only be seen at runtime if the JMenu were selected and it was
exposed. If at design time we exposed the menu it'd be obscuring whatever
else was beneath it on the GUI.
> Am I'm doing something wrong?
Not at all. We need to work on visual composition of menus, so please open
a bugzilla feature request and we can engage a design discussion there are
to how it could be done. I know that Instantiations have done some nice
work in this area in the past with WindowBuilder and also CodePro Studio
that enhanced the Visual Editor with menu designer when it was part of
WebSphere Studio. Their approach was to use an enhanced tree that let you
quickly and easily move things between levels, although it maybe that we
need to do more work with the visual composition of menus or perhaps a
combination of the two.
Joe
Re: Menus again [message #576707 is a reply to message #12935] Sun, 04 January 2004 18:18 Go to previous message
Hi Joe,
Joe Winchester wrote:
> Hi Vitor,
I started a new visual class and put some jmenus inside a jmenubar. In
the Java Beans view, I try to move a jmenus inside other and appears a
horizontal bar with the mouse icon changed, but when I drop the jmenu
nothing happens.
Have you experienced a situation like this?
Vitor
Re: Menus again [message #576747 is a reply to message #13844] Mon, 05 January 2004 09:21 Go to previous message
--------------030801030402050902060803
Content-Type: text/plain; charset=us-ascii; format=flowed
Vitor George wrote:
> Hi Joe,
>> Hi Vitor,
>> editor
>> pane,
>> them. You
>> new
>> that
> nothing happens.
> Vitor
The horizontal bar denotes that you are going to change the ordering of
the menus. See image1 before and image2 after the drop. The "Tools"
menu moved left.
If you drag the Tools menu on top of the "Files" menu (on the JB
viewer), it will become its child (fig. 3)
Content-Type: image/jpeg;
name="Image1.jpg"
Content-Disposition: inline;
filename="Image1.jpg"
/9j/4AAQSkZJRgABAQEAYABgAAD/2wBDAAUDBAQEAwUEBAQFBQUGBwwIBwcH Bw8LCwkMEQ8S
EhEPERETFhwXExQaFRERGCEYGh0dHx8fExciJCIeJBweHx7/2wBDAQUFBQcG Bw4ICA4eFBEU
Hh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4e Hh4eHh7/wAAR
CAHaAw4DASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS 0fAkM2JyggkK
FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1 dnd4eXqDhIWG
h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW 19jZ2uHi4+Tl
5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcI CQoL/8QAtREA
AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMz UvAVYnLRChYk
NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0 dXZ3eHl6goOE
hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU 1dbX2Nna4uPk
5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD6Ru/+QLZ/9hiL/wBOIrlf i/pOtanfaU2j
eFB4kljtbpDCWtx5JZoMSYndVP3SOCTz0IzXVXf/ACBbP/sMRf8ApxFcr8Yr /UdNutLu7Oz8
R3Uf2e6jK6Ol2xEhaEpv+zfNjCvjPGfTrW2WuSxEHG19d/T1X5meLSdGSab9 N9zD8GaHr2g+
ENH0HUdd0fwhqpF9PJZ3+hx36xh7q7uFdp0lEajylJ27+Ah5r0zwz5Z05Xiv 7HUVeOB/tllG
sdvclreImWNVZgEcncAGIwep615z8Prjxx/wiWjawNA0m61uP7aBdeJo71dR iU3lz5ab/Id1
TymTGSDhjxivTNHmvLmF7nUYooruXy2nWHf5Qk8mMOELqrFAwYAlQSB0FZZg 715t2vzPb1Zd
FWivQ5jT/G91cRWGuTaPDD4T1WSCLT9RW8LXDmd1S3kkt/LGyOVnQKQ7uPMj Lon7zyzxN8Sd
A0nw7pGtWrTajHq8drdWUcMExea1lubWBpVUIWJX7ZEwjxvYnaBnODT/AARd W8Vhoc2sQzeE
9Kkgl0/TlsytwhgdXt45LjzDvjiZEKgIjny4w7v+88zCj+Fep7NItJvFFm1j 4e05LLQ0TSmW
WPyrmznga5czkTYNjEHCLFuDPgpkY5dDXUuQfFLT7bXdYt9Z/wBGsbe4VLML ZXRvHRoNMKKb
cRsxcy6iEKnYy/INjfOy7r/EDwwtlFcLPqUskkjx/YotIu5L2MoFLF7VYjPG AJIiWZAMSxHO
JE3c5e/C26v/ABMfEF74ihN1JewXkyQ6eURnR9JdgoMrFQTpRxkkgT9Ts+c8 V/Ce11vxFe6+
8mhXt1cXsk8dvreiDULWJJLazhceX5qEyZskKybgAsjqVOQwNA1PRrG6tb6y gvbK5hurW4jW
WGaFw6SowyrKw4IIIII4INTVT0TT4dJ0Wx0q3bdDZW8dvGfLjjyqKFHyxqqL wOiqqjsAMCrl
SMKKKKACiiigAooooAKKKKACiiigAooooA57xJ4w0jw3rNhY6752n2l+GWHV J9q2YmHIgeTd
lHYZK7gFbBAYthTY8G+IrXxVow1mws76CwlkYWk11EI/tcQxtnjXJby252lg pYDcBtKk5vjr
wanjO5trHW9RkbwyiM11pEKtH9ulz8nmyq2TEvXywBlgCzEDadLwbpOp6Jow 0zUtdm1sQSMt
rc3EeLgQcbEmfcfNdeQZMKWGMgtlmCVe5iah/wAli0//ALBh/nLXb+Bf+QA3 /X/e/wDpVLXE
ah/yWLT/APsGH+ctdv4F/wCQA3/X/e/+lUtbw3EzhPHclj4d+GOt+Kbbw9om oasmqzJH9usx
KJXk1EwhT0YnDAAA9cVe+C2upeX+t+HrXVn1HT9LitZbT7RZTWtxAk3mjynS Y78DysjIGCWA
AVQq8d8VPAfiHW5Z7vTPCWqXGp20t0sbf2nbLZX1vJNOxSSJ3+Y+XcSqoYAZ fDYHzLz37P3h
Xxna/E60upNJ1TT9F0qKZXn1O3khlMcsZ/0RS+GmXzPKkD/MAIyH+cKzqrWl GcKcIXWrb669
O2lrrvd+hUIRcHJvXsdTd+OPi5oul+INR1/R7Kxhh1KwtbOVtOkugv2htNib EEMiu+DcXLiO
J7jMvmRCUCFDP08fxIm0DS7KbxPHe6v9rtr3UpLux0GTSl0+wtGhSeWe3u5z P8plDfIGZl+6
hwC3Z+NPD0PijQG0ia/vdP8A9JtrqK5s/L82KW3njnjZfMR0OHiXIZSCMiuf 1H4b2+r2N3b+
IPFPiDWJbnSNR0c3FwLSORLe9EAkCiGBF3L9nUqSpwWbO4bQupmQf8LOjk1S HRbPwX4mvNcP
2n7VpkTWSy2XkrbM3mO9ysTZS9tmHlu/D4OCrAU9A+K0OoP4h1NtIvbjwvY3 NkbTWrdI0g+z
XNtYy75lklEq7BdvM7mNUSFCSdykGbWfhvez/ElfFOi+KdT0NbmK9e+ktRbv MZpY9OiREWaC
RBFssMtn5txGDtJAur8P7XQtB1mx8IrCsF5pBs4tE1MCfTJpkto7eF59ytOV 8qGGJlD7Sik7
S5LEA6bQtbtdZm1NbOOYxaffNZNOwHlTuiIXMTAncqOzRN0IkikUjK15/efG fQtB8NadrXii
Cawivb7UbeQTTWVvJZi0unhkDRNdM07JjB+zeaXK5CKXRK7PRvCtrpOk6Bpt nqOprFo0pmZ/
PAfUHaKVHe6IUeazvK0zHgtKA5568YnwiW+8NahZX/iLU9Iu9civYtbXSGge O4hubq6ufs+6
4hc7YjeTosiLEzhizAfKqAHW2PjXSrzVLXS4re9+3z6ld6fJalF822+zqzNP Km7KQsohKvjk
XdscDzRVL4ZfEjw98QP7Qj0dtlzp/lNcQfbLW62pJv8ALbzLWaWLkxyDbv3j bkqAylrupeBf
Depaprt9f2Xn/wBu6b/Zt7FkIrRMpWVlKgOryp5SOwbLLbQDjy1o8J+En0PX NS1u88S61r1/
qFtbWry6itsvlxQNMyKot4Yh964kJJBPT0oA1tY/5Zfj/SvF/GvxS1fwD4mm 0HxJokOqXGsy
Y8HHTW8oahIXjj+xz+Yx8mRGlQmbPlshJAVl8s+0ax/yy/H+ledXPwx8K6le +I7zxFbzeIbj
xBH9muX1JlcwWoIZLWDaF8qNWG8bfnL4dmZgCMJW5nctbHUeD111dJ04eJpt Nl1jCm7bTonj
tw5OdsYdmYgcDJOWxnC52iTTvuXH/X5c/wDo56j8H6XJomk6dpMuralq7WoW MXmoyI9xKAeD
IyqoYgYG7GTjJJJJMmnfcuP+vy5/9HPUdBlmiiikMKKKKACiiigAooooAKKK KACiiigAoooo
AKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigA ooooAKKKKACi
iigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAMDVzKvhqFoGRJR qsZRnUsob+0O
CQCMjPbI+oq15HiL/oKaV/4LpP8A4/VbVP8AkXbf/sKx/wDpxq9r+laRq1h5 Ot2drdWsTedt
uFBRCARu56YBPPvVX0EReR4i/wCgppX/AILpP/j9V9RPiW1tfNj1DSZHMiIq tYSKCWcKMnzj
jr6Vw3wYuJ7XxFrenSf2La2c03mW8VojoJ2Cqu6IHgJhWJHJy2c4GT6TrX/H nH/182//AKOS
iWjsCdzO+zePP+evh0/SGb/4v/OR6ij7N48/56+HT9IZv/i/85HqKoeK/E2q aX8WNH0qKYvp
cvh/Ur64tVRCZZYXt9hDEFgcSOMA4O7kN1PM/CLxRLfeOItPk1Sd7W70czJD d6sbyR7jzctk
lQqyCNhmNBhR7lgeqlhJVYSmvsmE66hJRfU7u3tfF2x2u77Q4iCoURWcsmc5 65lGOnvnNP8A
I8Rf9BTSv/BdJ/8AH637n/Vtz3X/ANm/z/j1PnfjHXtS0zxVDpceqi0srtY5 JLp7dH+wjLKT
zgGM7SxZs7CCSdp+Tmtd2Rtc6XyPEX/QU0r/AMF0n/x+jyPEX/QU0r/wXSf/ AB+ub0HxJfw+
K7fQdRnu7n7UGVTd2S200cgRpMFVJG0op5OD0ruaTuhp3MryPEX/AEFNK/8A BdJ/8fo8jxF/
0FNK/wDBdJ/8fqtp/i3Rbm4u7O6uV0y+tJvKmtL50ilGSdjgbiGRwMqykg8j hlZV5jwRp5s/
iJqUiaVIBJ9uea9l0uW2lBa6RkRptxjulYFjGQMxogU4LEUagdh5HiL/AKCm lf8Aguk/+P0e
R4i/6Cmlf+C6T/4/WrXJ694i1GPVZ7HSxaxC1YJM9zE0m9mRX+UK64ADDkk5 JPAxkiTewPQ1
/I8Rf9BTSv8AwXSf/H6PI8Rf9BTSv/BdJ/8AH6XwprKa/oFvqqQNB5pdHjLb tro7IwB7jcpw
cDIwcDpWpSuwMryPEX/QU0r/AMF0n/x+jyPEX/QU0r/wXSf/AB+tWii4zK8j xF/0FNK/8F0n
/wAfo8jxF/0FNK/8F0n/AMfrVoouBleR4i/6Cmlf+C6T/wCP0eR4i/6Cmlf+ C6T/AOP1q0UX
AyvI8Rf9BTSv/BdJ/wDH6PI8Rf8AQU0r/wAF0n/x+tWii4HBsl6nxcsBfXFv PJ/Zxw0MBiUD
MvGCzc9ec/hWzpEl9DbCK11LWt093fOkFqtrtQLdOp5ljJ5JB6nqe1Z2of8A JYtP/wCwYf5y
1teGf+P2z/39T/8AS0/5/oelaXa2JC0vtTuxIbXVPEVwIpDFJ5Tac2xxjKnE fBGRkdeamD66
el34o59tP9v+mfuPzrkpvD2s6LNd+PfBsYuL2W+uxrGlFwkeqRpcSqG3HIWd VGFkPBHyOSuC
nd+EvEWleKtCg1nRp2mtpSVZXQpJFIDh45EPKOpyCp5B9c/M7y7kpplEPrp6 Xfijn20/2/6Z
+4/OgPrp6Xfijn20/wBv+mfuPzrjdb8T6x4Q13Udb8aX/iSHTYPt01pb2cWn vpt7HFBNOkMe
QbsTfZ4mkYyMkZlRwGKMivjaz8VdSVdJ1fWvD+saLbaVqM11erBFdpFfW66R qUxiU3cFs0jq
0AYqUKAmE7iSQC8u49D0sPrp6Xfijn20/wBv+mfuPzoD66el34o59tP9v+mf uPzrk9H+J+ua
isVg3gma11m8vY7SwF015a2M5aCedszXNpHLuVLaXISCQZkhG4732wr4v8ZQ 6l4jXVLWzSxs
/Eej6cj2l+GlgkuV0wSQKr2uJIc3UzGViJGDFQEyrAvLuGh2QfXT0u/FHPtp /t/0z9x+dAfX
T0u/FHPtp/t/0z9x+dcdL8VtUXSdLv08LWjf8JFb2t34fQ6o486Ce6s7cG6P kH7O4+3wttTz
wcSDdwDJ2/g3XrrWk1O11LT4bHU9JvRZXsVvcG4g8xoYp1McjIjOpjuI8kov zbhhhhpC8u4a
EIfXT0u/FHPtp/t/0z9x+dAfXT0u/FHPtp/t/wBM/cfnXSdffP8An+vv175+ Y6++f8/19+vf
PzF5dw0ObD66el34o59tP9v+mfuPzoD66el34o59tP8Ab/pn7j866Tr75/z/ AF9+vfPzHX3z
/n+vv175+YvLuGhzYfXT0u/FHPtp/t/0z9x+dVYrLUUDBJfFA3uznmw5Zm3E /c7lv1rruvvn
/P8AX3698/MdffP+f6+/Xvn5k7vcZyYtdUPSbxRz72Ht/se4/OkmtNSH2P8A 4nGt23n3DRMs
y2jNtEbPkbYiOoHf146Gut6++f8AP9ffr3z82Vrn/Hzpf/X4/wD6Ib/P9T1q XogRjzWOopqe
l2o8R6nsu7lopCY7bIAhlk4/ddcoPwzW5/wjVx/0M+s/98Wv/wAZqndf8h/w /wD9f7/+ks9d
bWkEmtRSepz3/CNXH/Qz6z/3xa//ABmj/hGrj/oZ9Z/74tf/AIzXQ0VfKuwr s57/AIRq4/6G
fWf++LX/AOM0f8I1cf8AQz6z/wB8Wv8A8ZroaKOVdguznv8AhGrj/oZ9Z/74 tf8A4zR/wjVx
/wBDPrP/AHxa/wDxmuhoo5V2C7Oe/wCEauP+hn1n/vi1/wDjNH/CNXH/AEM+ s/8AfFr/APGa
6GijlXYLs57/AIRq4/6GfWf++LX/AOM0f8I1cf8AQz6z/wB8Wv8A8ZroaKOV dguznv8AhGrj
/oZ9Z/74tf8A4zR/wjVx/wBDPrP/AHxa/wDxmuhoo5V2C7Oe/wCEauP+hn1n /vi1/wDjNH/C
NXH/AEM+s/8AfFr/APGa6GijlXYLs57/AIRq4/6GfWf++LX/AOM0f8I1cf8A Qz6z/wB8Wv8A
8ZroaKOVdguznv8AhGrj/oZ9Z/74tf8A4zR/wjVx/wBDPrP/AHxa/wDxmuho o5V2C7Oe/wCE
auP+hn1n/vi1/wDjNH/CNXH/AEM+s/8AfFr/APGa6GijlXYLs57/AIRq4/6G fWf++LX/AOM0
f8I1cf8AQz6z/wB8Wv8A8ZroaKOVdguznv8AhGrj/oZ9Z/74tf8A4zR/wjVx /wBDPrP/AHxa
/wDxmuhoo5V2C7Oe/wCEauP+hn1n/vi1/wDjNH/CNXH/AEM+s/8AfFr/APGa 6GijlXYLs57/
AIRq4/6GfWf++LX/AOM0f8I1cf8AQz6z/wB8Wv8A8ZroaKOVdguznv8AhGrj /oZ9Z/74tf8A
4zR/wjVx/wBDPrP/AHxa/wDxmuhoo5V2C7Oe/wCEauP+hn1n/vi1/wDjNH/C NXH/AEM+s/8A
fFr/APGa6GijlXYLs57/AIRq4/6GfWf++LX/AOM0f8I1cf8AQz6z/wB8Wv8A 8ZroaKOVdguz
nv8AhGrj/oZ9Z/74tf8A4zR/wjVx/wBDPrP/AHxa/wDxmuhoo5V2C7Oe/wCE auP+hn1n/vi1
/wDjNH/CNXH/AEM+s/8AfFr/APGa6GijlXYLs57/AIRq4/6GfWf++LX/AOM0 f8I1cf8AQz6z
/wB8Wv8A8ZroaKOVdguznv8AhGrj/oZ9Z/74tf8A4zR/wjVx/wBDPrP/AHxa /wDxmuhoo5V2
C7Oe/wCEauP+hn1n/vi1/wDjNH/CNXH/AEM+s/8AfFr/APGa6GijlXYLs57/ AIRq4/6GfWf+
+LX/AOM0f8I1cf8AQz6z/wB8Wv8A8ZroaKOVdguznv8AhGrj/oZ9Z/74tf8A 4zR/wjVx/wBD
PrP/AHxa/wDxmuhoo5V2C7Oe/wCEauP+hn1n/vi1/wDjNH/CNXH/AEM+s/8A fFr/APGa6Gij
lXYLs57/AIRq4/6GfWf++LX/AOM0f8I1cf8AQz6z/wB8Wv8A8ZroaKOVdguz nv8AhGrj/oZ9
Z/74tf8A4zR/wjVx/wBDPrP/AHxa/wDxmuhoo5V2C7OB1T/kXbf/ALCsf/px qfxjp9zqnhq8
sbQgTyKpUE4D7WDFc/7QGPxqLWYC+gxWwmeMtq6IJEA3L/xMcZGQRnvyCK17 nQTawNPc+LdV
hiXG55BaKoycDJMPrWKi3qU2ebW8Gp69q+kQwaXq+nrY3VvPN9rt/KhsxEMO sTHmQykEHy8L
hiW3cGvQda/484/+vm3/APRyUyK006WVIovHt1JI7BVVZbMliegA8rk1fPhi Y43eJNWcAggN
FaMMg5BwYex5qpRchJpHmHimfxt/w0t4blsvA8t3osOmXNsdVF7iBYpnt2ke T5DskUxsFj+b
zMqQcFiu38Z9RgspdGhOrz2V5eefDbI2pyWVpkhC008iOpKxjooOWL4Gc5bB 8YeLfEv/AAk9
5oPgvUZ7s6aGN9eXsdmsKFfvDPloFCngszfeBGOATc+HHifWdW8Ry+FfFOqX thrAUvA9tFaG
KYbd20AxNzsIYEMwYZPGBmYYimqijfX+uphRzCjGso79PK/a51/w/ltJfA1k 1lrN5rUKsyfb
7uQvJcMskgZskk43A4HZcdepp+J9BvrnWLLXtHltl1GzGBHdbvKlAOVBK8jB J5wetdM/h66Z
dp8TauBnPEVoP5QVx3ifXPDnhrUv7P1/4oW+kXLL5iQ397YwSMm4gMFeMEjK kZ6ZB9Kqaalz
HTKSk2zG8GeCdV0bxDp2oalHbTRwCVIktrkstqWTAY7lXeuNygDlN+BlT8np FZX9l33/AEMm
q/8Afu2/+M1FfWsljZT3t74tv7W1t42lmmmFqiRIoyzMxiwAACSTwAKzbuCV jmPij4G1LxLq
lnqek3VnBdwReSHuCwCLuJbgA+YrZwyHbnapDKyqy9H4AnuX8LWdpfWV7Z3u nxrZ3MdyCSZI
1UF0kwBKjcMHXrnBCsGVbP8AZd9/0Mmq/wDfu2/+M1dsdAup4i7+JtXBDY4j tf8A4zTSctBb
aliuc8S+ELLW7v7V/aGo6dKy7ZjZugE3GAXV1YZA4yACRgHIC46L/hGrj/oZ 9Z/74tf/AIzR
/wAI1cf9DPrP/fFr/wDGapU5IOZFfS7Cz0vT4bCwgWC2hGEQZPfJJJ5JJJJJ ySSSck1ZpP8A
hGrj/oZ9Z/74tf8A4zR/wjVx/wBDPrP/AHxa/wDxml7JhzIWik/4Rq4/6GfW f++LX/4zR/wj
Vx/0M+s/98Wv/wAZo9kw5kLRSf8ACNXH/Qz6z/3xa/8Axmj/AIRq4/6GfWf+ +LX/AOM0eyYc
yFopP+EauP8AoZ9Z/wC+LX/4zR/wjVx/0M+s/wDfFr/8Zo9kw5kLRSf8I1cf 9DPrP/fFr/8A
GaP+EauP+hn1n/vi1/8AjNHsmHMjjNQ/5LFp/wD2DD/OWt3wvFK09rKsUjRr JqSsyqSATetg
H64P5Hg1g6hYvp/xi0+F765vS2mFvMnEYYcyjHyKoxx6Z561FrlhZ6pY+HNO vdd1LS45/EN8
BFY3NxbvfEfb28gywOjIBtMuScEwherCm1bcEU/ib4R8QyeEtUjOu6peWN7P NHcWNrpzusFt
PLIwkWFCZJ5IpJIpHUsRLHDJGEAchu2+HB1J/AmjPq2hPot+1ohubIIv7qQj 5vuKF5JJIAGM
njrugm8OafLqV/qDXGsCa/tzbTKmr3SxKhUDMcYk2RPhR88YVgckHJJNP4cW U2neGDYzav8A
2t5Oo36x3BvpLtli+2TeXE8shLs8abY2DEkMhGTjNDqOW/8AX9WBRsXz4G8O y6nc397Z6jqT
3Pm74NSv7q8tl80MsmyCZ3ijysjp8ijCO6D5WYNDB8PPCiKouNKu9RYStIZN Tu7m+d8wzQFH
ed3Z4vLuZwImJQGWQhcklvO9F+NX9peG/C98vhry9U1jUba3vdO+3Z/s+2ne 2C3Pm+WFl+W+
sW8sYP8ApGOPLfb2uo/EHwlpbXo1fUptKWykWOaTULKe1Rg0yQb43lRVljEk kYaRCyKJELMA
wJXMwsX0+HvhkWMtq1rq8sksiyfbZtUvJL6MqGChLppDPGAJZQFVwAJZRjEj 75W8C+HHuRcP
Y37ufsrSB765ZZpLaSKSGaVS5EkymGIGZw0jKgVmZchsu5+IHhi2vbW0mn1J ZLmS2h3DSLsp
BLcFBDFO4i2wSN5kf7uUowEiEgBhmZ/HHhZNN03UW1T/AEfVNO/tKxIt5S1x BuhUFFC7i7Nc
wKseN7NIFVSeKXMwsWLT4c+EbZgY9IuXVJIXt45rq4ljtBFPHPHHbo7lbeIS RRExxBUIiQFS
qAHf0/S7Owu9Ru7S0kim1O5F1eNhz5soijhDYOQP3cUa4HHyk8kktyT/ABA8 MLZRXCz6lLJJ
I8f2KLSLuS9jKBSxe1WIzxgCSIlmQDEsRziRN3R2N1a31lBe2VzDdWtxGssM 0Lh0lRhlWVhw
QQQQRwQaOYLGthj/AMs5PxQ/57/z687jDH/lnJ+KH/Pf+fXndn0Uc47Ghhj/ AMs5PxQ/57/z
687jDH/lnJ+KH/Pf+fXndn0Uc4WNDDH/AJZyfih/z3/n153GGP8Ayzk/FD/n v/Przuz6KOcL
Ghhj/wAs5PxQ/wCe/wDPrzuy9cBFzpZKsM3jnkY/5YP/AJ/xqSqWo/8AH5pv /Xy3/omSk5XQ
WC6/5D/h/wD6/wB//SWeutrkrr/kP+H/APr/AH/9JZ662tqfwky3CiiirJCi iigAooooAKKK
KACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigA
ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA4nVP+Qd b/8AYbj/APTl
XR+J5I4tLWWV1jjS7tmZmOAoE8eST2Fc5qn/ACDrf/sNx/8ApyrtqiOzKZwN pd6+0sceteMv
CWrwvcWwit9M0t7abf8AaIju3NdzAqFDZUKDyDkYwe2RL4bd9xbHpuxAwz93 OPn46P8ATcvX
ad1iiqsSfN/jaE+D/Efi2x8SQXUWj+I5Wmg1C3QMFJl85QAxCkhiVZSwOBkc EZX4GeHn1T4k
W3iLRoL1fD+mCRlurtQDPI0TRbVxwfvsx25CgAEkkE/R9QpKTfSwbl2pEjgc ZGSw55zj5fQd
+TyByLBxVRTvs7nmxy2CqqpfZ3X5/myavEfGE82lfG+/1W4vvF9jYvpOnKo0 jQZL+C9aO5vW
eKVktpimA6cK0bYk69CPbqqvYQu7OWkyxycEf4V0zTex6aZ86arp3jKCx1jU LOTxeb42/ibU
YFF5duv2y2vsaYqRliuwxO+2ADy5lALI+1SM3ULbWvE2geJdM8ON4pv9bvb3 xLYait5NefYG
tf8AiYRW8cTXB+ygiUWajySHADA4US19N/2dB/ek/Mf4VDZ6Jp9nE0NpCtvG 0jyskSqoLu5d
2wB1ZmZiepJJPJqOWQ7o8Z1KO9ZtK0rwjquuxWXiayk0501O4vVv7BIpmeW8 jFx++iPlS3Ce
a4YeadPUAIefbNJ/49m/3z/IVTu9P0SHU7Ke7e3jv5fMtLKSUoJX3L5jxRkj JysO8qOoiyfu
5EOheJvCd/rN34f0jxNo+oarZlzdWNvfxS3EGxgj741O5drEKcjgnB5pxi09 QbN6iiobe7tb
ma5ht7mGaW1lENwkcgZoXKK4RwPutsdGwecMp6EVqSTUUVman4h0DS7G/vtT 1zTLK006VYb6
e4u0jjtXYIVSRmICMRJGQGwSHX+8KANOiqWiatpWuaXDqmianZanYT7vKurO dZopNrFTtdSQ
cMCDg9QRV2gAooooAKKhsru1vYWms7mG5iWWSFnikDqHjco6Ej+JXVlI6gqQ eRU1ABRRRQB5
v4m/5LXpv/YJ/wDZpqzdc1ZtGsfDl8+jTajajxDfLdSQaXNezWaH7fiaNIVZ 1JfZGW2kbZWB
+9kaXib/AJLXpv8A2Cf/AGaakvvEVh4W8E3Gsai4EUV3eYXOC5+1TE49AAGY scKqqzMVVWYY
1GldsuJpTeI9Pi1K/wBPa31gzWFubmZk0i6aJkCg4jkEeyV8MPkjLMTkAZBA 5v4ZeJ9Jvry6
8PWfh/WNFuB9p1byru1nVXin1C6USsZFDRvK0bTCJwpCyALuCttST4k2jeDN U8RWlilxNprQ
pPpwu1E4aaQRwndjy/LZj/rQ5jG2TLZjcLN8LviDaeOYJhFax2t3aqDdQLOX 8sklQRuRGA3J
KmHVGDROCoG0tzqrB2Se+xfKyKx+G9jaeENG0aO8/wBO0+30S2mv/Kb/AEiL TLhZ418vfhNx
EgyCSPM53bQK5yx+C/2bXrXUv7W0dfsvkjz4NE8u+vvLvrO78y9uPOP2iZvs e0ybFy0zvj+G
u71vx54L0W7vrLU/FOjwX1hbyXNzZfa0a6SJIjM7eSpMhxGC+ApOOa6OtLtE nnPjbwb4hkv5
7rQL6zlsdR8RaTquo2M9oTOWt57NXaKfzVVEWK1RthjdiVcA/MoXNuvhDdX+ n6fo+p6/pt5o
+jaUNN0q1fRySUS4s5ovtZaYrcD/AEGJXVUiDhnxsyMesUUXYWPJ7j4M2Ell Ystt4Ka8tpLl
vs8vhOJtLAnEAYparKrLJ/o0WJGlc/NKPusix+maJp8Ok6LY6VbtuhsreO3j Plxx5VFCj5Y1
VF4HRVVR2AGBU19dWtjZT3t7cw2trbxtLNNM4RIkUZZmY8AAAkk8ACqnh7X9 C8RWT3vh/WtN
1e1SQxPNY3STorgAlSyEgHDKcdcEetF2wNGiiikMKKKKACiiigAqlqP/AB+a b/18t/6Jkq7V
LUf+PzTf+vlv/RMlABdf8h/w/wD9f7/+ks9dbXJXX/If8P8A/X+//pLPXW10 U/hIluFFFFWS
FFFFABRRRQAUVS1vVtK0PS5tU1vU7LTLCDb5t1eTrDFHuYKNzsQBliAMnqQK ydM8e+BtUiab
TPGnhy9jVtrPb6pDIAeuCVY88j86qMZSdoq4m0tzo6KyB4o8Mt08RaQfpex/ 40v/AAk3hv8A
6GDSf/AyP/Gr9hV/lf3E+0h3Naisn/hJ/DX/AEMOk/8AgbH/AI0f8JP4a/6G HSP/AANj/wAa
PYVf5X9we0j3Naisn/hJ/DX/AEMOkf8AgbH/AI0f8JP4a/6GHSP/AANj/wAa PYVf5X9wc8e5
rUVk/wDCT+Gv+hh0j/wNj/xo/wCEn8Nf9DDpH/gbH/jR7Cr/ACv7g549zWor J/4Sfw1/0MOk
f+Bsf+NH/CT+Gv8AoYdI/wDA2P8Axo9hV/lf3Bzx7mtRWT/wk/hr/oYdI/8A A2P/ABo/4Sfw
1/0MOkf+Bsf+NHsKv8r+4OePc1qKyf8AhJ/DX/Qw6R/4Gx/40f8ACT+Gv+hh 0j/wNj/xo9hV
/lf3Bzx7mtRWT/wk/hr/AKGHSP8AwNj/AMaP+En8Nf8AQw6R/wCBsf8AjR7C r/K/uDnj3Nai
sn/hJ/DX/Qw6R/4Gx/40f8JP4a/6GHSP/A2P/Gj2FX+V/cHPHua1FZP/AAk/ hr/oYdI/8DY/
8aP+En8Nf9DDpH/gbH/jR7Cr/K/uDnj3Naisn/hJ/DX/AEMOkf8AgbH/AI0f 8JP4a/6GHSP/
AANj/wAaPYVf5X9wc8e5rUVk/wDCT+Gv+hh0j/wNj/xo/wCEn8Nf9DDpH/gb H/jR7Cr/ACv7
g549zWorJ/4Sfw1/0MOkf+Bsf+NH/CT+Gv8AoYdI/wDA2P8Axo9hV/lf3Bzx 7mtRWT/wk/hr
/oYdI/8AA2P/ABo/4Sfw1/0MOkf+Bsf+NHsKv8r+4OePc1qKyf8AhJ/DX/Qw 6R/4Gx/40f8A
CT+Gv+hh0j/wNj/xo9hV/lf3Bzx7mtRWT/wk/hr/AKGHSP8AwNj/AMaP+En8 Nf8AQw6R/wCB
sf8AjR7Cr/K/uDnj3Naisn/hJ/DX/Qw6R/4Gx/40f8JP4a/6GHSP/A2P/Gj2 FX+V/cHPHua1
FZP/AAk/hr/oYdI/8DY/8aP+En8Nf9DDpH/gbH/jR7Cr/K/uDnj3Naisn/hJ /DX/AEMOkf8A
gbH/AI0f8JP4a/6GHSP/AANj/wAaPYVf5X9wc8e5rUVkf8JR4Z/6GLSP/A2P /GkPinwwOviP
R/8AwNj/APiqPYVf5X9we0h3NiiuZ1T4h+ANLZF1Pxz4YsTJnYLjVoI92MZx uYZ6j866Cwu7
W/sbe+sbmG6tLmJZoJ4ZA8cqMMq6sOGUgggjgg1nKLi7NWKTT1RNRRRSGFFF FAHDXrFtItGY
5J1mIn/wYiu5rhbv/kC2f/YYi/8ATiK7qop7FSCiiirJCqUnntqEyW88aMIU OHUuBnzADtDj
HOOcDIBGT/BdqvG2dTnTdnEMZ27umWfnG7jp12jOOrYwqAHS+O7ZcWw67cwM cfexn5+eqfXa
3TcNtXxXFf3HhbVoNLMgv5LKZLUxybGEpQhMNkbTuxzkYrSooaurF05uElJd DiPhtY69a6tq
0up2WuWdlJbWa28Wqaqt6xlUS+cylXbaDlPTOM4H3V7eiilGPKrIqvWdabnL dnmfx4sdb1Ae
GrHw3rN7pWralc6jptvLFfzQRbpdIvmRpBGcHbLFC4YqzIVyuCTk13xCl54M k0DwvoXibRZr
H7Gt1Zx6Hc2v2awS5hS7it5kTy3dbcyhBayOxxmEsQprudau9A0qaHV9audM sZY4poYbu7kS
NlTZ50qK7YwuyDzGAOMQ7jwmRD4Y8WeFfFH2j/hGfEui639m2/aP7Ovorjyt 2du7Yx252tjP
XB9KoyPLPDmh6pr/AI1trO6n8cw+C0i1KXS2m1PUrKfAXSwgnculwW846jsW c527ig2BMc/o
Nl42/wCET1/VLlPE1j411y20i+uZfs14bf7GbXTIr9/IhZIlugYrseXGY7vC 4j25Q19GUUAe
GeCfDmv6xrmj2Guaz4zu/D622qTQzI+qaNhg2nCJXL3LXTfMb0r9pfccybF8 tYzWBpOj+K73
w7d32qWfiCLxrrV94Y1PdPZXb2IVP7HWeWW3jKW6ypPBOXT93MI42+7Hg19J UUAeM+PNC1/S
dPMdxqV602t6k+p6rq+kaZqjJFcR28FtDAlpp9ytyqPFHuLvM6B4TkZkjCZn gq28dXOgr4v1
lvFq+J/7X8PRGGWa6jg+zy22lrfH7FkQbQZb3c3l/Iwc5VowV9zsLu1v7G3v rG5hurS5iWaC
eGQPHKjDKurDhlIIII4INTUAeM/Aa28bR6403ijWdaurltNP9tW1zpV5Bbxa gWjPyTXNw8T4
P2gD7DGkBBJO0CBT6b4e/wCQv4j/AOQ1/wAhJP8Aj+/1P/Hpb/8AHr/0x9f+ mvn1s0UAfM3i
W98Zw+CZV0K78TC50a51z+xbuKHVtXlvriLUruOK2k+zzBV8pYLcBrxZkcS4 CkJIG9Nlg8cW
PifU7a1jvdUsNF+2a5pyG8eJ9UluUkEFg8zjyykcrXmUwBGg085OHr0awtLW wsbexsbaG1tL
aJYYIIYwkcSKMKiqOFUAAADgAUJd2r30tilzC13DEk0sAkBkRHLBHK9QrGNw CeCUbHQ0AeDe
DX8Zxf25YaZqPibUJY/sE2gTXek6tZW4v3+1iZbg6jLLI9qIkiMnz7QGHkqL goW9Gj1G6h8F
HTLJvFtjqE+kahcf2rf6abyeyuY2VWMka5WSUySl44ogYpFiYRfuwgPc1S1v VtK0PS5tU1vU
7LTLCDb5t1eTrDFHuYKNzsQBliAMnqQKAPCvh2L4fEG2F7YanbqLd1gnv72/ mkvUAYeeIr4m
4tlLBx5DkhSpKs6sHbrvEPhxPFHgldPF5JY3a6rcSWd3GNxgmN5MgYrkblKu ysuQSrMAynDB
L/VtK1j4x6dcaRqdlqEK6SmZLWdZVG9XlTlSR80ckbj1V1I4INa2lXunDSmt 5tTt7eaO/umw
ZkDowvJWHB/A8isKyUk0y4trVHjD+HNQ+DsF22oxaZqt1rlpcWttpcVq91ZQ WYaH7QPKYxmd
mLR7bYMgCCbYzfJFXU/AHWPDlzNcWGjaPaWM80TXzXdrPJNHqETeWqNukd3Q x42eWWKhShQ4
ZlTqPiFouheNNLittR8TLHc2snm2d0ksIeB+hyABvRhwyHgjBGGVWXC+FngT QfBWt6hrlx4p
s9U1K8V4w6qkEcSOys+1N7Hc5SMuc4Zk3YBLE8fJNVFy/Alt1/r5m3NGUG5f EZupTT2nwM1j
4ez6RrsvidPDN7azmHR7qWG9uzayGSZblYzFIZ3LSAl97NJhgJCyCbxHp2ra J4kk0i3k8Xy+
C1+w3OoPDeX13dfOmoLIIplZ7o/vY9O3JC3yg5ICPIW9R/tfSf8AoJ2X/f8A X/Gj+19J/wCg
nZf9/wBf8a6bmVjxe+/4TL+yrr7T/wAJf9s/s6b/AIQzyPtf/Hz9qvPs/wBt 8vj/AFH9m5+3
8ff3/N59Ta6vjN9R8WJo82u3krSfvNWaLUrdLS2N7CHtorJmWO4K2qzFbizZ ZGEeBtkkWST2
L+19J/6Cdl/3/X/Gj+19J/6Cdl/3/X/GjmCx5cmn69P+z/450+W51jWZbnTt Qj0tbjTbm3nd
GtMCNI7mWW6bMvmY847iThR5YjJwtbtvFF3LeajpGp+KZtMnksLfUNZ1DRLq G/aGNL5jAtta
ra3DRpNJasHhVWJnk3O8aOie3f2vpP8A0E7L/v8Ar/jR/a+k/wDQTsv+/wCv +NHMFjwvxrN4
9tPBNh9mu/Ef9pWGnXNzpV5Ho+pyy38xlkMMMlvb3DCLYiW2Gv8Azi4l/eKG WdT1/hnTtesd
a0jVzJ4je41DxVq9tqSXV5czQJYBr9rciGRjHCmYrTa6KuQVAOHIb0X+19J/ 6Cdl/wB/1/xo
/tfSf+gnZf8Af9f8aOYLF2iqX9r6T/0E7L/v+v8AjR/a+k/9BOy/7/r/AI0h l2iqX9r6T/0E
7L/v+v8AjR/a+k/9BOy/7/r/AI0AXapaj/x+ab/18t/6Jko/tfSf+gnZf9/1 /wAar3F9ZXWo
abHbXlvO4uGJWOUMQPKk5wDQBYuv+Q/4f/6/3/8ASWeutrkrr/kP+H/+v9// AElnrra6Kfwk
S3CiiirJCiiigAooooA82/aa0eHXvgnrmlXL7YJpbMycHlVu4WK8EYyFxntn NeN+HkgsLOGx
060hihjUKiRoMAAccCvd/jmM/C7Vh/tW/wD6UR15P4CSSKC/kRYMR26NK80i xgQ+agkUOzpt
ZkLKPmHLAEgEkfSZZNUcDUrKN2m/nZLT8Tkq0ViK8KTlZN79vMnea9tLbz7i 1eGIbMvJGVUb
yAvJ9SygeuRjrUTapKDgKn5Vvalef2hoWv2ev+KrXRori4u1aFBDISkiSQF0 UZZ0HmIThixO
4fJgCuNUkMI3aFmKLIrwyeZFLG2dssb/AMcbYOGwOhBCsrKOnLcX9ci3OHKz PNcs+oTUYz5l
1t0f9f8ADmgdWnz/AMsx7YFJ/a83rH+QrMMbE9P1pPLb0r0/ZR7HmWXc1P7X m9Y/yFH9rzes
f5Csvy29KPLb0o9lHsFl3NT+15vWP8hR/a83rH+QrL8tvSjy29KPZR7BZdzU /teb1j/IUf2v
N6x/kKy/Lb0o8tvSj2UewWXc1P7Xm9Y/yFH9rzesf5Csvy29KPLb0o9lHsFl 3NT+15vWP8hQ
dXm9U/IVl+W3pR5belHso9gsu5p/2xN6p/3zR/bE3qn/AHzWZ5belHlt6Uey j2HZdzT/ALYm
9U/75o/tib1T/vmszy29KPLb0o9lHsFl3NP+2JvVP++aP7Ym9U/75rM8tvSj y29KPZR7BZdz
T/tib1T/AL5o/tib1T/vmszy29KPLb0o9lHsFl3NP+2JvVP++aP7Ym9U/wC+ azPLb0o8tvSj
2UewWXc0/wC2JvVP++aQ6vN6r+VZvlt6UhRvQ0eyXYLLuaf9ry+q/lR/a8vq v5VmbG9D+VGx
vQ/lR7Jdgt5mn/a8vqv5Uf2vL6r+VZmxvQ/lRsb0P5UeyXYLeZp/2vL6r+VH 9ry+q/lWZsb0
P5UbG9D+VHsl2C3mbsl48PFxdwQuOGRo5CVPodqkZ/GoH1i3T72qWw/7YTf/ ABusjW7pvt96
iscLdSj/AMfNczfXNxkgMQM8Cuyhl8aiu3+X+RnKpys7yDV/tX/HlcxXY3iM +WrAhj0BDAHn
txzg+hqaS/EY/eahbKf+uch/UIQfwNcz8ORuubhh1+2WefzlrqfBd14Zj0S9 1DxRp91fwRSW
8EIgchlLrKT0deMJXLXoRpSmrNqNtrXd/wADWKulruVn1m2j+/qlsP8AthN/ 8bpbfVJbrYbK
WK5RyQsiAhcjls7gCMDk5HTnpWheaj8MNWsb+x0rw5q1vqH2C6lt5ZpW2I8c DyAn98f7vTBF
cl4J+XQ5XBx++vD/AOSyVnUhGNGVTkkmukrdn29DSnT5qijzXv2v5G/LdSx8 NqFoD7wy/wDx
uqsmoqgO/VLEf9sZv/jdafhy30bX7efRbi4NlrMzBrC6d/3MhxjyWHbJ6Hrn GOm1s/xdpOle
GtAGnanI134ouSkjpFL+70+PrtbHDOw7duCMAAv81LNqq6L7v+CfS08lwzly tyv/AFrtscj4
5t7HW9Jm07U7e3u7WePKuo4YZ+8vcEEexBHYivpr4Q2f9n/CbwfYeZ5v2bQr KHftxu2wIM47
dK+Zr5P+JBpzDnNvJx/23lr6k+HH/JPPDf8A2CbX/wBErXTm7VTDUqrWrOCF KNGpOEdk2b1F
FFfOmwUUUUAcLd/8gWz/AOwxF/6cRXdVwt3/AMgWz/7DEX/pxFd1UU9ipBRR RVkhVKTz21CZ
LeeNGEKHDqXAz5gB2hxjnHOBkAjJ/gu1XjbOpzpuziGM7d3TLPzjdx067RnH VsYVADpfHdsu
LYdduYGOPvYz8/PVPrtbpuG2r4riv7jwtq0GlmQX8llMlqY5NjCUoQmGyNp3 Y5yMVpUUNXVi
6c3CSkuhxHw2sdetdW1aXU7LXLOyktrNbeLVNVW9YyqJfOZSrttBynpnGcD7 q9vRRSjHlVkV
XrOtNzluzyD9qW21G58KWNvpTanJd30Wr6eLO0ml23Yk0XUHEbQodsreZFEV ypII+XGTnT8T
+FvEy3/hjT/+E58Z6nZ3mtldRlX7NbtDarYXpZS9rBEVSSQxKWb5lbyzGyPt au/u/wCyodUs
bi7+xR38nmWllJLtEr7l82SKMnk5WAOVHURZI+XIzNH8b+C9ZmtIdH8X+H9R lvJZYbVLXUoZ
WneJFeRECsdzIjKzAZIDAnAIqjI8T+KF38Qj4j1+bQR4mtL25ttVtW0+y0/V JUSGPTrr7LPH
dea1mHklitJFWCNJVeURliwl37PiDTPH2j3WsJ4Lk8TS3kOpXWmaT9svZ7qI 2p0N7mJmNyzR
t/xMSFE8mWBxDvCDy69m0rVtK1b7X/Zep2V/9juXtLr7NOsnkTpjfE+0na65 GVOCMjIq7QB5
n8C7bWLf+2Ptes61qWmt5H2b+0dK1Cz8ub955u3+0bia5fK+Tn7sQwNmXMuO s8OW0d74av7O
ZvECxT32oxO1/M8N0A11MCY3Qhki5/cspBEXlEEGtPW9W0rQ9Lm1TW9TstMs INvm3V5OsMUe
5go3OxAGWIAyepAqGyu9A8WeHWms7nTNe0W/ikhZ4pEuba5TlHQkZV14ZSOR 1BoA8A8P6t44
vbH4c6tFc+IFuzY+H4zss9Tvo9Ttphbm7uZZkl+xxNiW5VhPE8oEPmBhviKd mtt46s9G1mC6
bU72Lw/YnQrN1mujLfRzSRs+oybCslzLDafZyDCySNOt9GmC0bD1+igDwbwj L46bQbu20668
W3d/a6vNFpk8mnXVmsmmm2tXuCyam7sZRK8ogaZ3bzgACLYTqvc+Lr6SbwJe aRolx4m0dIdN
sJotTfSL2+leGWUqYdisLtptkRWQgrLGJlfcrcjurK7tb2FprO5huYllkhZ4 pA6h43KOhI/i
V1ZSOoKkHkVNQB4Zp9j8S7xLKHRre90NL/TUuYItS1e/vI7aSyubqVBLPKol H2p7jT90ciiQ
26XMbCNokFU9L0zxtrfi/RotZk8ZwaHqtzFqEyR3t5aNbQTnX7hIJXjZTE8a vp0ciBsKyQpk
gJn3+igD5t8fXfiPTvA3iufxLc+ObWLTdI1OPwxcWEmoqyTQXmoIklzJbcsv 2dNOYS3ZKsNz
hmJlY+5an4sstMW/kvtL8QLFaXy2Qa30e4uzcFoEm8yNYEdjEN5QuQAHRl64 zd1jw9oGs32n
32r6Hpmo3emy+dYT3Vokslq+VO+JmBKNlFOVwcqPQVde7tUvorF7mFbuaJ5o oDIBI6IVDuF6
lVMiAkcAuueooA+avgnoGs+GviAula7p01jdw6dpsTLIMqxj0ezhcowyrqJI 5E3KSMowzxXp
X9pXtrHBaWLXks01xeslvbvtLYu59zHJCqAMZZiB0GckA2fE3/Ja9N/7BP8A 7NNXO6z4js/C
2o2epXmDvi1OCBWbYjStfkgM/RRhWJPJwpwC2BXBmFWdKjKUFrp+djWklJpM 1n8UPayNBqmq
T6ZcqfmgvLoI+PUfMQw91JGcjqCBfl1x7awk1C51dobSKIzSTyXO2NIwMlyx OAoHOemK88Pj
e4mkJj8fTNM5+WCzt7Y5Y9EjUxMx5wFBLHgDJIzWx4d0m+svCN1aazHLrETW xjj0p47dsQhC
ogJwiOzDg7jt5xnALHzcux1XEtqaaS62a/OxtWpKn1Ok8OeLRrvn/Y5Ndi8j bu+3add2ed2c
bfPjTf0OduccZxkVryapcQy28b3F4xnkMaFFkcAhWbLEAhBhT8zYGSBnLAHx mTwz4uulS70W
PW9Fjs7uCTT7bWb5NQuoZ5Ibq1uLre80o8tI7qKURGQ7jbOoRfM3nK8XfDDx NLpuoWelWv2u
G2t5tK0yPzI0zZJpmqLbHLPn5X1CO1+b5j5HmscOdvr/ADMD6IS6uj/y8zf9 9mn3GpLZWVxe
31+tta28bSzTzTbEiRQSzMxOAAASSeABXiHjfwvp/hnUbnUBoGkW3gG2+wXF /pKva2tpeSYv
4pMxStHAXEk2nuTIVDeSmCzRqtbPw+0KTWfglb2ukWEOlD+3ZtW020lCJF5U WsPeW8e6Lcix
uiIokj3qFcMocYBXzA9I8N+KbbX/AD/sK65D5G3f9v0q7ss7s42+fGm/oc7c 44zjIzr+fP8A
89pP++jXmvi7+2PFlhYfbvh7rB07T9RWe/0e/lsJP7VhME6BFQXDRP5czQSk Ssg+QMu5lArk
Lf4ZatPczXl/4as5GP8AZkVgspgd7KwOs3ktzZA5IREsJ44XjQmNlBjUuoxV fMD3nz5/+e0n
/fRo8+f/AJ7Sf99Gvm6XwjqE3iXxLoH/AAhn2zWl0bydA1EG12+H0k1LV/sU qO8gkhRIzAyi
BWZFiACgqq1seM/AXiPUbDxBaaf4Yxrlx/bT3Gu+bbr/AGra3MF4trZeZv8A ObYZ7QbJVWJf
s3DYSPcW8wPefPn/AOe0n/fRo8+f/ntJ/wB9GvEfHnw1ujqVzZeGtC+xeEj9 guLjStHhsUW8
lVb9JttvcD7MzhpLB2MqgFYVKkvGgFRfhdqB0LxBO3h77Rq8PhVLfwzcX0tr JeWV4J9RljSK
SNUS2eMTWoHlBY49qqjsIw1HzA9t0jWoNWtHutPvZJoUuJ7Zm+ZcSwyvFIuD g8OjjPQ4yMjB
q558/wDz2k/76NeI6p4Elh0LWbEeCby5vpvEU+pTXFjBp0tvrKSz3U0CXUdx KhnhiEyKyPsY
OFMTfKJB6z4Wtbqx8M6VZXttptrdW9lDFNDpyFLWJ1QBlhU8iMEEKDyFAofq Bq+fP/z2k/76
NUdUkke70wPI7D7UeCc/8sZKtVS1H/j803/r5b/0TJU3Ywuv+Q/4f/6/3/8A SWeutrkrr/kP
+H/+v9//AElnrra6KfwkS3CiiirJCiiigAooooA4z42/8kz1P/rpbf8ApRHX lXhO9tNJW7vL
q0F0Rauqxnd8wOBIAFBJYx71UYI3Fc4HI9U+N2f+FZapjr5lt/6UR1594V8D +INa0W31Wzut
Ojgm3bFldww2sVOQFI6j1r6TLZ044GSqOycmvwRwYlT9rFwV2jH07XtFkjhh 1mbV7xIIvLgV
fD7wnOCgMkoidvljOMooJLMcZANRXcdlc6pcT6Z5x0/y447Xzo2jaJFX/Uor BT5aEkKSqEks
SpJMknaj4beJsc3uk5/66Sf/ABFI3w18T9r3Sf8Av5J/8RXRRq4KjLmjP+vu Ma8sTXjyyicR
9lPvR9lPvXZn4ZeKCf8Aj+0n/v5J/wDEUf8ACsfFH/P9pP8A38k/+Irp/tDD fzo5vqtbscZ9
lPvR9lPvXZ/8Kx8Uf8/2k/8AfyT/AOIo/wCFY+KP+f7Sf+/kn/xFH9oYb+dB 9VrdjjPsp96P
sp96p/G9PiR8PtO0JPC3gK38ZXd9NdG8eCxvbtbdEEHlD9wybSxaX7wOccdD XWa38PfiS2s3
x0jT/CI043EhtPO1q4WTytx2bgLRsNtxkbm57nrWKzfDczi5bdbafgX9SrWu c/8AZT70fZT7
1q/8K8+LP/QP8F/+D25/+QqP+FefFn/oH+C//B7c/wDyFVf2rhP5/wAH/kL6 lW7f195lfZT7
0fZT71q/8K8+LP8A0D/Bf/g9uf8A5CrF8Gjx94l+K/jHwlf/AA+h0HQ9P+1f 2NrEtlfQrceX
dxpHmWR2jffCXb5V5xkYAqZZvhk0lK9/Lb1vYawNazbJfsp96Psp967P/hWP ij/n+0n/AL+S
f/EUf8Kx8Uf8/wBpP/fyT/4itv7Qw386I+q1uxxn2U+9H2U+9dn/AMKx8Uf8 /wBpP/fyT/4i
j/hWPij/AJ/tJ/7+Sf8AxFH9oYb+dB9Vq9jjPsp96Psp967P/hWPij/n+0n/ AL+Sf/EUf8Kx
8Uf8/wBpP/fyT/4ij+0MN/Og+q1exxn2U+9H2U+9dn/wrHxR/wA/2k/9/JP/ AIij/hWPij/n
+0n/AL+Sf/EUf2hhv50H1Wr2OM+yn3o+yn3rs/8AhWPij/n+0n/v5J/8RR/w rHxR/wA/2k/9
/JP/AIij+0MN/Og+q1exxn2U+9H2U+9dn/wrHxR/z/aT/wB/JP8A4ij/AIVj 4o/5/tJ/7+Sf
/EUf2hhv50H1Wr2OM+yn3o+yn3rs/wDhWPij/n+0n/v5J/8AEUf8Kx8Uf8/2 k/8AfyT/AOIo
/tDDfzoPqtXscZ9lPvR9lPvXZ/8ACsfFH/P9pP8A38k/+Io/4Vj4o/5/tJ/7 +Sf/ABFH9oYb
+dB9Vq9jjPsp96Psp967P/hWPij/AJ/tJ/7+Sf8AxFH/AArHxR/z/aT/AN/J P/iKP7Qw386D
6rV7HGfZT70fZT712f8AwrHxR/z/AGk/9/JP/iKP+FY+KP8An+0n/v5J/wDE Uf2hhv50H1Wr
2OE0jUPDNp4y1g+KbG4vbPzp1SOFsMJPN4P3l4xu796rfEC/8E3y2n/CK6Zd 2Gzf9p+0OTvz
t24y7dMN6dR1r0ST4X+IpX3zN4bmfABeWEOxx0yTESaYfhXrh6xeFT/26L/8 areGa4WNVVOd
3XTmdtu1rClhK0oOFvw1+884+Fy+ZdXjDot3ZnP/AH9pvh7UtI/4R6703VLi 7t/NngmR4IFl
/wBWsqkEM6Y/1g9ehr0xPhh4ljUJDcaFAgO7bCGjXPrhYwM+9I/wu8QO7PIP DMjscsz24ZmP
qSYsk+9Oeb4WU5ycl71uu1vkEcJWSStseb2114W057m7g1LVLiY2dzBHG+nx opaWF4xlhMSA
N+eh6UngkFvDF3IBwJL3B/7dkr0c/CrWz1h8Kn/t0X/41UifDLxRHsEN3o0K p9xYiyKv0AjA
FZ4jNMNWpShz6vq/n2S7l0MNVpVFO23T7vXscX4R8Taf4f0y5u7W0MmvufLt rmTDR20ZHzMq
936jnjB9MhoPEXimy17wuttrVvJca3ZlUs9QRhmSLPKTZ5bHY9cnPHzbu2Pw t8REnjwsfrar
/wDGaP8AhVniLpjwt/4Cr/8AGa+Wlg6b/wCX0fx/yPq45pBS53Sd/U8wki3e GNPYj/l3k/8A
R8tfS/w4/wCSeeG/+wTa/wDola8U+IPg3XPDmijUNRudPlhkcW6rblsqdrEY BUADCnp7V7V8
Nju+HXhpvXSLU/8AkFa9DMnD6lSUJXS0v8jyYTc605NWu7/eb9FFFfPm4UUU UAcLd/8AIFs/
+wxF/wCnEV3VcLd/8gWz/wCwxF/6cRXdVFPYqQUUUVZIVSk89tQmS3njRhCh w6lwM+YAdocY
5xzgZAIyf4LtV42zqc6bs4hjO3d0yz843cdOu0Zx1bGFQA6Xx3bLi2HXbmBj j72M/Pz1T67W
6bhtq+K4r+48LatBpZkF/JZTJamOTYwlKEJhsjad2OcjFaVFDV1YunNwkpLo cR8NrHXrXVtW
l1Oy1yzspLazW3i1TVVvWMqiXzmUq7bQcp6ZxnA+6vb0UUox5VZFV6zrTc5b s4b4mXbaZ4o8
CamLnU44l1e6huYbSSd1uIf7MvZSjW8efOYPBGyjazAr8vLEHzmbwxrfib4n 3/ijSNOvbF5v
7R1LQL7ULOa1EdzHBoUUazK6CWFJXtbqJ1Kq8kPnbcqwY+2a1d6BpU0Or61c 6ZYyxxTQw3d3
IkbKmzzpUV2xhdkHmMAcYh3HhMgTxDoEk2lQprmmNLrMTTaWgu0LXyKgdnhG f3ihCGJXIAIP
SqMjwDUvCfiPw3qup6Rpt74g07wyNXkknv49N1G7uL+5/s3S1jnf+zpYLh2k Zb5nlyYjIH3j
eUI6bR9K8aQLe+INRu/Ftx4htvEGh2qebPMkElq8GmJev9jike125kvSzIHV GDlXygYe2UUA
fNviW78V6j4X8HaLPF45S+0TSLJfEU8ej3czLew6no5aZGeF47uVFiu3V0Ew IDsNysc6eoQ6
+2j3oU+JodN1PW3vB4hl0rVP7QujHZ2sKCey05raePcROgbZHEFtIyyM8qSt 7/UL3dql9FYv
cwrdzRPNFAZAJHRCodwvUqpkQEjgF1z1FAHmXwDh8XX0GoeIfG134g/tGaKw RLO9DQQRl9Ls
HuHSHaoDG480HghGSQIELS7+68Pf8hfxH/yGv+Qkn/H9/qf+PS3/AOPX/pj6 /wDTXz62aKAP
mbxLe+M4fBMq6Fd+Jhc6Nc65/Yt3FDq2ry31xFqV3HFbSfZ5gq+UsFuA14sy OJcBSEkDemyw
eOLHxPqdtax3uqWGi/bNc05DePE+qS3KSCCweZx5ZSOVrzKYAjQaecnD16NY WlrYWNvY2NtD
a2ltEsMEEMYSOJFGFRVHCqAAABwAKmoA8A8Gv4zi/tyw0zUfE2oSx/YJtAmu 9J1aytxfv9rE
y3B1GWWR7URJEZPn2gMPJUXBQt6NHqN1D4KOmWTeLbHUJ9I1C4/tW/003k9l cxsqsZI1yskp
klLxxRAxSLEwi/dhAezv7u1sLG4vr65htbS2iaaeeaQJHEijLOzHhVABJJ4A FTUAeDaPp3ji
9sdOtdOXxBpthqMt7o0t5NqWpvK6Si0c6kEvMz2TLFbXscSyFhHPJFgyJKZD S1O2+J+p6nbS
6q3iCCLU74RXsGlTXkEVuI7/AEK1nMZUhoon8jUpomDAmCV3yC0gH0NXP6n4 38F6XfX9jqfi
/wAP2V3p0SzX0FxqUMclqjFAryKzAopMkYBbAJdf7woA8q0C21HTvjpqmk3L am+nWJWLSXv5
pZ5Gt2tY5GImlLSSr58k43MzYIKAgIFHRxxhoczXvl/6Td7FW034X7XN1JkG TnPbpirXib/k
tem/9gn/ANmmqjBbJqOsWemzyTJbMNRuJBFIY2cpfOoUsCGC/vCTtIOVHONw PFja8aFOVSXS
xpTjzOyLSQxdtRb/AMAP/ttSpCM8aieP+nD/AO21zE2r6LbzumleILo2mcp5 ui3l6P8AgEy4
3ocZBy3Xg7cBZNJ1261zw1ePoiQprkFrtEd7bzR28V2Y8qjkqCVDYzt52kHu K48LjqeIfLFW
aNJ03Dc6pIWHTUR/4Af/AG2pkhm7ajGf+3A//Ha8p07xsfC1x5Pie88TM7yb rqPW0st9jai1
vLgXCfYYysgb7HKmwsWGzOAMb49b+L0llbRXI0WVJrOze6vbVLxceeltqrTW jMYjuEcumsnm
JjcSGBKgq/dZ9jO57CkNz21GH/wAP/x2p4ob3BC6jb/jYH/47Xn8njnW7TV0 8M3fhzTl8Szy
QC0hi1V3snSWO6kBecwB0IWxuMgQsM+Vz8zFL0XjXU5fh2dc/syzstUfWRov k+e1xBDMdS+w
ebnbG0iBv3m3CFgNuVzuCtrsB2vk3/8A0Ebb/wAAW/8AjtHk3/8A0Ebb/wAA W/8Ajtcneza1
4SWztU1rUvFmpa1erZ2EWryW1rDC6wzTuWktrYMoMcL/AMEhLBAAoLMMKT4q ans1e7h8L2bW
Ph7Tnvdcd9VZZY/KubyCdbZBARNg2MpQu0W4MmQmTirAek+Tf/8AQRtv/AFv /jtHk3//AEEb
b/wBb/47Xnmk+NvEVp4S1nVdTs9NvJE12/sNGQXM5mvRFfXEflmGC1d1McUW R5azFljZn2AM
wzdM+K+p6vrVlaaJoHnXmoeRai01G+a0ggmVtVE7Z+zGYc6awG9QSGTKRMHD OwHqvk3/AP0E
bb/wBb/47R5N/wD9BG2/8AW/+O15hf8AxiniuktLLwdqWo3VrHI+qQ2kV1cF DHdXFsyW5ht5
FkJktJ9vnG3DDyzkZcR6Vz8SNTj0K+1ceFfKtodZuNJguJ7xvs48ie4jlurh 4opDb2wEA/eM
pw7EMEjAmYt5Ad75N/8A9BG2/wDAFv8A47R5N/8A9BG2/wDAFv8A47TNEvP7 R0Wx1DfZv9qt
45t1ncefA25QcxyYXzE54bAyMHAzirlSBW8m/wD+gjbf+ALf/Haq3cdyt9pp mu4Zl+0thUtj
Gc+TJzku35YrzT9obxh4n0mG28M+GrB1u9Xkt4LXUILzZJFPJIwSMjGI9xRc O5If94oU7TXe
aEniCPSNAj8UyWEuspOy3Ulju8mQiOUBlDAEErgkYwCSBxg10zwzhRjVbWr2 vr6kRqXm422N
W6/5D/h//r/f/wBJZ662uSuv+Q/4f/6/3/8ASWeutpU/hHLcKKKKskKKKKAC iiigDi/jd/yT
LVP+ult/6UR1P8H/APknWl/9tv8A0c9QfG7/AJJlqn/XS2/9KI6n+D//ACTr S/8Att/6OevT
/wCZb/2//wC2mH/L/wCX6nmfw78V+Nm8DeHvE/iC48czjVItGDTXv9iR2Mj3 d5aRs0It0acK
RM+FkUHyywykm1lm+FHxY1K50fwhoZ8Pa1rW3TdItdU1MQ3k8v2m4s7eUyll t2gKKLiN5Hlu
I3AEh2NhPM9aj8LaFH4Y0zwyljjSdL+x/Y7fzX/dfZXje3+bO47WijPJOdvO QTnM074ceD9O
m057LTJoYtPit44LZb+4+zMYEVIJJYN/lzSoscQWWRWceVGQ2UTHmG51lef/ ABp1TxBp8XhW
08Oz61FNqetm1nXSEsjdyRCyu5tqG8Hkj5oUYlsHapA5OD6BWN4s8MaR4ot7 OHV0vf8AQrn7
VbS2d/PZyxS+W8e5ZIHRxlJZFIzghjmgDzL4meJvFml/DTxPomjre3Wrab4R l1XUdS1fUYrO
9s1nS58ry/scLRSTRm3lBCmNRsjw7FmZdP4deL/FGvfErWdMWOG40KzikEzX V2qz2zrqeq2w
aJY7cCVXFpEu12UoqDmRizN0Gr/DHwhq2ljTtQh1qaE2z2kzf2/fLLdQMzsY riUTB7hAZJNq
yswUO4UAMQdPTvBvh3TtWi1XT7Oa0u45biVmhvJkWYzyyzOJlD7ZlEk8zosg YRmRigXNAGZ8
Q/8Akbvhx/2Mk3/pp1GofjK2uW2hadfaH4o1PQ5f7X0+ylFpBayLMl1fW9u5 bz4ZMMqSOV24
GT8wYACsX47+N/B/grXfAd94t8Qw6RFBq9xeqJLa4maZFsbi3YJ5Ub4YPdxH 5toxuwSRivRt
Z0uw1izjtNRg8+GO5gulXey4lgmSaJsqQflkjRsdDjByCRQBxk3ja/0rVJbB tP8A7R0nSNSs
NC1LVLi8VL2S8uVthG626QiJ0Ju4C7b48Zl2xkKofmdc+I+q6tovh1xp39kQ +IbnSNU0a4td
RaSWWxOq6ckqXK+Wghdo7yIFEaVSGlUtgDf6Ne+DfDt54iXXp7OZrvzY5njW 8mW2mmjx5c0t
uHEMsq7I9sjozL5ceCPLTbTtPhx4PtmzHpkzKksElvHLf3EkdoIZ45447dGc rbxCSGE+VEEQ
iKMFSqKAAQfDLxtN4x/tBp9PstLe28php73kh1K2WTeVF7ayQxm2cqoIAaRW 5KsyhWY0j/kt
/ij/ALFvRv8A0p1Strwx4Y0jw79obTkvZJrnaJrm+v5724dVzsQyzu77FLOQ m7aC7kAFmJ4X
wP438H+Ifj74u0zRfEMN5qltpFrZXNiLa4SSB7K6u1nJZ4xGVDXcSjazEkNx gZIB6nRRRQAU
UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAebft
Ff8AIi2//X8v/oqWuo+Gf/JOPDH/AGCLT/0Slcv+0V/yItv/ANfy/wDoqWuo +Gf/ACTjwx/2
CLT/ANEpXqVf+RfD/EzGP8RnQ0UUV5ZsFFFFAHC3f/IFs/8AsMRf+nEV3VcL d/8AIFs/+wxF
/wCnEV3VRT2KkFFFFWSFUpPPbUJkt540YQocOpcDPmAHaHGOcc4GQCMn+C7V eNs6nOm7OIYz
t3dMs/ON3HTrtGcdWxhUAOl8d2y4th125gY4+9jPz89U+u1um4baviuK/uPC 2rQaWZBfyWUy
Wpjk2MJShCYbI2ndjnIxWlRQ1dWLpzcJKS6HEfDax1611bVpdTstcs7KS2s1 t4tU1Vb1jKol
85lKu20HKemcZwPur29FFKMeVWRVes603OW7PIP2pbbUbnwpY2+lNqcl3fRa vp4s7SaXbdiT
RdQcRtCh2yt5kURXKkgj5cZOcXx18P8AxRot7Zal4TWa91Gxvr6HwuiBZE0u 3fSdReNMOojh
U3c6QgcR+VBZIeU59m1q70DSpodX1q50yxljimhhu7uRI2VNnnSortjC7IPM YA4xDuPCZAni
HQJJtKhTXNMaXWYmm0tBdoWvkVA7PCM/vFCEMSuQAQelUZHifhnQ/EuoX+ka dNrvjO+8PT63
H9qZbbWNIaMLYX7PmW6unvNhkFnnLJDuEYTc7SgGqan420Xwp44gu4/Gcs13 ol7pnhk2tleX
cqz297qkcLbolZo3MD2BE8pUygK29yrEe/0UAY3iH/kL+HP+Q1/yEn/48f8A U/8AHpcf8fX/
AEx9P+mvkVwvxXuNXsvHVoNHOp3DX3hbUo7i2hu7ny0VbvT0+0rBE6s0sMdx O4EO2aQDYrBi
mPTUu7V76WxS5ha7hiSaWASAyIjlgjleoVjG4BPBKNjoaEtLVL6W+S2hW7mi SGWcRgSOiFii
FupVTI5APALtjqaAPDPCMvxGs9Bu9U0q61PVZbDV5tL0+DVtO1K2int7q2tf LuGguXe5ZYb0
/NLJI2yD7Xs48tVm8Ux+LdH8ceHrLTL3xM39l3Ok6bC8lpqV/wD2rZGWFbm6 uJ4pBZRPskuF
fz4Wk/deYGXfEU9tt7u1uZrmG3uYZpbWUQ3CRyBmhcorhHA+62x0bB5wynoR U1AHmfhXUNV0
n+1dU1Oy8Z39jZ6bNcaBayRNJNPZJhmjkTIZr1mChBcESGIxD/XfbKxfHen+ LdW8fa9pehXu
tT3N7ptxb2N15upaZaaCWsWWOTeg+y326dwcqPOiZ8jeI/3Xs1FAHgHjP/ha eo+HtQ1Gw/tq
z/tTTdR1+1t7b7THc2eNPubaGxZR/q5j52mzCEZ/0iK9cH5Ywbmo6Z4+sNDl 1jwvJ4mfxRqO
t+IbbZd3s81ukAXU2sSILhjbwp5kVjskCqCCoztkIb3Oobi7tbaa2huLmGGW 6lMNukkgVpnC
M5RAfvNsR2wOcKx6A0AeTfDzW7Cw8deJodFj8c3+lpY6Gq2mqjUpJ4pri7vI ZJlS/PmLEFET
O6/KFiY8lSKpfGCxbxv4r0yGz8PanqOnaZLFYaql3pE8cMgk1rSXIUSoFuIv KtbhmePegVMs
QGXPrPhvw9oHhqxex8OaHpmjWkkpmeCwtEt42cgAuVQAFsKoz1wB6Vp0AeIe HtA1Xw78T7Oz
1jW73V7lrJtk1zdNORBHvhg+ZgDvaKKOSXsZpJmHDABnimzbU4oo7XXILF45 b6G5jdBIssb3
kjGNxuU4O1CRnkcHIJB1n8Q6B4l+LthfeHNc0zWbSPTjC89hdpcRq4MpKFkJ AbDKcdcEetdZ
4S2jR7hyisRqN2Bkn/n5m9PpXNiKcaicZK60NItrVHl6aXqbkLN4u08Rnh/K sgj477WMhAPo
SDj0PSukgi0WLSG0qG5jgtTE0WIboxuAwO4iRWDhySTvBDZOc55rpk8WaI4Q xpcOHXchWxuT
vXj5hheRyORxyPWprbxHpNxeQ2ixyxzTsViE1pPEHYKWIBcAZ2qxx6A1yYfB 0MPf2UVG/ZFz
qyn8TucNYeHfB9rayW5lNz5lxb3DzXmqTXMzNbyrLCPNlkZ9iSDcE3bcs3Hz NmfV/DngfWI7
2PUo7SdL64kubgfbWXfI9mbNm4YYzbkpgYH8X3ua9G8xP+eEf5t/jR5if88I /wA2/wAa6beZ
B514w0LQNdiu7q11HTbPWpo7eOO/eeXMIhaQqV8maJ0O2eddyOhIlIYsuVq9 4K0jw7oPgkeF
rvVbLVbeT7Q139rmEi3DXEjyzBhIzsyFpHADs7bcBmc5Y9v5if8APCP82/xo 8xP+eEf5t/jR
bzA4VPDHggWUtq+r6hOryJKktx4nvJpoHUMA0Mrzl4SVd1YxspZWKtkHFTJ4 d8Appupacv2L
7Pqmnf2bfA37FriDdMxDsX3F2a5nZpM72aQszE812nmJ/wA8I/zb/GjzE/54 R/m3+NP5gcXd
+H/A1z9s3XQi+1XAuj9n1iaHyJvn3SwbJB9nd/Mk3tFsMnmPv3bjmHRPCvw9 0a9tL2waAXVp
J5sU02qyzPvJuiWZpJGLkm+uiS2STLz91cd15if88I/zb/GjzE/54R/m3+NH zA4W68K/D25b
MjQKryTSTxxarLGl2JZpJ5EuEWQLPGZJZT5coZAJXAUBmBuXWk+EJ9I/spNT ks7U3s18RY63
PaOZpZJJJCZIpVchnldtuduSMDgY67zE/wCeEf5t/jR5if8APCP82/xo+YGR Y3ugWNlBZWV3
plra28axQwwyIiRIowqqo4AAAAA4AFTf2vpP/QTsv+/6/wCNaPmJ/wA8I/zb /GjzE/54R/m3
+NKwGVFqOhxPK8V9pyPM++VllQF22hctzycKoyewA7VHcX1ldahpsdteW87i 4YlY5QxA8qTn
ANbPmJ/zwj/Nv8aprO76vcQ4VY0giZVHqWkBPr/CPyosMiuv+Q/4f/6/3/8A SWeutrkrr/kP
+H/+v9//AElnrra6KfwkS3CiiirJCiiigAooooA4v43f8ky1T/rpbf8ApRHX k/wj0XUvE0Hi
F28V6npsNhq4tIILax0+RQn2S2lJLT20j5LSt/FjpgCvWPjd/wAky1T/AK6W 3/pRHXA/s4/8
eHjH/sYh/wCm+yrvqu2Wf9v/APtph/y/+X6m7/wr+9/6H7X/APwV6N/8g0f8 K/vf+h+1/wD8
Fejf/INdxRXh8zOg4f8A4V/e/wDQ/a//AOCvRv8A5Bo/4V/e/wDQ/a//AOCv Rv8A5BruKKOZ
gcP/AMK/vf8Aoftf/wDBXo3/AMg0f8K/vf8Aoftf/wDBXo3/AMg13FFHMwPP te+D/g3xTptn
ZeOILnxUbGaaW0munW0eHzVjDqBZLAjA+UpyyluvOOBS174K+GtY1y/1e4uo 1mvrmS5kH/CO
aJJhnYsfnksWduT1dmY9SScmvTqKfPLuB5J/woTwp/z9x/8AhL6B/wDK+j/h QnhT/n7j/wDC
X0D/AOV9et0Ue0l3A8k/4UJ4U/5+4/8Awl9A/wDlfXRQ/CnwZYa9rviPQLCX Q/EGu+Z9u1O3
lM8jeZOk8mIrnzYBudB/yz4H3cV3NFHPLuBw/wDwr+9/6H7X/wDwV6N/8g0f 8K/vf+h+1/8A
8Fejf/INdxRS5mBw/wDwr+9/6H7X/wDwV6N/8g0f8K/vf+h+1/8A8Fejf/IN dxRRzMDh/wDh
X97/AND9r/8A4K9G/wDkGj/hX97/AND9r/8A4K9G/wDkGu4oo5mBw/8Awr+9 /wCh+1//AMFe
jf8AyDR/wr+9/wCh+1//AMFejf8AyDXcUUczA4f/AIV/e/8AQ/a//wCCvRv/ AJBo/wCFf3v/
AEP2v/8Agr0b/wCQa7iijmYHD/8ACv73/oftf/8ABXo3/wAg0f8ACv73/oft f/8ABXo3/wAg
13FFHMwOH/4V/e/9D9r/AP4K9G/+QaP+Ff3v/Q/a/wD+CvRv/kGu4oo5mBw/ /Cv73/oftf8A
/BXo3/yDR/wr+9/6H7X/APwV6N/8g13FFHMwOH/4V/e/9D9r/wD4K9G/+QaP +Ff3v/Q/a/8A
+CvRv/kGu4oo5mBw/wDwr+9/6H7X/wDwV6N/8g0f8K/vf+h+1/8A8Fejf/IN dxRRzMDh/wDh
13FFHMwPAPi1Yap4c17SdIbxPqOq2Op2N5czQ3VpZRBZLdoFjZfs8ERzi5lB znOR6Cve/hn/
AMk48Mf9gi0/9EpXiv7Rn/I6+FP+wTq3/oyxr2r4Z/8AJOPDH/YItP8A0Sle 69ctp/4mYr+K
zoaKKK881CiiigDhbv8A5Atn/wBhiL/04iu6rhbv/kC2f/YYi/8ATiK7qop7 FSCiiirJCqUn
ntqEyW88aMIUOHUuBnzADtDjHOOcDIBGT/BdqvG2dTnTdnEMZ27umWfnG7jp 12jOOrYwqAHS
+O7ZcWw67cwMcfexn5+eqfXa3TcNtXxXFf3HhbVoNLMgv5LKZLUxybGEpQhM NkbTuxzkYrSo
oaurF05uElJdDiPhtY69a6tq0up2WuWdlJbWa28Wqaqt6xlUS+cylXbaDlPT OM4H3V7eiilG
PKrIqvWdabnLdnkH7UttqNz4UsbfSm1OS7votX08WdpNLtuxJouoOI2hQ7ZW 8yKIrlSQR8uM
nOL46+H/AIo0W9stS8JrNe6jY319D4XRAsiaXbvpOovGmHURwqbudIQOI/Kg skPKc+za1d6B
pU0Or61c6ZYyxxTQw3d3IkbKmzzpUV2xhdkHmMAcYh3HhMgTxDoEk2lQprmm NLrMTTaWgu0L
XyKgdnhGf3ihCGJXIAIPSqMjxPwzofiXUL/SNOm13xnfeHp9bj+1MttrGkNG FsL9nzLdXT3m
wyCzzlkh3CMJudpQDVNT8baL4U8cQXcfjOWa70S90zwybWyvLuVZ7e91SOFt 0Ss0bmB7AieU
qZQFbe5ViPf6KAPP/DqW0Hx78YPb6Re232zRNL828/suaO3up4ZLvf8A6QUE cjrHNbDhicDa
P9WwXp7P/keNU/5DX/INs/8AW/8AHh/rbr/U/wDTb/nr/s/Z6mt/EOgXPiK5 8OW+uaZNrVrE
JrjTo7tGuYUO0h3iB3KvzpyRj5l9RWnQB4N4qk1p9V8WaNBe+IItLi8UtJ9v h/tbUZLRjpth
KtssNjPHcLE7XFxIDv8AJjMe3bl49u14Oh+Id+vha31i71OOLW7HTdc1i4lE kM9ncW0EQubQ
AKEhWaZbQ+Tt+ZTqOdp2CvUtK/sqP7XZ6X9iT7Pcv9qhtto8qeTEz71Xo7ea JDnk+YGP3sm7
QB4B4fu/FsnizUm1AeM7eC/024urzT7HT9SD6dqQurX7NBDdXcr2021pJ13Q iK1dEZpVMONn
pngnUNVs9PtLfxBZa1ca7fak9vqcixM9pbzi3aXzIiTtSyKxokZXJ3Ogl/fm Y12dFAHgGh/8
LCh0/wDtHR/7a1S9s9Sg36lqX9qW0erzT291bjfplxzbQwz3NrNL5P7oxozp taIRJS8caf8A
FOx0rUrewvfE1z/ZltNpFrJaS3LzXXk6Vq8sN2SB87v9o01HkGN11CwAGyMn 6MqG4u7W2mto
bi5hhlupTDbpJIFaZwjOUQH7zbEdsDnCsegNAHj/AIm0zWNC8TyaPbSeM5fA 6/YLnUngvdQv
Lv501JZBDOrPdnE0Wm7o4W+VTkgI8pba+D/iRI/BMSzQ+Jr62Fzr08V3c29z cyxW9rqUkccE
vmZuDMY2UJGylyInGMrg9/rek6VrmlzaXremWWp2E+3zbW8gWaKTawYbkYEH DAEZHUA1PYWl
rYWNvY2NtDa2ltEsMEEMYSOJFGFRVHCqAAABwAKAPCvDCzXHx613XDZ3ttZa zKl1Y/bLWS2l
kiSyht2ZopVWRP3kEoAdVJChhlWUn0rwp/yA7n/sJXX/AKUTVyj+IdA8S/F2 wvvDmuaZrNpH
pxheewu0uI1cGUlCyEgNhlOOuCPWur8Kf8gO5/7CV1/6UTVjU3LRV8IW8txp XhNIb24s2GjT
HfCqFiN1vx86sMfhnik8Y2dxbeJfCLTareXgOozALMsQC/6HPyNiKaqafo/i zTxZR2XiTSli
srdraAPpDsRGxQ/MfPGT8i84HfirJ0zxBe6tpt5rmt2F3Hp8zzxR22nNAxdo nj5YyvxhycY6
gc+sXVrCSZ5R+03/AMIzqFtN9g/se78UaZp2p/b/ACPLe+tLI6Nf483H7xIT JNF97C7pE7sM
6/8AwjOt+Dr7QtM0S78IaE3iDWVtLqfQPCqWTGFLG9lYMHmlDuCilGIwjDLL IpZD69RS5irH
z98Svib4j0jxBrg0jXrO3xb6pBFpV1e273tm9tYXMyXItBbiREeS2V1eSaVW jmU7B5i+Xr67
4p8beHLnVk0/VbzxFc2Go3OkWlpd2cLG6ddFfUo5GW3jjZpjLthAQqpjwNnm fvK9qop3XYLH
nPwV1zW9Y/tZNS8S6P4js4PJNvd2F+l9tkbzPMjaeG1t4eAsZEYVpF3Eudrx ivRqKKljCiii
gAooooAKKKKACqUP/Iduv+vaH/0KWrtUof8AkO3X/XtD/wChS0AF1/yH/D// AF/v/wCks9db
XJXX/If8P/8AX+//AKSz11tdFP4SJbhRRRVkhRRRQAUUUUAcX8bv+SZap/10 tv8A0ojrgf2c
f+PDxj/2MQ/9N9lXffG7/kmWqf8AXS2/9KI64H9nH/jw8Y/9jEP/AE32Vd9b /kV/9v8A/tph
/wAv/l+p6rRRRXhHSFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQA UUUUAFFFFABR
RRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAHiP7Rn/I6+FP8A sE6t/wCjLGva
vhn/AMk48Mf9gi0/9EpXiv7Rn/I6+FP+wTq3/oyxr2r4Z/8AJOPDH/YItP8A 0Sle9/zLaf8A
iZgv4rOhooorzzUKKKKAOFu/+QLZ/wDYYi/9OIruq4W7/wCQLZ/9hiL/ANOI ruqinsVIKKKK
skKpSee2oTJbzxowhQ4dS4GfMAO0OMc45wMgEZP8F2q8bZ1OdN2cQxnbu6ZZ +cbuOnXaM46t
jCoAdL47tlxbDrtzAxx97Gfn56p9drdNw21fFcV/ceFtWg0syC/kspktTHJs YSlCEw2RtO7H
ORitKihq6sXTm4SUl0OI+G1jr1rq2rS6nZa5Z2UltZrbxapqq3rGVRL5zKVd toOU9M4zgfdX
t6KKUY8qsiq9Z1puct2eQftS22o3PhSxt9KbU5Lu+i1fTxZ2k0u27Emi6g4j aFDtlbzIoiuV
JBHy4yc4vjr4f+KNFvbLUvCazXuo2N9fQ+F0QLIml276TqLxph1EcKm7nSED iPyoLJDynPub
2lq99FfPbQtdwxPDFOYwZERypdA3UKxjQkDglFz0FTVRkeAeGdD8S6hf6Rp0 2u+M77w9Prcf
2plttY0howthfs+Zbq6e82GQWecskO4RhNztKAapqfjbRfCnjiC7j8ZyzXei XumeGTa2V5dy
rPb3uqRwtuiVmjcwPYETylTKArb3KsR7NqvizwrpOh2mu6p4l0Ww0m82fZb6 5voo7efepdNk
jMFbcoLDBOQCRxRqvizwrpOuWmhap4l0Ww1a82fZbG5voo7ifexRNkbMGbcw KjAOSCBzQBxm
hX+nax8Q47S50PWtJi0fUrx9KtB4fu4beS6ImWe+luREID5gkn8tQ5VhKXct JIiQ9nZ/8jxq
n/Ia/wCQbZ/63/jw/wBbdf6n/pt/z1/2fs9bNQvd2qX0Vi9zCt3NE80UBkAk dEKh3C9SqmRA
SOAXXPUUAeGeKpNafVfFmjQXviCLS4vFLSfb4f7W1GS0Y6bYSrbLDYzx3CxO 1xcSA7/JjMe3
bl49u14Oh+Id+vha31i71OOLW7HTdc1i4lEkM9ncW0EQubQAKEhWaZbQ+Tt+ ZTqOdp2CvWbK
0tbKFobO2htomlkmZIowil5HLu5A/iZ2ZiepLEnk0Pd2qX0Vi9zCt3NE80UB kAkdEKh3C9Sq
mRASOAXXPUUAeDeH7vxbJ4s1JtQHjO3gv9NuLq80+x0/Ug+nakLq1+zQQ3V3 K9tNtaSdd0Ii
tXRGaVTDjZ6Z4J1DVbPT7S38QWWtXGu32pPb6nIsTPaW84t2l8yIk7UsisaJ GVydzoJf35mN
bXhjxZ4V8UfaP+EZ8S6Lrf2bb9o/s6+iuPK3Z27tjHbna2M9cH0rZoA8A0P/ AIWFDp/9o6P/
AG1ql7Z6lBv1LUv7Uto9Xmnt7q3G/TLjm2hhnubWaXyf3RjRnTa0QiSl440/ 4p2Olalb2F74
muf7MtptItZLSW5ea68nStXlhuyQPnd/tGmo8gxuuoWAA2Rk/RlY1r4p0K51 RNOhvt00lzPa
RMYnEUs8KhpYklI2O6gtlVYnMUwxmGUIAeZeJtM1jQvE8mj20njOXwOv2C51 J4L3ULy7+dNS
WQQzqz3ZxNFpu6OFvlU5ICPKW2vg/wCJEj8ExLND4mvrYXOvTxXdzb3NzLFb 2upSRxwS+Zm4
MxjZQkbKXIicYyuD3+t6TpWuaXNpet6ZZanYT7fNtbyBZopNrBhuRgQcMARk dQDU9haWthY2
9jY20NraW0SwwQQxhI4kUYVFUcKoAAAHAAoA8K8MLNcfHrXdcNne21lrMqXV j9stZLaWSJLK
G3ZmilVZE/eQSgB1UkKGGVZSfSvCn/IDuf8AsJXX/pRNWR4m/wCS16b/ANgn /wBmmrX8Kf8A
IDuf+wldf+lE1Y1Ny0V/B/hy11Twtpmo3eoaybi4tkkkK6nMoLEcnAbiotf0 xNC8QeG1sb7U
mW8vpYZ1nvZJVZBbTOBhiR95VOevFN8JeLrDSPDOnaZeaZ4hFza26RShNFun UMBzhgmD9RxU
es63B4i8R+Gxp+n6wgsr2Wad7rTZ7dFQ20yA7pFAPzMoxnPP1qXbl8yUc78a vFvibwVZw6xp
UmjzWL296ptbmykaXzodPvLtX81ZVGwm3RSmzOCx3DjEOj/ElbbSNe1PUdW0 LxNpulR2sg1f
RJIbS1keaR42tt1xctEJI9sbsTMCVnQbQdu/d8YeArTxY97HreuaxPYz280M FinkJFZvLbPb
PLGwi8wv5csoxI7rmQnbwu3Y8U6DDr1vaf6deadeWNx9psr208sy28vlvGWU SK8bZjlkQh1Y
YckYYKROhZyFt8YNBvLR9Q0/SdYv9LttOXUdR1C3a2aCwh824icufO3S7GtZ 8mAShggKF9y5
x/HXxo0GGw8W6LoV/wCTrmn6dqQsrjzraTN5awSuy+R5jTLsMUh3SxLG3l8M wdN/R6f8L9Gt
dC8Q6VLqusXn/CQadLYX9zM8IlZZZ7yZ5F2RqiuXvpv4doAT5eDmbUvh1YX1 lrGmSa9rsWj6
pHehtNhmiSGGS7Ennyqwj8xyWmlcLK7xhnyEGxNr0DU7WiiipGFFFFABRRRQ AUUUUAFUof8A
kO3X/XtD/wChS1dqlD/yHbr/AK9of/QpaAC6/wCQ/wCH/wDr/f8A9JZ662uS uv8AkP8Ah/8A
6/3/APSWeutrop/CRLcKKKKskKKKKACiiigDi/jd/wAky1T/AK6W3/pRHXA/ s4/8eHjH/sYh
/wCm+yrvvjd/yTLVP+ult/6UR1wP7OP/AB4eMf8AsYh/6b7Ku+t/yK/+3/8A 20w/5f8Ay/U9
VooorwjpCiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gAooooAKKKKA
CiiigAooooAKKKKACiiigAooooAKKKKACiiigDxH9oz/AJHXwp/2CdW/9GWN e1fDP/knHhj/
ALBFp/6JSvFf2jP+R18Kf9gnVv8A0ZY17V8M/wDknHhj/sEWn/olK97/AJlt P/EzBfxWdDRR
RXnmoUUUUAcLd/8AIFs/+wxF/wCnEV3VcLd/8gWz/wCwxF/6cRXdVFPYqQUU UVZIVSk89tQm
S3njRhChw6lwM+YAdocY5xzgZAIyf4LtV42zqc6bs4hjO3d0yz843cdOu0Zx 1bGFQA6Xx3bL
i2HXbmBjj72M/Pz1T67W6bht5b40Xtxp/wANtUvLW8mspI2t/wB/DKY3QGeM Nhl5HBI+hrsa
KmpDng43tc3w1ZUK0KrV+Vp272d7HhHwG8QX+qfEGa1l8QX2owDSp5Gilv3n RWE0ADYZiAcF
gD6E/U+70UVlhqDoU1Byv5s3zHGLG13WUeW9tP6sef8AxT8z+3NF/tX/AISb /hF/s139r/sD
7b9o+27oPs277D/pGzy/tef+Wedu75vLry34at8QNUufB2qX3iLxAWmsdFms 1TTb66jurM2d
q108twLhLJWaQ3m43Eb3AHzJuYwCvf8AxJ4e0DxLYpY+I9D0zWbSOUTJBf2i XEauAQHCuCA2
GYZ64J9a066DhPBtNshpX7M03w9g0rxbJ4jv/D82jNbXFlqFzGuo/YkhZFmk VoobfeyhXDrb
43FGwrEdz4R1FPC2oX2g65p+tPqupa3dXSX1tpFzd29zFPcMbdnuIo2RPLhM UBEpQoIAP9UI
3bp9V8WeFdJ0O013VPEui2Gk3mz7LfXN9FHbz71LpskZgrblBYYJyASOKgsv G/gu98RN4cs/
F/h+51pZZIW06LUoXuQ8eS6GINu3LtbIxkbTnpQB4zFbeMr3StJs4m8crfTx afF4zZ5r+EC+
bUtPEptXYhUi8o6luayIhCYJIXyq2rXQb60+LllJq0Xi2Xw9o19d2Gj3CXN/ PJuuItInjEsq
MZZrcype7nmLQqU2OQFRR7ZRQB82+H9N+I1zpQg1XW/Fs99dS6XF4gt7ew1K zEM7alZi4Mdz
JcspURfbAWsEjg2bmYqohFdNa6DfWnxcspNWi8Wy+HtGvruw0e4S5v55N1xF pE8YllRjLNbm
VL3c8xaFSmxyAqKPbKxtE8U6FrVxDBpt95z3Fs13bFonRbmASGMywswAlTdt O5Cw2yRNnbLG
WAPJfB3hnxhpfwg8PazqrfadT0/wjBpFpYWmnXNpcafb3AtRcvMFmM080KwI 4SHyHYxuqgO6
FKfw50jxL4h8Tw6V4h1HxnN4csv7T+yXKNrGjeZ8mlNFvMs32l8PJfBfOkfO 2TbhVCr7/RQB
88+Ej8T9R8S+HdS8Rav4gs9Rli0mVbRNDvDG8BtbZr0Ssk8dhCxlN6GWeJp1 A/dgn7Oo6DR/
m+Dvw706L/kZV1vT7aVhxL/aNvcFtXJl6FzHBqXmSbv3oMgBfzQH9mqlFpOl Q6pJqkWmWUd/
Ju8y6WBRK+5YlbL4ycrBCDzyIox/CMAF2iiigDzfxN/yWvTf+wT/AOzTVr+F P+QHc/8AYSuv
/SiasjxN/wAlr03/ALBP/s01a/hT/kB3P/YSuv8A0omrGpuWivpV54k1TTbb UbPQrE29zGJI
y+pFW2kZGR5XBqvb+IL0arZ2N7paw/arh7cPHJK6q6i4J+YxLG3NtJkK5YAo SoDCl8EeK7S0
8N6ZpQsrm5uYLVFkFvLA+0+XG/zDzMoSksbAMAcODiudiltLjxlo8i2sMF22 r3M77niM3lvH
ehdyqxcAmNwCRtJiYAnFZNpNJb/kJNnS674u0DQtXttM1i7msZLmN5I55rSZ bXCRySuGudvk
oRHDI5VnB2rnGCMzeG/Een6/5/2G31iHyNu/7fpF1ZZ3Zxt8+NN/Q525xxnG Rnm/HVnqGveI
NMtH8I3l5pejXE97cPO9q0GpRvYXMBtokaXcXZrkDEqxx4V8t93dy0/hnX7t Vebwvrt34Wgv
YJrjw1reqQ6hdXpEN2kjbpriSJo98ti6xyTABrZ2ChtvmOyKPZK5zxX4x0zw 3q2maZfQXkk2
o7fJaFFKrm7tLX5ssCPnvYjwD8queoAPCf8ACBXD2Hiq/tfDH2KW+1HTXtdO aWIbtMig077T
ZIiuYU8wW8sDJlUk2Rh2MaowyJPAXiOXXrC+0zwx/ZGjJqKT2ulebbp/ZsIv tEkdNkbmNdxs
r2fEbMDuycO5WmkgPUvCPjfw54r8v+xrm8bzrcXVv9r064tPtMJ2/vYfORPN Qb0yybgN6Zxu
XPR15D4d+H2u6X8KNMhu7m81bX4PDsGlNY3q2bpZ28ggF7bQBY1ikdkiCobg yJujj3NsaTdk
fD74YyzeJIU8VeD/ALR4atP7S/s+01y306T7N5qaXs2wWuYI90kN6R5ajqxb 5pCWLID3WivB
PC3w98XjxFoGreJYtdudYij0uQ363WnslosNtbrcwS3MiPeAvLHclkgJilE2 Cy+bKw97pNWA
KKKKQwooooAKpQ/8h26/69of/Qpau1Sh/wCQ7df9e0P/AKFLQAXX/If8P/8A X+//AKSz11tc
ldf8h/w//wBf7/8ApLPXW10U/hIluFFFFWSFFFFABRRRQBxfxu/5Jlqn/XS2 /wDSiOuB/Zx/
48PGP/YxD/032Vd98bv+SZap/wBdLb/0ojrgf2cf+PDxj/2MQ/8ATfZV31v+ RX/2/wD+2mH/
AC/+X6nqtFFFeEdIUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAFFF
FABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAeI/tGf8jr4U/wCw Tq3/AKMsa9q+
Gf8AyTjwx/2CLT/0SleK/tGf8jr4U/7BOrf+jLGvavhn/wAk48Mf9gi0/wDR KV73/Mtp/wCJ
mC/is6GiiivPNQooooA4W7/5Atn/ANhiL/04iu6rhbv/AJAtn/2GIv8A04iu 6qKexUgoooqy
QqlJ57ahMlvPGjCFDh1LgZ8wA7Q4xzjnAyARk/wXarxtnU503ZxDGdu7pln5 xu46ddozjq2M
KgB0vju2XFsOu3MDHH3sZ+fnqn12t03Dby3xovbjT/htql5a3k1lJG1v+/hl MboDPGGwy8jg
kfQ12NFTUhzwcb2ub4asqFaFVq/K07d7O9jwj4DeIL/VPiDNay+IL7UYBpU8 jRS37zorCaAB
sMxAOCwB9Cfqfd6KKyw1B0Kag5X82b5jjFja7rKPLe2n9WPP/in5n9uaL/av /CTf8Iv9mu/t
f9gfbftH23dB9m3fYf8ASNnl/a8/8s87d3zeXXlvw1b4gapc+DtUvvEXiAtN Y6LNZqmm311H
dWZs7Vrp5bgXCWSs0hvNxuI3uAPmTcxgFe/+JPD2geJbFLHxHoemazaRyiZI L+0S4jVwCA4V
wQGwzDPXBPrWnXQcJ4NptkNK/Zmm+HsGleLZPEd/4fm0Zra4stQuY11H7EkL Is0itFDb72UK
4dbfG4o2FYi6fDfjCy+FfjnUdO8R+Lba+aXxNNp+iwW1uil5Lm9MDxEQfadz FklQrLkllI+U
gV6nqvizwrpOh2mu6p4l0Ww0m82fZb65voo7efepdNkjMFbcoLDBOQCRxUGp +N/Bel31/Y6n
4v8AD9ld6dEs19BcalDHJaoxQK8iswKKTJGAWwCXX+8KAPLPjhH4t0bS4rbw 7e+JmvNM02a8
07UIrTUtSl1TUHZ2aKRLORIYtrJEQLiN4CJ9iRqkToaer6Z42gsNa1Gyk8Zm /Nt4p1O3UXt4
6/bbW/26UqRFimxoZH2wBfLmUAskmxSPcv7W0r+3P7C/tOy/tb7N9r+w+ev2 jyN2zzfLzu2b
vl3YxnjOau0AfPOsab8T73WfFsdjrfiBdani1mK3s4bC8hgEDR3C2BW8kuRY o3Nmwa3iE4bh
yP8ASHr0Ca50bUtd+Fsvg9YUtJIp763FtD9nUaN9hZCoBC4i86bTv3PXIjbb +7JX0auZ8E6t
4B1i4v7jwVqfhnUJl2/bpNInglYb5JZV8wxEn5pJJ3G7qzyHqWNAHTUUVjWv inQrnVE06G+3
TSXM9pExicRSzwqGliSUjY7qC2VVicxTDGYZQgBs0UUUAFFFFAHm/ib/AJLX pv8A2Cf/AGaa
tfwp/wAgO5/7CV1/6UTVkeJv+S16b/2Cf/Zpq1/Cn/IDuf8AsJXX/pRNWNTc tHOyWPgUsgbx
A6+SpSNB4kuFES8ZVVE2FHA4GBwPSruiWnhMahb/ANnar9ruIWZ4IW1mW5CM VYM6xtIw3EM+
Wxn5m55NKYYf+FMafN5UfmfZ7T59o3f62Mda0fHcMMPiHwh5UUcedTmztUDP +h3FZ6/15iTN
SivP/ijYX7+JfCk+i67qWkalqF7c6asyXMslugOm30iO1qXEMhWVY3yy5OxR nArm7LUfEHh/
xFaeENOih0vXtSvbcTzahrOoeILVLV7bUJUaPz5IXWQvZSKwGF2lDlzwpYq5 7JRXzN488Z6y
134k1COT7JqX9jTadJcWc00GJbOLxKvnxhXyu57VXCOZAm4clkWQdf4pt/Gl 5471PSoptY1H
XIPDtlJYXukXr6fplhdyXF+EnuLV7o+YnyQ7htn3CJvlwQhfKFz2qivG/Hnx R8S6DcatqGma
XDe6CsepW1hdTWaxot5Z2lzLIGcXRllAltJoyvkRAjkSEKpkueJfG/jjQdXH hJLXTdc165kt
Da3VjYeSipNHfSFTbzXShyo09+ftCAiUEDMe2RcoXPWKKwvAOralrXhW2v8A WLOGz1DzJoLi
GKaOQB4pniJ/dySKhOzJjDuYyShZipJ3aQwooooAKKKKACqUP/Iduv8Ar2h/ 9Clq7VKH/kO3
X/XtD/6FLQAXX/If8P8A/X+//pLPXW1yV1/yH/D/AP1/v/6Sz11tdFP4SJbh RRRVkhRRRQAU
UUUAcX8bv+SZap/10tv/AEojrgf2cf8Ajw8Y/wDYxD/032Vd98bv+SZap/10 tv8A0ojrgf2c
f+PDxj/2MQ/9N9lXfW/5Ff8A2/8A+2mH/L/5fqeq0UUV4R0hRRRQAUUUUAFF FFABRRRQAUUU
UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQ AUUUUAFFFFAB
RRRQB4j+0Z/yOvhT/sE6t/6Msa9q+Gf/ACTjwx/2CLT/ANEpXiv7Rn/I6+FP +wTq3/oyxr2r
4Z/8k48Mf9gi0/8ARKV73/Mtp/4mYL+KzoaKKK881CiiigDhbv8A5Atn/wBh iL/04iu6rhbv
/kC2f/YYi/8ATiK7qop7FSCiiirJCqUnntqEyW88aMIUOHUuBnzADtDjHOOc DIBGT/BdqvG2
dTnTdnEMZ27umWfnG7jp12jOOrYwqAHS+O7ZcWw67cwMcfexn5+eqfXa3TcN vLfGi9uNP+G2
qXlreTWUkbW/7+GUxugM8YbDLyOCR9DXY0VNSHPBxva5vhqyoVoVWr8rTt3s 72PCPgN4gv8A
VPiDNay+IL7UYBpU8jRS37zorCaABsMxAOCwB9Cfqfd6KKyw1B0Kag5X82b5 jjFja7rKPLe2
n9WPP/in5n9uaL/av/CTf8Iv9mu/tf8AYH237R9t3QfZt32H/SNnl/a8/wDL PO3d83l15b8N
W+IGqXPg7VL7xF4gLTWOizWappt9dR3VmbO1a6eW4FwlkrNIbzcbiN7gD5k3 MYBXv/iTw9oH
iWxSx8R6Hpms2kcomSC/tEuI1cAgOFcEBsMwz1wT61p10HCeDabZDSv2Zpvh 7BpXi2TxHf8A
h+bRmtriy1C5jXUfsSQsizSK0UNvvZQrh1t8bijYViLvxgsW8b+K9Mhs/D2p 6jp2mSxWGqpd
6RPHDIJNa0lyFEqBbiLyrW4Znj3oFTLEBlz6nqvizwrpOh2mu6p4l0Ww0m82 fZb65voo7efe
pdNkjMFbcoLDBOQCRxRN4s8KwaXqGqTeJdFisNMuTaX9099EIrScMqmKVy2E cMyjaxBywGOR
QB4l4p8D+NNA1O3vtNvtT1DWJNIvLO61jbNeSxafHf6VGiF02StKbOK4maON lkaeS6aAqzLj
T8E+HNf1jXNHsNc1nxnd+H1ttUmhmR9U0bDBtOESuXuWum+Y3pX7S+45k2L5 axmvc6KAPBvD
+ueOl8K2Vn4ig8W/8JHrOr+HL5Gj0y6McduU0wXqu8SeVbLvivt8LlOC5K4c bsb4eWviW08F
aI1vZ+LdTuNN8G/2ZejVtKnsJNFeVrJJEtBFFby3Kqkc8hEbSyk2kSpLG0oM nv8ArWvaZpE0
MF5LM1xPFNNFb21tJcTOkSb5HEcSsxUfKucYLPGgy0iK12wu7W/sbe+sbmG6 tLmJZoJ4ZA8c
qMMq6sOGUgggjgg0AeGfCq08Zal41sbTVNY8Wt4d02XUXglks7/T47sKukyQ pKLxnuCome8K
75CWEciA+TuirT0f5vg78O9Oi/5GVdb0+2lYcS/2jb3BbVyZehcxwal5km79 6DIAX80B/Zqp
RaTpUOqSapFpllHfybvMulgUSvuWJWy+MnKwQg88iKMfwjABdooooAKKKKAP N/E3/Ja9N/7B
P/s01a/hT/kB3P8A2Err/wBKJqyPE3/Ja9N/7BP/ALNNWv4U/wCQHc/9hK6/ 9KJqxqblowJb
Txn/AMIlD4bj07QGggSJFnbUpg7CNlYEr5BAzt6ZOM960LmPxPrGtaPc6vZa PZ2+m3Elxm1v
ZJnctDJFtw0Sgf6zOc9unPEun2GvaxoMWv2OtSQzXcfmQ2BjiECoRwNxQvvx zuJK7v4McVWs
5/EOi6lYafrqC4i1GdobeZrlJJUdYpJDu2RRqVxHgcAgnvniGnuJWLs3hbwz NqV/qc3hzR5L
7Ubc2t9cvZRmW6hKhTFI5GXQhVG1iRhQO1Y9/wDDPwLd2Gn6Z/wi+j2+l2Wo nUf7OgsIVtbi
YwSQZli2bWwsmc4ByiHPGKm8WeIdd0fxFounWWiabeWuryS2sM82pPC6XS21 xOqsggceWRAF
LhiwL/cOOafhLxlqt94d1LXfEWgQ6fa2l7PZomlT3GqTSvDcyW0h8pLZXxvj yNoYlSSwTBpa
lHSW2gaFbS2s1voumwyWcccVq8dqimBI0kSNUIHyhVllVQOAJHA4Y5ND0DQt CiEOiaLpulxi
MRBLO1SEbA7uFwoHAaWRgOmXY9WOeQT4oaKni66sriaYaOulWl5FeR6bcsLd 3nu4pxdOEK2w
j+zqG87yyhEu4/KQsvhP4j6TfJfw67cf2XcWmo6nb+dPZz29m8VrczoNtxIv lO4hh3sFckbJ
DgBGClmBvX3gzwffavPrF74U0K61K4jaKa8m0+J5pUaPymVnK7iDGShBOCpx 04q5q2gaFq8V
1Dq2i6bqEd3HHFcpdWqSiZI3Lxq4YHcFZmZQeAWJHJrHT4geGGspbhp9Sikj kSP7FLpF3Hey
FwxUpatEJ5ARHKQyoRiKU5xG+3itM+Les3VjrWpr4bs59L0O3udR1CaS6mtL lbSO+v4FEds8
LFphFYlisjxZdsHZzgswPWLG1tbGygsrK2htbW3jWKGGFAiRIowqqo4AAAAA 4AFTVzmt+N/D
miXd9b6vc3lj9it5LmWafTrhYHSOIzOIpSnlzOI1ZtkbM2Efj5GxCnxA8MNZ S3DT6lFJHIkf
2KXSLuO9kLhipS1aITyAiOUhlQjEUpziN9qsxnU0VT0bU7HWNNi1HTp/Ot5c gEoyMrKxVkdW
AZHVgysjAMrKVIBBFXKACiiigAqlD/yHbr/r2h/9Clq7VKH/AJDt1/17Q/8A oUtABdf8h/w/
/wBf7/8ApLPXW1yV1/yH/D//AF/v/wCks9dbXRT+EiW4UUUVZIUUUUAFFFFA HF/G7/kmWqf9
dLb/ANKI64H9nH/jw8Y/9jEP/TfZV6h8SdEvfEXgy+0fTnt0upzE0ZnYrHlJ Uc5IBPRT2NeG
ah+z5rWo3j3l/pPga6uZMb5Zg7u2BgZJgycAAfhXq0oUq+C9jKoovmvr6WMJ c0avMlfQ94or
5/8A+Gb77/oX/h//AN+m/wDjFH/DN99/0L/w/wD+/Tf/ABiuf+yaP/P+JXtZ fyn0BRXz/wD8
M333/Qv/AA//AO/Tf/GKP+Gb77/oX/h//wB+m/8AjFH9k0f+f8Q9rL+U+gKK +f8A/hm++/6F
/wCH/wD36b/4xR/wzfff9C/8P/8Av03/AMYo/smj/wA/4h7WX8p9AUV8/wD/ AAzfff8AQv8A
w/8A+/Tf/GKP+Gb77/oX/h//AN+m/wDjFH9k0f8An/EPay/lPoCivn//AIZv vv8AoX/h/wD9
+m/+MUf8M333/Qv/AA//AO/Tf/GKP7Jo/wDP+Ie1l/KfQFFfP/8Awzfff9C/ 8P8A/v03/wAY
o/4Zvvv+hf8Ah/8A9+m/+MUf2TR/5/xD2sv5T6Aor5//AOGb77/oX/h//wB+ m/8AjFH/AAzf
ff8AQv8Aw/8A+/Tf/GKP7Jo/8/4h7WX8p9AUV8//APDN99/0L/w//wC/Tf8A xij/AIZvvv8A
oX/h/wD9+m/+MUf2TR/5/wAQ9rL+U+gKK+f/APhm++/6F/4f/wDfpv8A4xR/ wzfff9C/8P8A
/v03/wAYo/smj/z/AIh7WX8p9AUV8/8A/DN99/0L/wAP/wDv03/xij/hm++/ 6F/4f/8Afpv/
AIxR/ZNH/n/EPay/lPoCivn/AP4Zvvv+hf8Ah/8A9+m/+MUf8M333/Qv/D// AL9N/wDGKP7J
o/8AP+Ie1l/KfQFFfP8A/wAM333/AEL/AMP/APv03/xij/hm++/6F/4f/wDf pv8A4xR/ZNH/
AJ/xD2sv5T6Aor5//wCGb77/AKF/4f8A/fpv/jFH/DN99/0L/wAP/wDv03/x ij+yaP8Az/iH
tZfyn0BRXz//AMM333/Qv/D/AP79N/8AGKP+Gb77/oX/AIf/APfpv/jFH9k0 f+f8Q9rL+U+g
KK+f/wDhm++/6F/4f/8Afpv/AIxR/wAM333/AEL/AMP/APv03/xij+yaP/P+ Ie1l/KfQFFfP
/wDwzfff9C/8P/8Av03/AMYo/wCGb77/AKF/4f8A/fpv/jFH9k0f+f8AEPay /lPoCivn/wD4
Zvvv+hf+H/8A36b/AOMUf8M333/Qv/D/AP79N/8AGKP7Jo/8/wCIe1l/KfQF FfP/APwzfff9
C/8AD/8A79N/8Yo/4Zvvv+hf+H//AH6b/wCMUf2TR/5/xD2sv5T6Aor5/wD+ Gb77/oX/AIf/
APfpv/jFH/DN99/0L/w//wC/Tf8Axij+yaP/AD/iHtZfyn0BRXz/AP8ADN99 /wBC/wDD/wD7
9N/8Yo/4Zvvv+hf+H/8A36b/AOMUf2TR/wCf8Q9rL+U0v2jP+R18Kf8AYJ1b /wBGWNe1fDP/
AJJx4Y/7BFp/6JSvDNP+AGvabK82m6d4KsZXQxtJbF42KnBIysA4yBx7CvoD whp0+j+EtH0m
5eN57KwgtpWjJKlkjVSQSAcZHcCt8TGlRwkKMZqTTb0FC7m5NWNSiiivLNgo oooA4W7/AOQL
Z/8AYYi/9OIruq4W7/5Atn/2GIv/AE4iu6qKexUgoooqyQqlJ57ahMlvPGjC FDh1LgZ8wA7Q
4xzjnAyARk/wXarxtnU503ZxDGdu7pln5xu46ddozjq2MKgB0vju2XFsOu3M DHH3sZ+fnqn1
2t03Dby3xovbjT/htql5a3k1lJG1v+/hlMboDPGGwy8jgkfQ12NFTUhzwcb2 ub4asqFaFVq/
K07d7O9jwj4DeIL/AFT4gzWsviC+1GAaVPI0Ut+86KwmgAbDMQDgsAfQn6n3 eiissNQdCmoO
V/Nm+Y4xY2u6yjy3tp/Vjz/4p+Z/bmi/2r/wk3/CL/Zrv7X/AGB9t+0fbd0H 2bd9h/0jZ5f2
vP8Ayzzt3fN5deW/DVviBqlz4O1S+8ReIC01jos1mqabfXUd1ZmztWunluBc JZKzSG83G4je
4A+ZNzGAV7/4k8PaB4lsUsfEeh6ZrNpHKJkgv7RLiNXAIDhXBAbDMM9cE+ta ddBwng2m2Q0r
9mab4ewaV4tk8R3/AIfm0Zra4stQuY11H7EkLIs0itFDb72UK4dbfG4o2FYj M8S/DTVb/wCH
Pja4jtL0Q3v/AAkt3Po4jbdfXy3V8LCUQbMS745w+45YtbWBQ4j59z1XxZ4V 0nQ7TXdU8S6L
YaTebPst9c30UdvPvUumyRmCtuUFhgnIBI4om8WeFYNL1DVJvEuixWGmXJtL +6e+iEVpOGVT
FK5bCOGZRtYg5YDHIoA8M8TW3xL+2eNLi31nxN/a32bW/KsrLSr/AGfZvJuR YeXcG4+yb/8A
jzZfssP2jfhW589q63U7bXfCXxBtV09vFtz4P0+WyvrzM17qcjmW31WCVQWM k0yiQaeTCu4I
dsm1cs9ev0UAeQfB+51G48f3t54gXUxLqNjfS6EuqQypOlums3pmCpKA8KmG fSvlYLuUQgAi
L5Os+CnzfDmxni/48Lm5vLnSgOFGnS3UslkEX+BBbNCFjwNi4XC7cDoNftNA v1tbHX7bTLpb
mWSG1gvY0cSu0EodEV/vMYTMCByUMmfl3VDdeKdCttUfTpr7bNHcwWkrCJzF FPMpaKJ5QNiO
wC4VmBzLCMZmiDgGzRRRQAUUUUAFFFFAHm/ib/ktem/9gn/2aatfwp/yA7n/ ALCV1/6UTVke
Jv8Aktem/wDYJ/8AZpqmTUpNG+H2u6xFam7ksZdQuVgBIMpSWdgmQrEZxjhS eeh6VlKLlKyK
Ww7wT448Had4R0qxvvE+k291BaoksUl0gZGA5UjPBHpUPiHxL4f8QeJ/CsOh 6zYajJBfzSSp
bTq7In2SddxA6DJAz6keteWyfHbxWkyovwqvpFKKxdX1DaCVBK82AOVJIPGM g4JGCfWfh54h
m8VeELLXbnTW0ya4Mqvas7MYykrxkZZEb+HOCqkZwRW+JweIw8F7VWT80/yb IhOMnZfkyO/0
DU9S8X6fql/qtmdL0q4N3YWcFkyTiY28kBMsxlZXTbNKdqxoclPmO0hsfVPh 99r8IHQv7Qs5
8azear5d/YfaLK4+0XE83k3FvvXzUTz8r86/vIo5P4dtdJqvinwzpOpDTNV8 R6PYXxt3uhbX
N7HFKYUVmaXYxB2AI5LYwAjHsam8Pa/oXiKye98P61pur2qSGJ5rG6SdFcAE qWQkA4ZTjrgj
1rj1NTzLSvg/qenaVqOjW/iXR4NL1nTpNO1S3t9CaLbDJdXs7C1xcbYMLfOi hllA2KcHla0r
r4W3Wq2V3omueIoZtBe91W8tobPTzBdRvfi6Vw8zSyI4VL2YDESncEJOAVb0 ys6z13SLrT21
CK/hW1W9ewMsp8sfaEuDbmP5sZPnKUH944xnIyXYWOE0j4XSaUsd9plx4W0r WLa9jurVtK8M
paWWVhnh/fQrL5spKXU3PnKARGQow4km8HfCnTNM16TX/EY0fxDqh/eQTyaS qfZJjfXl40kO
95Gj+a7VRhsjyVOTnj0aqes6ppmi6bLqes6jZ6bYw4825u51iiTLBRudiAMk gDJ6kCi7Cx5b
4v8Agv8A2/qt/df2to8H2r+0D9tfRPM1Q/a7W4g8uS784b4Y/tHyR7BhIYkz 8u473j74Z2vi
vX5dauJ9NmkEdmLe01LTBeWm+D7apaaIuvmArfPgAoVeNGywytdpo2qaZrWm xano2o2epWM2
fKubSdZYnwxU7XUkHBBBweoIq5RzMDI8G6HD4b8N2mjQCzVYN7FbOyjtIFZ3 Z2EcScIgLEAE
s2MbmdssdeiikMKKKKACqUP/ACHbr/r2h/8AQpau1Sh/5Dt1/wBe0P8A6FLQ AXX/ACH/AA//
ANf7/wDpLPXW1yV1/wAh/wAP/wDX+/8A6Sz11tdFP4SJbhRRRVkhRRRQAUUU UAFFFFABRRRQ
AUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAFF
FFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAcLd/8AIFs/+wxF /wCnEV3VcLd/
8gWz/wCwxF/6cRXdVFPYqQUUUVZIVSk89tQmS3njRhChw6lwM+YAdocY5xzg ZAIyf4LtV42z
qc6bs4hjO3d0yz843cdOu0Zx1bGFQA6Xx3bLi2HXbmBjj72M/Pz1T67W6bht 5b40Xtxp/wAN
tUvLW8mspI2t/wB/DKY3QGeMNhl5HBI+hrsaKmpDng43tc3w1ZUK0KrV+Vp2 72d7HhHwG8QX
+qfEGa1l8QX2owDSp5Gilv3nRWE0ADYZiAcFgD6E/U+70UVlhqDoU1Byv5s3 zHGLG13WUeW9
tP6sef8AxT8z+3NF/tX/AISb/hF/s139r/sD7b9o+27oPs277D/pGzy/tef+ Wedu75vLry34
at8QNUufB2qX3iLxAWmsdFms1TTb66jurM2dq108twLhLJWaQ3m43Eb3AHzJ uYwCvf8AxJ4e
0DxLYpY+I9D0zWbSOUTJBf2iXEauAQHCuCA2GYZ64J9a066DhPBtNshpX7M0 3w9g0rxbJ4jv
/D82jNbXFlqFzGuo/YkhZFmkVoobfeyhXDrb43FGwrEZniX4aarf/DnxtcR2 l6Ib3/hJbufR
xG26+vlur4WEog2Yl3xzh9xyxa2sChxHz7nqvizwrpOh2mu6p4l0Ww0m82fZ b65voo7efepd
NkjMFbcoLDBOQCRxRN4s8KwaXqGqTeJdFisNMuTaX9099EIrScMqmKVy2EcM yjaxBywGORQB
4Z4mtviX9s8aXFvrPib+1vs2t+VZWWlX+z7N5NyLDy7g3H2Tf/x5sv2WH7Rv wrc+e1dbqdtr
vhL4g2q6e3i258H6fLZX15ma91ORzLb6rBKoLGSaZRINPJhXcEO2TauWevX6 KAPE7Ka4u774
ca1qejeILi+XxlrksVzcaLdvPaWEx1CKESFo91vE3m2QCybBtVTjbGSs2sfL 8HfiJp0v/Iyt
reoW0THmX+0bi4DaQRL0DiOfTfLk3fugIwSnlEJ6nrHiHQNGvtPsdX1zTNOu 9Sl8mwgurtIp
Lp8qNkSsQXbLqMLk5YeorMv9T8Gp4nD3kdk2rW1zbWjXjWRb7PPIk3kRNcbd sblZpAqlgR9q
RcA3CBwDpqKKKACiiigAooooA838Tf8AJa9N/wCwT/7NNUwjkm+HuvQwxvJI 8uoKiIMsxMs4
AAHU1D4m/wCS16b/ANgn/wBmmrX8Kf8AIDuf+wldf+lE1Yz3KWxmar4lXWru OazsdZht7Oxu
7meC5kudNZ9hhIZSoy+AWGOnzdaZ4h0m70TTbe6tbP7GBqVmjNHrl1P8sl3E rjy3UK24OwOf
UnrWh4i0u/v/AJtOv7a0ke0ntJDPatMDHLs3YAkTDDYMHJHXimahaeJtViht dV1jSHtFuYLh
1ttLkikYxSpKoDNOwGWQZ+U8Z+tJSvuwsed/tDJd+JNEuNB0TStYvL7TrfUb mcJps4iZJNIv
YUEcpQRzOZLiJdkbM2WPHytg8dy694jkuPEPgmDWNMih04WF/cXGl3NtPcI1 5bO2yBhHcS+T
breEFNrA3BEDGRn2evUVFyrHglxD4rg8M2KDUfFOvRfbbk2Oliw1fS3vgUgV FN4Jpbm1CSGc
g3jbHLsMLGkUqGoaF4ibw9f2mq2GuzWFz4mnuLRNPE8ZtrePXmu52eOP94ZH gjMkU6k5AEcY
jkdTc+90U+YLHkMn9rf8JJH9g/4S/wC2f2jpn9heb9u+y/2RstftX2nf+587 H27P2n/SM7cf
N5VcV4dXxBrvgDwrL4am8U3clxZaPc6zcazFqF1D9vGoadJFNGtyw3xhReO/ 2dgm0AswHlkf
SdQ2Nra2NlBZWVtDa2tvGsUMMKBEiRRhVVRwAAAABwAKOYLHk/jjRNc0uwKX GoXjTazqL6jq
eq6Tp2pMkc8cENvDAlrYXC3AR4o9xdpXQNEcjMkYTO8HW3ja50NfFert4pXx J/augxmGSa5j
h+zy2+mren7HkQYBlvNzeX8jBzlWTK+30UuYLHkPwPt/GUetNL4l1fWLm4bT v+JxbXGl3cME
d8Wj+5LczvG+D54H2KNYSMk7R5IPr1FFDdxhRRRSAKpQ/wDIduv+vaH/ANCl q7VKH/kO3X/X
tD/6FLQAXX/If8P/APX+/wD6Sz11tcldf8h/w/8A9f7/APpLPXW10U/hIluF FFFWSFFFFABR
RRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFF FABRRRQAUUUU
AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQB wt3/AMgWz/7D
EX/pxFd1XC3f/IFs/wDsMRf+nEV3VRT2KkFFFFWSFV5orkzvLBPGm5AoDozg EB+cbgOrL0AJ
AIzyNtiigCu6Xx3bLi2HXbmBjj72M/Pz1T67W6bht5b40Xtxp/w21S8tbyay kja3/fwymN0B
njDYZeRwSPoa7GioqQ54ON7XN8NWVCtCq1fladu9nex4R8BvEF/qnxBmtZfE F9qMA0qeRopb
950VhNAA2GYgHBYA+hP1Pu9FFZYag6FNQcr+bN8xxixtd1lHlvbT+rHn/wAU /M/tzRf7V/4S
b/hF/s139r/sD7b9o+27oPs277D/AKRs8v7Xn/lnnbu+by68t+GrfEDVLnwd ql94i8QFprHR
ZrNU02+uo7qzNnatdPLcC4SyVmkN5uNxG9wB8ybmMAr3/wASeHtA8S2KWPiP Q9M1m0jlEyQX
9olxGrgEBwrggNhmGeuCfWtOug4TwbTbIaV+zNN8PYNK8WyeI7/w/NozW1xZ ahcxrqP2JIWR
ZpFaKG33soVw62+NxRsKxGZ4l+Gmq3/w58bXEdpeiG9/4SW7n0cRtuvr5bq+ FhKINmJd8c4f
ccsWtrAocR8/RlFAHzn4mtviX9s8aXFvrPib+1vs2t+VZWWlX+z7N5NyLDy7 g3H2Tf8A8ebL
9lh+0b8K3PntXW6nba74S+INqunt4tufB+ny2V9eZmvdTkcy2+qwSqCxkmmU SDTyYV3BDtk2
rlnr1+igDwaDWRqOlXOi+JNB8Ww2Oty6i2p6gfDGoXF1eaa2pXotrAFIWeFf JYk+ZtaOKVRE
oaTzIdPWPl+DvxE06X/kZW1vULaJjzL/AGjcXAbSCJegcRz6b5cm790BGCU8 ohPZqpS6TpU2
qR6pLpllJfx7fLumgUyptWVVw+MjCzzAc8CWQfxHIBdooooAKKKKACiiigDz fxN/yWvTf+wT
/wCzTVr+FP8AkB3P/YSuv/SiasjxN/yWvTf+wT/7NNWv4U/5Adz/ANhK6/8A Siasam5aOQ8P
aXY3lnaiXSp3Z0toYmtbHT2DubKKZtzTKXLHLsSTjp3pRarpvj3TbCPT2tAl xbyBpba1imYS
W2o7lJtwAUzBGQDzlc+lFl/wl2mpZx2Gk3cYtjFIwksracNKlqtsSG+3RkoV XIBUHPX0q1aw
eIdU8WWOratp1xFLHNGZZTBBBCsUUF2igKtzMxcvddeBhfXrTej1JSDx42tQ eLfCqaf4l1Kw
tdWvZtNuLWGG2ZAPsN5MsymSJnEivFGRlimFwUOTnkPC3xG8S2fgew1C/sod djsfCNj4l1zU
bm9W3uClws7ukEEVv5blFt3ChmjB+QFs5evR77wlot7q8+q3Q1KS6ljaNSdU uQluWj8svBGJ
NkEmwsvmRBXw7/N8zZp6d8PvCVhoF3oVvps39n3elLo88ct7PKWs187bDvdy wC/aJQCCCAwA
OFUDG6LOQh+IviLSfDtze6no8OqSXXibUNJ0Y28k8jzCG5vOJooLZ3jCRW21 TGsxYgF9gLMJ
pPitqY03V70eCLyFdH8Ovrd79suGtiu1rxBEqSRCX53tAyMyLmNyzBGVY36+ 78EeHLn7Zutr
yL7VcC6P2fUbiHyJvn3SwbHH2d38yTe0WwyeY+/duORPA/hZNN1LTl0v/R9U 07+zb4G4lLXE
G6ZiHYtuLs1zOzSZ3s0hZmJ5p3QGFqPj7VdJi1Ow1fQ9Nh8Q2kdrNbWVrf3F 1DdpO8yqqNHa
mcyAW1w7IkDgKgbdjeU8+1D4geI/EHiywk8PyeI7FdQ+xWlxYWAt/tCSRnXV nES3yrGuZLOM
lpEjkKRgFVb5B7JrfhHQNZvZr6+tJvtk0cEZuoLuaCaMQmYxmOSNlaMj7ROp ZCpZZGUkqcVT
0T4feEtGvbS9sNNmF1aSebFNNezzPvJuiWZpHYuSb66JLZJMvP3VwXQGR4a8 W6pa6o2g6zp2
pQwadpSapqmr67e2UUlvFJLdqBItsPKyPs6kFSF8ssXZXQLJj6b8V9a1DULf QrfwfDHr097D
CsN5c3lnbiKW3u5lk3z2aSk/6FKpAhK/MuHJ3BfR7jQtIub3ULu6sIbiTUrK OwvVmG9J7dDK
VjZDlSP38ueOQ2DkAYx9I+H/AIY0zV49Yhg1K41CKSOSO5vtXu7x1KRzxoAZ pW4C3VwNvTMh
OMgEK6A5CX4xsul2k0fhmaS81WOyutJgikmnEtrdxXMsLTeTBJLHIEs59yRx zKp2fOVLMnoP
g3WZvEHhu01a40u80uabeslrdQyRujI7ISFkVH2MV3KWRGKspKqSVGb/AMK+ 8JCygtYtNmt1
trK1sbaWC9nimghthKIRHKjh0IWeZSysGZZGViwOK3dG0yx0fTYtO06DybeL JALs7MzMWZ3Z
iWd2YszOxLMzFiSSTQ7dALlFFFIYVSh/5Dt1/wBe0P8A6FLV2qUP/Iduv+va H/0KWgAuv+Q/
4f8A+v8Af/0lnrra5K6/5D/h/wD6/wB//SWeutrop/CRLcKKKKskKKKKACii igAooooAKKKK
ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAo
oooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigDhbv8A5Atn/wBh iL/04iu6rhbv
/kC2f/YYi/8ATiK7qop7FSCiiirJCiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAK
KKKACiiigDzfxN/yWvTf+wT/AOzTVr+FP+QHc/8AYSuv/SiasjxN/wAlr03/ ALBP/s01a/hT
/kB3P/YSuv8A0omrGpuWjyCT9pvwLGkLtpesETJvXbc6cxA3FfmAu
Re: Menus again [message #576795 is a reply to message #12935] Tue, 30 December 2003 00:00 Go to previous message
We done visual menu designing in our SWT Designer even before I've
heard anything about Instantiations. :-)
See for example: http://www.swt-designer.com/demos/demo4.html
SY, Konstantin.
Advanced Eclipse SWT Designer (http://www.swt-designer.com)
Re: Menus again [message #576855 is a reply to message #13844] Tue, 06 January 2004 08:23 Go to previous message
I openned a bug and Peter Walker show the correct way to move jmenus.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=49510
Thank you all
Previous Topic:Installing plugins (CSharp feature)
Next Topic:TableLayout
Current Time: Sat Jul 26 14:41:10 EDT 2025
Powered by FUDForum. Page generated in 0.06432 seconds
