Home » Eclipse Projects » Remote Application Platform (RAP) » Remember Data on page reload
Remember Data on page reload [message #137857] |
Thu, 25 June 2009 07:24  |
How do I remember informations when the user reloads the page in the
browser.
Say I open my application with an URL like this:
-------8<-------
http://127.0.0.1:55350/rap?startup=bizerbawb&username=bl abla&password=bloblo
-------8<-------
In reality these 2 parameters are passed as post parameters :-) Now my
user wants to switch the language which I implemented by simply
reloading the page and like this:
-------8<-------
parent.window.location.href=' http://127.0.0.1:55350/rap?startup=bizerbawb&language=de _DE'
-------8<-------
Naturally I can't pass the username and password now because of security
reasons. In standard web-applications I'd restore those informations in
the HttpSession and that's what I thought would be possible also.
So I tried:
- RWT.getSession()
- RWT.getSessionStore()
- RWT.getRequest().getSession()
but it looks like those sessions are clear when ever I reload the page.
So I'm a bit stuck now because my standard Servlet-Knowlege doesn't seem
to work.
Tom
Re: Remember Data on page reload [message #137904 is a reply to message #137883] |
Thu, 25 June 2009 08:49   |
Originally posted by: benjamin.wolff.web.de
hm, that's odd, since i'm using this mechanism to store login information throughout session.
for example, when logging in i do:
RWT.getSettingStore().setAttribute("username", "bla");
RWT.getSettingStore().setAttribute("password", "blabla");
in a new session i do:
String username = (String) RWT.getSettingStore().getAttribute("username");
String password = (String) RWT.getSettingStore().getAttribute("password");
and then i get the values that have been stored in a previous session.
please distiguish between the RWT.getSETTINGStore() and RWT.getSESSIONStore()...
HTH,
-ben
Tom Schindl schrieb:
> I tried it already and it is cleared when I reload the page!
> Tom
> Ben W. schrieb:
>> take a look at RWT.getSettingStore() and ISettingStore doc?! afaik this
>> mechanism works with cookies, maybe this is a point for further
>> investigations?!
>> HTH,
>> -ben
>>> Hi,
>>> browser.
>>> -------8<-------
>>> -------8<-------
>>> -------8<-------
>>> -------8<-------
>>> So I tried:
>>> - RWT.getSession()
>>> to work.
>>> Tom
Re: Remember Data on page reload [message #137916 is a reply to message #137904] |
Thu, 25 June 2009 09:24   |
You are sooooo right - I had a typo and really used
RWT.getSESSIONStore() :-)
Tom
> HTH,
> -ben
>> Tom
>>> investigations?!
>>> HTH,
>>> -ben
>>>> Hi,
>>>> browser.
>>>> -------8<-------
>>>> -------8<-------
>>>> -------8<-------
>>>> -------8<-------
>>>> security
>>>> So I tried:
>>>> - RWT.getSession()
>>>> seem
>>>> to work.
>>>> Tom
Re: Remember Data on page reload [message #137950 is a reply to message #137916] |
Thu, 25 June 2009 09:28   |
On a site note I think the approach from Rüdiger to use a static mao is
better because the setting store survives sessions (e.g. Browser
restart) which is a bad thing to happen!
Tom
> Tom
>> HTH,
>> -ben
>>> Hi,
>>> Tom
>>>> investigations?!
>>>> HTH,
>>>> -ben
>>>>> Hi,
>>>>> browser.
>>>>> -------8<-------
>>>>> -------8<-------
>>>>> -------8<-------
>>>>> -------8<-------
>>>>> security
>>>>> So I tried:
>>>>> - RWT.getSession()
>>>>> seem
>>>>> to work.
>>>>> Tom
Re: Remember Data on page reload [message #138134 is a reply to message #137990] |
Fri, 26 June 2009 06:40   |
This works great. Now one final question and I'm totally happy. Do you
know if it possible to somehow modify the main-html page so that I can
add a hidden IFRAME where I redirect file downloads to?
Tom
Ben W. schrieb:
> hi,
> using servlets in conjunction with a RAP/server-side equinox application
> is as easy as can possibly be imagined :PP.
> just use the org.eclipse.equinox.http.registry.servlets extension point
> and point to the servlet class and fill in the other parameters.
> you can then use the servlets in an embedded jetty or deployed in a
> tomcat environmen.
> HTH,
> -ben
>> Hi Rüdiger,
>> Works like a charme but I'm not sure how I should add a session listener
>> in context of an RAP-Application.
>> Do you by chance have a pointer how I do that in an RAP-env? I also have
>> to register 2 more servlets in the Jetty (to produce PDF and CSV-Files).
>> So the general question might be how to configure the underlying
>> Jetty-Instance through extension points.
>> Tom
>> Rüdiger Herrmann schrieb:
>>> Tom,
>>> currently all session attributes are removed from the HttpSession. The
>>> ISessionStore is itself an attribute taht is stored in the HttpSesion.
>>> If you feel that it is a general requirement to have sme attributes
>>> "survive" a session restart, please file an enhancement request.
>>> Meanwhile you could work around this by storing the user information in
>>> a static map. As a key you can use the session id (it doesn't change
>>> with a session restart).
>>> The first login would store user/password in the map under the session
>>> id. A "restart-request" would encounter that there is no user/password
>>> in the request parameters and consult the map.
>>> To save memory, remove the entry from the map when the session is
>>> invalidated.
>>> Another approach would be form based authentication. It should also
>>> work, thou I haven't tried it myself.
>>> HTH
>>> Rüdiger
>>> Tom Schindl wrote:
>>>> Hi,
>>>> browser.
>>>> -------8<-------
>>>> -------8<-------
>>>> -------8<-------
>>>> -------8<-------
>>>> security
>>>> So I tried:
>>>> - RWT.getSession()
>>>> seem
>>>> to work.
>>>> Tom
Re: Remember Data on page reload [message #138158 is a reply to message #138134] |
Fri, 26 June 2009 07:22  |
Tom Schindl wrote:
You would need a "branding" that - among other things - allows you
to insert HTML snippets into the main page.
See here for the branding documentation:
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .rap.help/help/html/advanced/branding.html
The documentation of the body attribute might be a bit misleading.
You need to specify a file that contains an HTML snippets that goes
into the body element of the page.
> Tom
> Ben W. schrieb:
>> hi,
>> tomcat environmen.
>> HTH,
>> -ben
>>> Hi Rüdiger,
>>> Tom
>>>> Tom,
>>>> invalidated.
>>>> HTH
>>>> Rüdiger
>>>> Tom Schindl wrote:
>>>>> Hi,
>>>>> browser.
>>>>> -------8<-------
>>>>> -------8<-------
>>>>> -------8<-------
>>>>> -------8<-------
>>>>> security
>>>>> So I tried:
>>>>> - RWT.getSession()
>>>>> seem
>>>>> to work.
>>>>> Tom
Current Time: Fri Jul 18 00:23:55 EDT 2025
Powered by FUDForum. Page generated in 0.12521 seconds
