Home » Language IDEs » Java Development Tools (JDT) » disable java builder
disable java builder [message #139459] Thu, 05 February 2004 15:56 Go to next message
Originally posted by: me.andresmarch.com
My project must be a java project to get all the help navigating classes,
but:
The only problem I have not been able to resolve is eclipse's build
process. I want to only use Ant because the eclipse java build is limited
and problematic. I cannot figure out how to disable it. It requires me to
have an output folder. And until you change a preference, it constantly
builds you project. However, the main issue is it calls the java builder
even when you just want to run ANT. Is there a way to stop this?
Maybe I'm just not setting up my project correctly to use the java
builder. But I have no control over that anyway. I want to only use ANT
anyway because of build dependancies. I tried adding an ANT as an external
builder but I still cannot delete the java builder. Help!!!!!!!?!?!?!!!
Re: disable java builder [message #139531 is a reply to message #139459] Thu, 05 February 2004 16:53 Go to previous messageGo to next message
Originally posted by: smesh.openrules.com
Try to experiment with '.project'.
Note: I did not advise you to do this :)
Sam Mesh - http://openrules.com
Life is very short, and there's no time,
For coding and testing, my friend.
Re: disable java builder [message #139575 is a reply to message #139459] Thu, 05 February 2004 17:54 Go to previous messageGo to next message
There is support for this in the 3.0 stream.
Right click on your project, select Builders and uncheck the Java Builder.
This disables this builder.
Then you can create your own builder that executes your Ant build (and set
the responsive level of your builder using the Build Options page for your
builder).
HTH
Darins
"Andres" <me@andresmarch.com> wrote in message
news:bvuall$isl$1@eclipse.org...
> but:
Re: disable java builder [message #139586 is a reply to message #139575] Thu, 05 February 2004 19:51 Go to previous message
That sounds great, thanks
> builder).
> HTH
> Darins
> > but:
Previous Topic:More control over Problem/Task window
Next Topic:Input redirection in Windows Eclipse
Current Time: Wed Jul 16 04:42:34 EDT 2025
Powered by FUDForum. Page generated in 0.08940 seconds
