Home » Eclipse Projects » GEF » Shape Example HOWTO
Shape Example HOWTO [message #12636] Tue, 09 July 2002 11:11 Go to next message
Hi there,
I've installed the Shape Example from the GEF wiki and now I can't seem to
see how to use it... :">
How do you use the plugin?
Thanks in advance,
Peter.
Re: Shape Example HOWTO [message #12678 is a reply to message #12636] Tue, 09 July 2002 11:30 Go to previous messageGo to next message
Originally posted by: none.ibm.com
I'm just guessing, but if you look at the plugin.xml, the editor must be
associated with some file extension, probably "shape". Create a new file
called test.shape, and see if it will launch the example.
"ObjectWiz" <objectwiz@lycos.co.uk> wrote in message
news:agesud$r1m$1@rogue.oti.com...
> Hi there,
> Thanks in advance,
> Peter.
Re: Shape Example HOWTO [message #12698 is a reply to message #12678] Tue, 09 July 2002 11:46 Go to previous messageGo to next message
Randy's right. Just create a file with a .shape extension. Sorry I forgot
to mention that.
Eric
"Randy Hudson" <none@ibm.com> wrote in message
news:agetti$s1i$1@rogue.oti.com...
> > Hi there,
to
> > Thanks in advance,
> > Peter.
Re: Shape Example HOWTO [message #12718 is a reply to message #12698] Tue, 09 July 2002 11:49 Go to previous message
The wiki has been updated.
Eric
"Eric Bordeau" <ebordeau@us.ibm.com> wrote in message
news:ageus7$spr$1@rogue.oti.com...
forgot
> to mention that.
> Eric
file
> > > Hi there,
seem
> to
> > > Thanks in advance,
> > > Peter.
Previous Topic:Cannot set Factory on ConnectionCreationTool
Next Topic:[JFace] weird Exception after Closing Wizard Dialog
Current Time: Sat Jul 26 05:54:47 EDT 2025
Powered by FUDForum. Page generated in 0.04747 seconds
