Converting a View to an Editor [message #139869] |
Sun, 05 October 2003 21:34  |
I've successfully implemented/extended the table editor described in the
"Building and delivering a table editor with SWT/JFace" Eclipse Corner
article. Unfortunately, I need this editor to appear in the 'center'
frame of the Eclipse window. This appears to be reserved for Editors.
I've tried to convert the View to an Editor with no luck.
Can someone outline the steps necessary to make such a conversion?
-Mitch
FWIW, my approach was to do the following:
o Create a new Editor plugin project using PDE (based on the XML editor
example).
o Delete all XML Editor classes except for the class that extends
TextEditor.
o Added/Implemented creatPartControl() and copied code from the Table
Editor example.
o All compiles fine, but I can't bring up the table editor.
o I mapped the file extension of '.pgd'. But opening a file of that type
from the navigator opens a standard text editor.
Re: Converting a View to an Editor [message #140143 is a reply to message #139903] |
Mon, 06 October 2003 10:17  |
Brilliant. Thank you.
I'm building a "Posting Grid", so a .pgd extension seemed natural. Just
my luck that I would choose an unacceptable extension.
Works now.
-Mitch
Syed wrote:
> I am no specialist on editors but I think you need to use a different file
> extension,as thats what Eclipse platform looks for when a editor is
> invoked.
> My reason for saying this is that when I created my javaeditor I had to
> use a different file extension to make the platform know that it is my
> editor not the Eclipse javaEditor.
> You can get this done (i think) by specifying a different file extension
> in the plugin.xml file for your editor.
> I hope this helps.
> Syed
> > Thanks,
> > -Mitch
> > example).
> > TextEditor.
> > Editor example.
FUDForum. Page generated in 0.02899 seconds
