Home » Language IDEs » C / C++ IDE (CDT) » CDT Draft Plans V1 and V2 Posted
CDT Draft Plans V1 and V2 Posted [message #12762] Thu, 24 January 2002 10:43 Go to next message
Draft plans for CDT Project V1.0 and V2.0 have been posted here
http://64.38.235.23/tools/cdt/downloads/
Please send your comments concerning these plans to cdt-dev@eclipse.org
Rob Cecco
Re: CDT Draft Plans V1 and V2 Posted [message #12800 is a reply to message #12762] Thu, 24 January 2002 11:08 Go to previous messageGo to next message
> Rob Cecco
I realise that you are not formally testing either CDT 1 or 2 in Debian
but for the record, using the IBM 1.3.1 JDK running a 2.4 (actually
2.4.5) kernel - soon to be upgraded, under XFree 86 4.1 and KDE 2.1/2
CDT 1 works a treat. I will be running on this or a derived platform
for the forseable future, so I will test any code on this platform as
it comes out. I am likely to move to CDT 2 just as soon as possible
however as Eclipse V1 gives me problems with my CVS access.
It might be worth both CDT in particular and Eclipse in general keeping
records of who is testing on other Linux distributions so that if
problems arise we might be able either to run diagnostic tests or
give assistance.
David
Re: CDT Draft Plans V1 and V2 Posted [message #12841 is a reply to message #12762] Fri, 25 January 2002 01:53 Go to previous messageGo to next message
Originally posted by: johan.nosp.m.appeal.se
The plan talks about only testing with Motif builds. As support for
GTK+ is one of the reasons I want to use 2.0, I would really appreciate
having you testing with GTK+.
Especially since Linux seems to be your #1 target platform, focusing
mainly on a seldom used (on Linux) widget set like Motif seems kind of
backwards to me.
Regards //Johan
> Rob Cecco
Re: CDT Draft Plans V1 and V2 Posted [message #14011 is a reply to message #12841] Fri, 25 January 2002 05:09 Go to previous messageGo to next message
Originally posted by: s.schaefer.schaefer-edv.de
I have the same opinion.
"Johan Walles" <johan.nosp@m.appeal.se> schrieb im Newsbeitrag
news:3C5100CF.2040907@m.appeal.se...
> backwards to me.
> Regards //Johan
> > Thanks,
> > Rob Cecco
Re: CDT Draft Plans V1 and V2 Posted [message #14042 is a reply to message #12841] Fri, 25 January 2002 09:56 Go to previous messageGo to next message
We agree that the GTK support is important, but our decision to focus our
testing on the Motif version, is based on a few factors:
1. The Eclipse R2.0 plans says the following:
"Note that the Linux GTK configuration is considered early access for the 2.0
release; it will be tested, but it is known in advance that it will not be of
product quality in this release."
2. We have limited testing resource and testing our code against a stable Motif
version would probably bear more fruit than testing on an potentially unstable
GTK version (while testing with the GTK version we would need to do more
investigation to determine if a UI or performance problem was our bug or the
GTK's).
All that being said, we will not be ignoring the GTK version. We will be doing
some basic testing on the latest versions, and will fix bugs reported by others
using it.
Thanks...
Jeff Turnham
"Johan Walles" <johan.nosp@m.appeal.se> wrote in message
> backwards to me.
> Regards //Johan
> > Thanks,
> > Rob Cecco
Re: CDT Draft Plans V1 and V2 Posted [message #14058 is a reply to message #14042] Fri, 25 January 2002 10:13 Go to previous message
Good enough for me. Good to hear that you are aware of that this is an
issue!
Cheers //Johan
Jeff Turnham wrote:
> GTK's).
> using it.
> Thanks...
> Jeff Turnham
>>backwards to me.
>> Regards //Johan
>>>Thanks,
>>>Rob Cecco
Previous Topic:What's the plan for moving to Eclipse 2.0
Next Topic:CDT has a new project home page...
Current Time: Sat Jul 12 00:20:07 EDT 2025
Powered by FUDForum. Page generated in 0.05404 seconds
