Shape Example HOWTO [message #12636] |
Tue, 09 July 2002 11:11  |
Hi there,
I've installed the Shape Example from the GEF wiki and now I can't seem to
see how to use it... :">
How do you use the plugin?
Thanks in advance,
Peter.
Re: Shape Example HOWTO [message #12718 is a reply to message #12698] |
Tue, 09 July 2002 11:49  |
The wiki has been updated.
Eric
"Eric Bordeau" <ebordeau@us.ibm.com> wrote in message
news:ageus7$spr$1@rogue.oti.com...
> Randy's right. Just create a file with a .shape extension. Sorry I
forgot
> to mention that.
> Eric
> "Randy Hudson" <none@ibm.com> wrote in message
> news:agetti$s1i$1@rogue.oti.com...
> > I'm just guessing, but if you look at the plugin.xml, the editor must be
> > associated with some file extension, probably "shape". Create a new
file
> > called test.shape, and see if it will launch the example.
> > "ObjectWiz" <objectwiz@lycos.co.uk> wrote in message
> > news:agesud$r1m$1@rogue.oti.com...
> > > Hi there,
seem
> to
> > > Thanks in advance,
> > > Peter.
FUDForum. Page generated in 0.28901 seconds
