Using BIRT charts as input in GEF style [message #139283] |
Sat, 04 March 2006 12:52  |
Charts are normally used to display output data. However, it is also
possible to use a chart for graphically create input data. A quick example
is the way that GEF elements can be created from a panel, they can be
moved and modified in size , and finally they can be deleted.
Here is the question: what is the optimal way to implement the GEF style
elements in BIRT charts?
The examples for interactivity do not include anything for moving elements.
Re: Using BIRT charts as input in GEF style [message #139728 is a reply to message #139626] |
Mon, 06 March 2006 11:21  |
Thanks, I see what you mean. There is no way to do this now, in fact it
seems a different product altogether. I imagine it can be implemented in GEF
to create static charts. The real challenge would be to map those GEF
figures to a BIRT Chart model, that seems quite difficult to render exactly
the same thing using the chart engine and Draw2D Figures.
David
"Ali" <saveez@hotmail.com> wrote in message news:duhj5d$vpv$1@eclipse.org...
> David,
> Here is a simple example:
> Assume a bar chart.
> (1) Creating bars: from a panel the user can select a 'bar element' and
> drag and drop it to the chart
> (2) Manipulating data: by selecting a bar, the user can move/resize the
> bar
> (3) Deleting data: selecting a bar allows the user to delete the data
> graphically.
> The above features may be found in GEF. Hope the example helps the
> question now.
> -Ali
> David Michonneau wrote:
>> There is no such feature for now. I am not sure I really understand what
>> you are trying to achieve when you mention "Graphically create input
>> data". I am familiar with GEF, but I don't see exactly how this would
>> work within a chart. Could you elaborate your thought on that?
>> Thanks,
>> David
>> news:87e5df655ce30b66fe80eb8a96004619$1@www.eclipse.org...
>>> example is the way that GEF elements can be created from a panel, they
>>> can be moved and modified in size , and finally they can be deleted.
>>> elements.
FUDForum. Page generated in 0.27863 seconds
