Re: CDT Draft Plans V1 and V2 Posted [message #14042 is a reply to message #12841] |
Fri, 25 January 2002 09:56   |
We agree that the GTK support is important, but our decision to focus our
testing on the Motif version, is based on a few factors:
1. The Eclipse R2.0 plans says the following:
"Note that the Linux GTK configuration is considered early access for the 2.0
release; it will be tested, but it is known in advance that it will not be of
product quality in this release."
2. We have limited testing resource and testing our code against a stable Motif
version would probably bear more fruit than testing on an potentially unstable
GTK version (while testing with the GTK version we would need to do more
investigation to determine if a UI or performance problem was our bug or the
GTK's).
All that being said, we will not be ignoring the GTK version. We will be doing
some basic testing on the latest versions, and will fix bugs reported by others
using it.
Thanks...
Jeff Turnham
"Johan Walles" <johan.nosp@m.appeal.se> wrote in message
news:3C5100CF.2040907@m.appeal.se...
> The plan talks about only testing with Motif builds. As support for
> GTK+ is one of the reasons I want to use 2.0, I would really appreciate
> having you testing with GTK+.
> Especially since Linux seems to be your #1 target platform, focusing
> mainly on a seldom used (on Linux) widget set like Motif seems kind of
> backwards to me.
> Regards //Johan
> Robert Cecco wrote:
> > Draft plans for CDT Project V1.0 and V2.0 have been posted here
> > http://64.38.235.23/tools/cdt/downloads/
> > Please send your comments concerning these plans to cdt-dev@eclipse.org
> > Thanks,
> > Rob Cecco
Re: CDT Draft Plans V1 and V2 Posted [message #14058 is a reply to message #14042] |
Fri, 25 January 2002 10:13  |
Originally posted by: johan.nosp.m.appeal.se
Good enough for me. Good to hear that you are aware of that this is an
issue!
Cheers //Johan
Jeff Turnham wrote:
> GTK's).
> using it.
> Thanks...
> Jeff Turnham
>>backwards to me.
>> Regards //Johan
>>>Thanks,
>>>Rob Cecco
FUDForum. Page generated in 0.04182 seconds
