No memory analysis events with TPTP and Tomcat [message #139981] |
Thu, 05 February 2009 21:10 |
Jörg Friedrich Messages: 2 Registered: July 2009 |
I have started using TPTP 4.5 to analyze a web application running with
Tomcat 5.5 and JDK 1.5. I have set up everything to profile the
application entirely from within Eclipse (Tomcat is started from WTP),
using the IAC.
I am able to do an execution time analysis, and get nice results. When I
try to do a memory analysis I don't get any data displayed. In the status
bar I see that there are about 4900 bytes processed right during startup,
thereafter there are no more events.
I have tried to set the filters, restart Eclipse with -clean, changed the
Tomcat VM memory parameters, and fiddled around quite a bit, but no change.
Anybody else having this problem? Is this a known TPTP problem, or am I
doing something wrong here?
Re: No memory analysis events with TPTP and Tomcat [message #140325 is a reply to message #139992] |
Thu, 12 February 2009 16:53 |
Eugene Chan Messages: 287 Registered: July 2009 |
------=_NextPart_000_008F_01C98D08.7CD44270
Content-Type: text/plain;
charset="iso-8859-15"
Content-Transfer-Encoding: quoted-printable
Hi Jorg,
Could you try with a more latest release of TPTP? eg TPTP v4.5.1. Also =
which JVM version are you using (java -version)? I am having trouble =
reproducing the problem with the Tomcat 6 samples on Windows XP. Does =
this happen on Widnows or Linux?
Eugene
""J=F6rg" Friedrich" <joerg.friedrich@trackplus.com> wrote in message =
news:40a523cf27f439461329385693a4fe93$1@www.eclipse.org...
> Well, I am a little further. I switched to option Java profilinge Pre =
JRE=20
> 1.5, and it is collection memory analysis data now - for about 20 =
seconds.=20
> Then the following nasty message appears:
>=20
> # An unexpected error has been detected by HotSpot Virtual Machine:
> # EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=3D0x10018720, =
pid=3D4708,=20
> tid=3D2124
> # Java VM: Java HotSpot(TM) Client VM (1.5.0_06-b05 mixed mode)
> # Problematic frame:
> # C [piAgent.dll+0x18720]
> # An error report file with more information is saved as =
hs_err_pid4708.log
> # If you would like to submit a bug report, please visit:
> # http://java.sun.com/webapps/bugreport/crash.jsp
>=20
> and the process is terminated. I can see the collected memory data, =
but of=20
> course I would love to have the machine run a little longer than =
that...
>=20
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Diso-8859-15">
<META content=3D"MSHTML 6.00.2900.5659" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY>
<DIV><FONT face=3DArial size=3D2>Hi Jorg,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>Could you try with a more latest =
release of TPTP?=20
eg <A =
href=3D"http://www.eclipse.org/tptp/home/downloads/?ver=3D4.5.1">TPTP=20
v4.5.1</A>. Also which JVM version are you using (java -version)? I am =
having=20
trouble reproducing the problem with the Tomcat 6 samples on Windows XP. =
Does=20
this happen on Widnows or Linux?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Eugene</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>""J=F6rg" Friedrich" <</FONT><A=20
href=3D"mailto:joerg.friedrich@trackplus.com"><FONT face=3DArial=20
size=3D2>joerg.friedrich@trackplus.com</FONT></A><FONT face=3DArial =
size=3D2>>=20
wrote in message </FONT><A=20
href=3D"news:40a523cf27f439461329385693a4fe93$1@www.eclipse.org"><FONT =
face=3DArial=20
size=3D2>news:40a523cf27f439461329385693a4fe93$1@www.eclipse.org</FONT></=
A><FONT=20
face=3DArial size=3D2>...</FONT></DIV><FONT face=3DArial size=3D2>> =
Well, I am a=20
little further. I switched to option Java profilinge Pre JRE <BR>> =
1.5, and=20
it is collection memory analysis data now - for about 20 seconds. =
<BR>> Then=20
the following nasty message appears:<BR>> <BR>> #<BR>> # An =
unexpected=20
error has been detected by HotSpot Virtual Machine:<BR>> #<BR>> =
# =20
EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=3D0x10018720, pid=3D4708, =
<BR>>=20
tid=3D2124<BR>> #<BR>> # Java VM: Java HotSpot(TM) Client VM =
(1.5.0_06-b05=20
mixed mode)<BR>> # Problematic frame:<BR>> # C =20
[piAgent.dll+0x18720]<BR>> #<BR>> # An error report file with more =
information is saved as hs_err_pid4708.log<BR>> #<BR>> # If you =
would like=20
to submit a bug report, please visit:<BR>> # </FONT><A=20
href=3D"http://java.sun.com/webapps/bugreport/crash.jsp"><FONT =
face=3DArial=20
size=3D2>http://java.sun.com/webapps/bugreport/crash.jsp</FONT></A><BR><F=
ONT=20
face=3DArial size=3D2>> #<BR>> <BR>> and the process is =
terminated. I can=20
see the collected memory data, but of <BR>> course I would love to =
have the=20
machine run a little longer than that...<BR>> =
<BR>></FONT></BODY></HTML>
------=_NextPart_000_008F_01C98D08.7CD44270--
FUDForum. Page generated in 0.03785 seconds
