How to add EMF Index Plugins? [message #137481] |
Sun, 21 June 2009 23:41  |
Hi All,
I am a GSOC student and I am working on Open Metadata Search. Please visit
the following link if you are required any information about the project.
http://wiki.eclipse.org/Open_Metadata_Search
My target is to register the EMF models for JavaEE which I can find in the
WTP in the EMF Index and call search operations.
I have already set up the wtp and looking forward to add the index plugins
into my plugin project. I have the problem of how to add these index
plugins into my plugin project.
Please be kind enough to help me in adding these index plugins.
Thanks in advance.
Sajith.
Re: How to add EMF Index Plugins? [message #137539 is a reply to message #137495] |
Tue, 23 June 2009 11:25  |
Hi Jan,
Thanks a lot for your valuable information. I will try to work this out.
Sajith
Jan KÂoehnlein wrote:
> Hi Sakith
> note that currently EMF Index is quite preliminary and may change
> drastically in the near future.
> Here is how it currently works:
> 1) You enable indexing by adding the EMF Index nature to the projects
> containing your models.
> 2) You configure the kind of information that should be extracted and
> indexed by implementing a ResourceIndexer. You can inherit from the
> ResourceIndexerImpl that already provides protected methods for the
> interesting hooks. Your resource indexer has to be registered to the
> org.eclipse.emf.index.indexer extension point.
> 3) You get a hold on the current index store by means of
org.eclipse.emf.index.ui.internal.EmfIndexUIPlugin.getDefaul t().getIndexStore()
> 4) Queries are created using the appropriate DAO, e.g.
> indexStore.eObjectDAO().createQuery().name("objName")
> The rest should be easy to figure out yourself.
> Regards
> Jan
> sajith weerakoon schrieb:
>> Hi All,
>> visit the following link if you are required any information about the
>> project.
>> the WTP in the EMF Index and call search operations.
>> plugins into my plugin project. I have the problem of how to add these
>> index plugins into my plugin project.
>> Thanks in advance.
>> Regards,
>> Sajith.
Re: How to add EMF Index Plugins? [message #621042 is a reply to message #137481] |
Mon, 22 June 2009 03:37  |
Hi Sakith
Jan
> Hi All,
> project.
> Thanks in advance.
> Sajith.
Re: How to add EMF Index Plugins? [message #621046 is a reply to message #137495] |
Hi Jan,
Sajith
> Hi Sakith
> Regards
> Jan
>> Hi All,
>> project.
>> Thanks in advance.
>> Regards,
>> Sajith.
FUDForum. Page generated in 0.08463 seconds
