| Drag & Drop ctableTreeItems? [message #12725] |
Mon, 02 October 2006 16:38  |
Can drag&drop be done in CTableTreeViewer? I've add support following the
drag&drop article (since CTableTreeViewer extends StructuredViewer). I
tried the drag but nothing happens I've used same code with a regular
treeViewer and (its not working perfectly yet) but I can see some typical
drag behaviour i.e. outline of the item moving with mouse on dragStart.
| Re: Drag & Drop ctableTreeItems? [message #12787 is a reply to message #12766] |
Wed, 04 October 2006 13:04  |
Currently its not possible for a custom widget to implement drag
effects. See:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=134769
This has been marked on the 3.3 plan though.
-Chris
Jeremy Dowdall wrote:
> Hi Cal,
> This currently should _not_ work - simply because no work has been done
> in this arena. Before CTableTree can be called version 1.0, however,
> this should probably be made to work :)
> Cal wrote:
>> Hi
>> I'm not asking for work to be done on this particular topic. I just want
>> to know if it "should" work, maybe I'm not doing something. Thanks
| Re: Drag & Drop ctableTreeItems? [message #565871 is a reply to message #12745] |
Wed, 04 October 2006 09:54  |
Hi Cal,
Cal wrote:
> Hi
| Re: Drag & Drop ctableTreeItems? [message #565898 is a reply to message #12766] |
effects. See:
-Chris
> Hi Cal,
> Cal wrote:
>> Hi
FUDForum. Page generated in 0.04703 seconds
