Home » Language IDEs » C / C++ IDE (CDT) » "Conflicting names" in the Problems tab?
"Conflicting names" in the Problems tab? [message #140016] Wed, 02 March 2005 18:20
I am working on a large, pre-existing project (standard make) that has
several files in different directories that share the same names. This
appears to cause the "Problems" window to have issues.
Any time there is a compile or other error in one of these files, the
Problems tab shows the error, but I can't double-click on the line to go
to the file - nor do markers show up in the file itself. In these cases,
the Problems line will show something like:
"[Conflicting names: somedir/filename.c ] warning: blah blah"
The Resource column will just contain the name of the project instead of
the filename and the In Folder column will be blank.
I've tried messing around with the Project Paths tab, but no luck.
Previous Topic:Why can't (Standard C) Make find my commands?
Next Topic:How to add Cygwin to eclipse??
Current Time: Thu Jul 17 13:15:35 EDT 2025
Powered by FUDForum. Page generated in 0.26879 seconds
