Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMF Compare] Bug in detecting added attributes?
[EMF Compare] Bug in detecting added attributes? [message #137311] Tue, 16 June 2009 08:35 Go to next message
short version:
I think I found a bug in added attribute detection as shown here:
http://img268.imageshack.us/img268/2386/multiattributechange .png
(using the latest version from the CVS)
long(er) version:
I created a small model for testing the detection of all kinds of differences:
http://imm.dtu.dk/~pk/files/eachonce.zip
http://imm.dtu.dk/~pk/files/eachonce-runtime.zip
eachonce.zip is a plugin project with a very simple ecore model (including generated code) with just one EClass and some attributes and references.
eachonce-runtime.zip contains example models for the runtime workbench:
Eachonce/attribute/ - the example above
Eachonce/eachonce/ - contains all different kinds of differences (14 in total)
Eachonce/reference/ - example from https://bugs.eclipse.org/bugs/show_bug.cgi?id=270439 (fixed)
Best regards
Patrick
Re: [EMF Compare] Bug in detecting added attributes? [message #137334 is a reply to message #137311] Tue, 16 June 2009 09:06 Go to previous messageGo to next message
--------------000703020000010802080405
Hi Patrick,
Looking at the image, this indeed looks like a bug. As we are currently
working on the release of Galileo, could you raise a bugzilla for this
with the zips and image so that I don't forget this needs fixing?
Laurent Goubet
Obeo
Patrick K
Re: [EMF Compare] Bug in detecting added attributes? [message #137346 is a reply to message #137334] Tue, 16 June 2009 10:08 Go to previous messageGo to next message
No problem, looking forward to Galileo :-)
Sure, here it is: https://bugs.eclipse.org/bugs/show_bug.cgi?id=280449
Patrick
On 16-06-2009 15:06, laurent Goubet wrote:
> Hi Patrick,
> Laurent Goubet
> Obeo
> Patrick Könemann a écrit :
>> Cheers,
>> short version:
>> long(er) version:
>> differences:
>> and references.
>> in total)
>> Best regards
>> Patrick
Re: [EMF Compare] Bug in detecting added attributes? [message #137358 is a reply to message #137346] Tue, 16 June 2009 11:43 Go to previous messageGo to next message
--------------040107030300030609010203
Thanks, i'll try and investigate some more asap as we haven't detected
such regressions in our tests :(
Patrick K
Re: [EMF Compare] Bug in detecting added attributes? [message #137369 is a reply to message #137358] Tue, 16 June 2009 13:04 Go to previous messageGo to next message
Hi Laurent,
I guess I just catched another unpleasant bug in the other example of the zip (sorry for doing that just before the big release :-/ )
The emfdiff of the Eachonce/eachonce/model_v?.eachonce models contains two UpdateReferences with LeftTarget = RightTarget.
In other words, they do not describe a difference at all ;-)
However, from the two models I expected a change from null to an object, and from an object to null respectively.
I could add that to the existing bug or raise another one? Or did I miss something in this particular case?
Best regards
Patrick
>> Patrick
>>> Hi Patrick,
>>> Laurent Goubet
>>> Obeo
>>>> Cheers,
>>>> short version:
>>>> long(er) version:
>>>> differences:
>>>> and references.
>>>> in total)
>>>> Best regards
>>>> Patrick
Re: [EMF Compare] Bug in detecting added attributes? [message #137381 is a reply to message #137369] Wed, 17 June 2009 04:12 Go to previous messageGo to next message
--------------010203050201000400080009
Hi Patrick,
The "*target" references of most DiffElement describe the value that is
to be copied in either direction by the mergers, not the value actually
changed (not sure I am really clear here :p). Thus tests on these values
can yield strange results sometime.
As you've already raised a bugzilla with both examples, you can add a
comment and a more detailed description of the actual issue you see and
how you've detected it ... I need to investigate to see if there is
actually a bug or if it is intended behavior, yet bug fixing isn't our
priority now except for blockers/criticals.
Laurent Goubet
Obeo
Patrick K
Re: [EMF Compare] Bug in detecting added attributes? [message #137448 is a reply to message #137381] Thu, 18 June 2009 10:55 Go to previous message
Hi Laurent,
I added steps for reproduction in the bug description.
Furthermore I found a ClassCastException in the 'Properties' tab is open in the compare view.
I also added this issue to that bug (because I couldn't reproduce it with another example - I tried a simple ecore model).
Patrick
On 17-06-2009 10:12, laurent Goubet wrote:
> Hi Patrick,
> Laurent Goubet
> Obeo
>> Hi Laurent,
>> Best regards
>> Patrick
>>>> Patrick
>>>>> Hi Patrick,
>>>>> currently
>>>>> Laurent Goubet
>>>>> Obeo
>>>>>> Cheers,
>>>>>> short version:
>>>>>> long(er) version:
>>>>>> differences:
>>>>>> and references.
>>>>>> workbench:
>>>>>> in total)
>>>>>> Best regards
>>>>>> Patrick
Re: [EMF Compare] Bug in detecting added attributes? [message #621028 is a reply to message #137311] Tue, 16 June 2009 09:06 Go to previous message
Hi Patrick,
Laurent Goubet
Obeo
Patrick K
Re: [EMF Compare] Bug in detecting added attributes? [message #621029 is a reply to message #137334] Tue, 16 June 2009 10:08 Go to previous message
Patrick
> Hi Patrick,
> Laurent Goubet
> Obeo
>> Cheers,
>> short version:
>> long(er) version:
>> differences:
>> and references.
>> in total)
>> Best regards
>> Patrick
Re: [EMF Compare] Bug in detecting added attributes? [message #621030 is a reply to message #137346] Tue, 16 June 2009 11:43 Go to previous message
Patrick K
Re: [EMF Compare] Bug in detecting added attributes? [message #621031 is a reply to message #137358] Tue, 16 June 2009 13:04 Go to previous message
Hi Laurent,
Best regards
Patrick
>> Patrick
>>> Hi Patrick,
>>> Laurent Goubet
>>> Obeo
>>>> Cheers,
>>>> short version:
>>>> long(er) version:
>>>> differences:
>>>> and references.
>>>> in total)
>>>> Best regards
>>>> Patrick
Re: [EMF Compare] Bug in detecting added attributes? [message #621032 is a reply to message #137369] Wed, 17 June 2009 04:12 Go to previous message
Hi Patrick,
Laurent Goubet
Obeo
Patrick K
Re: [EMF Compare] Bug in detecting added attributes? [message #621038 is a reply to message #137381] Thu, 18 June 2009 10:55 Go to previous message
Hi Laurent,
Patrick
> Hi Patrick,
> Laurent Goubet
> Obeo
>> Hi Laurent,
>> Best regards
>> Patrick
>>>> Patrick
>>>>> Hi Patrick,
>>>>> currently
>>>>> Laurent Goubet
>>>>> Obeo
>>>>>> Cheers,
>>>>>> short version:
>>>>>> long(er) version:
>>>>>> differences:
>>>>>> and references.
>>>>>> workbench:
>>>>>> in total)
>>>>>> Best regards
>>>>>> Patrick
Previous Topic:[EMF Compare] help in XML diff->patch->apply
Next Topic:[EMF Compare] Integrating EMF Compare in LTK
Current Time: Sun Jul 13 14:27:21 EDT 2025
Powered by FUDForum. Page generated in 0.06451 seconds
