Home » Archived » Visual Editor (VE) » VE opens a second window?
VE opens a second window? [message #137822] Sun, 27 May 2007 17:59 Go to next message
Originally posted by: joern_schmidt.hotmail.com
Hi All,
I'm new to Java and also Eclipse.
After reinstalling my notebook, now when I open a visual class in VE, a
second window appears outside Eclipse, with the same layout. It's a like a
mirror of the class being edited.
I've looked into the Preferences and could not find how to disable it.
Does someone know a solution for that ?
Thank you in advance.
Joern Schmidt.
Re: VE opens a second window? [message #137880 is a reply to message #137822] Mon, 04 June 2007 22:22 Go to previous messageGo to next message
Joern Schmidt wrote:
> Hi All,
> a mirror of the class being edited.
> Joern Schmidt.
This is actually a second jvm which is used to render the visual class
and javabean and the VE simply uses a screenshot of this window to mimic
the edit on the canvas. The window you are seeing is usually opened
off-screen. There is no preference to disable it and closing it woud
probably result in the loss of the WYSIWYG screenshot in the GE.
Re: VE opens a second window? [message #138164 is a reply to message #137880] Sat, 23 June 2007 18:10 Go to previous messageGo to next message
I also see this window and I find it very annoying!
Re: VE opens a second window? [message #138278 is a reply to message #138164] Mon, 25 June 2007 02:45 Go to previous message
It is just the way VE works. Just forget it is there :) and do you work.
Re: VE opens a second window? [message #615312 is a reply to message #137822] Mon, 04 June 2007 22:22 Go to previous message
> Hi All,
> Joern Schmidt.
Re: VE opens a second window? [message #616116 is a reply to message #137880] Sat, 23 June 2007 18:10 Go to previous message
Re: VE opens a second window? [message #616119 is a reply to message #138164] Mon, 25 June 2007 02:45 Go to previous message
Previous Topic:VE for other languges
Next Topic:VE out of Eclipse Europa ?
Current Time: Mon Sep 01 02:18:36 EDT 2025
Powered by FUDForum. Page generated in 0.29125 seconds
