Home » Eclipse Projects » OSEE » OSEE Quickstart - Tutorial to get you up and running...
OSEE Quickstart - Tutorial to get you up and running... [message #12757] Mon, 20 April 2009 16:54 Go to next message
For those interested in getting OSEE up and running, we have posted our
tutorial slides from EcipseCon 2009 that brought attendees from eclipse
installation all the way through deploying OSEE with artifact/relation
types configuration and ATS configuration.
This presentation uses a fictitious company "T. Rex" as an example of
how to migrate and use OSEE.
http://www.eclipse.org/osee/OSEE_eclipsecon2009_tutorial_sli des.pdf
Re: OSEE Quickstart - Tutorial to get you up and running... [message #12837 is a reply to message #12757] Tue, 21 April 2009 08:58 Go to previous messageGo to next message
What/where is the "PostgreSql folder" mentioned in the tutorial"? And
therefore related what/where are the osee batch and script files mentioned
in the tutorial (note that many of them are not mentioned in the
installation documentation)?
Trent
Re: OSEE Quickstart - Tutorial to get you up and running... [message #12852 is a reply to message #12837] Tue, 21 April 2009 10:02 Go to previous messageGo to next message
Found them.
But the application server scripts (osee_app_server.bat) must be refering
to a newer version of the application server than the one on microdoc
( http://osee.microdoc.com/downloads/osee/server/0.7.0/server_ 0.7.0-2009-02-19_08_49.zip)
as the application jar file is "org.eclipse.osgi_3.4.0.v20080326.jar"
compared to the one in the batch file
"org.eclipse.osgi_3.4.2.R34x_v20080826-1230.jar"
Any hints of a way forward for getting the application server running?
Trent
Re: OSEE Quickstart - Tutorial to get you up and running... [message #13429 is a reply to message #12852] Tue, 21 April 2009 11:02 Go to previous messageGo to next message
I took a chance and assumed the Application Server was running and
executed the OSEE Demo Database initialization - it worked (with SEVERE
errors being reported, see below) and I was able to spin up the tutorial
version of eclipse and start working through the slides.
Results of db init:
C:\all-in-one>eclipsec -application
org.eclipse.osee.framework.database.configClient -vmargs -Xmx512m
-Dosee.log.default=INFO -Dosee.application.server=http
://localhost:8089
-Dosee.authentication.protocol=trustAllDosee.prompt.on.db.in it=false
-Dosee.choice.on.db.init="OSEE Demo Database"
Adding:
org.eclipse.osee.framework.core.client.internal.ClientDataba seProvider @132ae7
OSEE Application Server Validation [PASSED]
Tue Apr 21 11:27:06 ADT 2009
org.eclipse.osee.framework.core.client.CoreClientActivator
INFO
org.eclipse.osee.framework.core.client.server.HttpServer$Int ernalHttpServer
run (136)
Starting HttpServer on port: [18001]
Are you sure you want to configure: OSEE:osee
Enter: [Y|N]
Y
Tue Apr 21 11:27:12 ADT 2009
org.eclipse.osee.framework.database.DatabaseActivator
INFO
org.eclipse.osee.framework.database.initialize.DatabaseIniti alizationOperation
execute (94)
Configuring Database...
org.eclipse.osee.framework.db.connection.internal.InternalAc tivator
INFO org.eclipse.osee.framework.db.connection.OseeConnectionPool
getConnection (71)
getConnection - jdbc:postgresql://localhost:5432/OSEE - connection pool
size [1]
many INFO messages
Tue Apr 21 11:27:49 ADT 2009
INFO
runDbInitTasks (219)
Starting [org.eclipse.osee.framework.skynet.core.PostDbUserCleanUp]
execution rule [Default]
org.eclipse.osee.framework.skynet.core.SkynetActivator
INFO org.eclipse.osee.framework.skynet.core.dbinit.PostDbUserClea nUp
run (39)
Post Initialization User Clean-up
INFO
org.eclipse.osee.framework.core.client.internal.InternalClie ntSessionManager
internalReleaseSession (163)
Session [AAABIMkSsNIBewmYQk6vaw] released.
SEVERE
ensureSessionCreated (139)
http://localhost:8089/osee/session?operation=create
org.eclipse.osee.framework.core.exception.OseeAuthentication Exception:
org.eclipse.osee.framework.core.client.internal.InternalClie ntSessionManager.internalAcquireSession(InternalClientSessio nManager.java:215)
org.eclipse.osee.framework.core.client.internal.InternalClie ntSessionManager.authenticate(InternalClientSessionManager.j ava:111)
org.eclipse.osee.framework.core.client.internal.InternalClie ntSessionManager.ensureSessionCreated(InternalClientSessionM anager.java:128)
org.eclipse.osee.framework.core.client.ClientSessionManager. ensureSessionCreated(ClientSessionManager.java:38)
org.eclipse.osee.framework.skynet.core.ClientUser.populateCu rrentUser(ClientUser.java:58)
org.eclipse.osee.framework.skynet.core.ClientUser.getMainUse r(ClientUser.java:48)
org.eclipse.osee.framework.skynet.core.UserManager.getUser(U serManager.java:69)
org.eclipse.osee.framework.skynet.core.dbinit.PostDbUserClea nUp.run(PostDbUserCleanUp.java:61)
org.eclipse.osee.framework.database.initialize.DatabaseIniti alizationOperation.runDbInitTasks(DatabaseInitializationOper ation.java:224)
org.eclipse.osee.framework.database.initialize.DatabaseIniti alizationOperation.processTask(DatabaseInitializationOperati on.java:126)
org.eclipse.osee.framework.database.initialize.DatabaseIniti alizationOperation.execute(DatabaseInitializationOperation.j ava:99)
org.eclipse.osee.framework.database.initialize.DatabaseIniti alizationOperation.executeConfigureFromJvmProperties(Databas eInitializationOperation.
java:294)
org.eclipse.osee.framework.database.ConfigDatabase.start(Con figDatabase.java:32)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
Caused by: java.io.IOException: Error during POST
[http://localhost:8089/osee/session?operation=create] - status code: [500]
org.eclipse.osee.framework.jdk.core.util.HttpProcessor.post( HttpProcessor.java:116)
org.eclipse.osee.framework.core.client.internal.InternalClie ntSessionManager.internalAcquireSession(InternalClientSessio nManager.java:210)
... 24 more
Caused by: java.lang.Exception: HTTP/1.1 500 Internal Server Error
org.eclipse.osee.framework.jdk.core.util.HttpProcessor.post( HttpProcessor.java:108)
... 25 more
INFO org.eclipse.osee.framework.skynet.core.ClientUser setCurrentUser
(91)
You are logged into OSEE as "Guest". If this is unexpected notify your
OSEE admin
INFO
Starting [org.eclipse.osee.framework.skynet.core.SkynetDbBranchDataIm port]
INFO
Starting [org.eclipse.osee.framework.database.PostDbInitializationPro cess]
org.eclipse.osee.framework.database.initialize.tasks.PostDat abaseInitialization
INFO
run (35)
Running Post-Initialization Process...
INFO
run (39)
Vacuumiing PostgreSQL
Tue Apr 21 11:27:51 ADT 2009
INFO
processTask (136)
Database Initialization Complete.
Database Configurationg completed in [38.625 secs] ms
Removing:
INFO
Session [AAABIMkTV7ABgu9rSXachA] released.
Re: OSEE Quickstart - Tutorial to get you up and running... [message #15272 is a reply to message #13429] Sun, 17 May 2009 15:24 Go to previous message
Trent,
Were you able to get up and running yet? If so, please tell how.
Ray
Re: OSEE Quickstart - Tutorial to get you up and running... [message #572759 is a reply to message #12757] Tue, 21 April 2009 08:58 Go to previous message
Trent
Re: OSEE Quickstart - Tutorial to get you up and running... [message #572778 is a reply to message #12837] Tue, 21 April 2009 10:02 Go to previous message
Found them.
Trent
Re: OSEE Quickstart - Tutorial to get you up and running... [message #572796 is a reply to message #12852] Tue, 21 April 2009 11:02 Go to previous message
Results of db init:
://localhost:8089
Adding:
INFO
run (136)
Enter: [Y|N]
Y
INFO
execute (94)
getConnection (71)
size [1]
many INFO messages
INFO
run (39)
INFO
SEVERE
java:294)
... 24 more
... 25 more
(91)
OSEE admin
INFO
INFO
INFO
run (35)
INFO
run (39)
INFO
processTask (136)
Removing:
INFO
Re: OSEE Quickstart - Tutorial to get you up and running... [message #573803 is a reply to message #13429] Sun, 17 May 2009 15:24 Go to previous message
Trent,
Ray
Previous Topic:Problems when running with remote app server
Next Topic:Getting client/server running - worked for me
Current Time: Sat Jul 26 08:27:40 EDT 2025
Powered by FUDForum. Page generated in 0.04522 seconds
