Home » Eclipse Projects » Nebula » Drag & Drop ctableTreeItems?
Drag & Drop ctableTreeItems? [message #12725] Mon, 02 October 2006 16:38 Go to next message
Can drag&drop be done in CTableTreeViewer? I've add support following the
drag&drop article (since CTableTreeViewer extends StructuredViewer). I
tried the drag but nothing happens I've used same code with a regular
treeViewer and (its not working perfectly yet) but I can see some typical
drag behaviour i.e. outline of the item moving with mouse on dragStart.
Re: Drag & Drop ctableTreeItems? [message #12745 is a reply to message #12725] Wed, 04 October 2006 07:32 Go to previous messageGo to next message
I'm not asking for work to be done on this particular topic. I just want
to know if it "should" work, maybe I'm not doing something. Thanks
Re: Drag & Drop ctableTreeItems? [message #12766 is a reply to message #12745] Wed, 04 October 2006 09:54 Go to previous messageGo to next message
Hi Cal,
This currently should _not_ work - simply because no work has been done
in this arena. Before CTableTree can be called version 1.0, however,
this should probably be made to work :)
Cal wrote:
> Hi
Re: Drag & Drop ctableTreeItems? [message #12787 is a reply to message #12766] Wed, 04 October 2006 13:04 Go to previous message
Currently its not possible for a custom widget to implement drag
effects. See:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=134769
This has been marked on the 3.3 plan though.
-Chris
Jeremy Dowdall wrote:
> Hi Cal,
> Cal wrote:
>> Hi
Re: Drag & Drop ctableTreeItems? [message #565845 is a reply to message #12725] Wed, 04 October 2006 07:32 Go to previous message
Re: Drag & Drop ctableTreeItems? [message #565871 is a reply to message #12745] Wed, 04 October 2006 09:54 Go to previous message
Hi Cal,
Cal wrote:
> Hi
Re: Drag & Drop ctableTreeItems? [message #565898 is a reply to message #12766] Wed, 04 October 2006 13:04 Go to previous message
effects. See:
-Chris
> Hi Cal,
> Cal wrote:
>> Hi
Previous Topic:Drag & Drop ctableTreeItems?
Next Topic:Single cell selection?
Current Time: Tue Jul 22 13:02:45 EDT 2025
Powered by FUDForum. Page generated in 0.07805 seconds
