Home » Archived » BIRT » IBM Websphere 6.0 + birt
IBM Websphere 6.0 + birt [message #137855] Thu, 02 March 2006 04:50 Go to next message
Originally posted by: mariusz.paszkiewicz.pbpolsoft.com.pl
What are the differences between js.jar placed in runtime of IBM Websphere
and js.jar placed in birt? This jar from birt has only more methods than
this from IBM runtime?
I can't make integration between IBM Websphere 6.0 and birt, without
replace this file in runtime. I tried to change class loader mode from
"Parent First" to "Parent Last" but it doesn't work. But our client
wouldn't agree on replacing because he will loose the maintenance from IBM.
Please help me in this integration.
Mariusz Paszkiewicz
PB Polsoft
Re: IBM Websphere 6.0 + birt [message #138693 is a reply to message #137855] Fri, 03 March 2006 00:03 Go to previous message
Mariusz,
Apart from making class loader mode to Parent Last, also change the WAR
class loader policy to 'Application'.
One more thing is, in WAS 6.0, you would get a Java Script error in the
Web Viewer and I couldn't find a solution for that. I assume that this
would be OK with you, as you can call the BIRT runtime from a JSP or some
other resource, rather than using the Web Viewer, till the issue is fixed.
In fact there is no need to copy the js.jar in the runtime.
Ravi.
Previous Topic:themes in libraries
Next Topic:Problem with Running Report with Type 4 driver
Current Time: Mon Jul 14 09:54:42 EDT 2025
Powered by FUDForum. Page generated in 0.28288 seconds
