IWAB0024E Error in copying Webservice Utility file-Please-help very very urgent. [message #137260] |
Thu, 08 September 2005 04:12  |
Originally posted by: zousey.hotmail.com
I have made a webservice witch was doing fine, then add some methods then
call some other class in my webservice class, then try to recreate the
webservice, now in running in to this errors.
thanks.
my console output.
IWAB0024E Error in copying Webservice Utility file.
at org.eclipse.core.runtime.Path.<init>(Path.java:182)
org.eclipse.core.internal.resources.WorkspaceRoot.getProject (WorkspaceRoot.java:132)
org.eclipse.jem.util.emf.workbench.ProjectUtilities.getProje ct(ProjectUtilities.java:728)
org.eclipse.jst.ws.internal.consumption.ui.widgets.test.Copy WebServiceUtilsJarCommand.execute(CopyWebServiceUtilsJarComm and.java:64)
org.eclipse.jst.ws.internal.consumption.ui.widgets.test.wssa mple.GSTCGenerateCommand.execute(GSTCGenerateCommand.java:43 )
org.eclipse.jst.ws.internal.consumption.ui.widgets.test.Clie ntTestDelegateCommand.commandFactoryExecution(ClientTestDele gateCommand.java:111)
org.eclipse.jst.ws.internal.consumption.ui.widgets.test.Clie ntTestDelegateCommand.execute(ClientTestDelegateCommand.java :94)
org.eclipse.wst.command.internal.env.core.fragment.CommandFr agmentEngine.runCommand(CommandFragmentEngine.java:335)
org.eclipse.wst.command.internal.env.core.fragment.CommandFr agmentEngine.visitTop(CommandFragmentEngine.java:301)
org.eclipse.wst.command.internal.env.core.fragment.CommandFr agmentEngine.moveForwardToNextStop(CommandFragmentEngine.jav a:217)
org.eclipse.wst.command.internal.env.ui.widgets.SimpleComman dEngineManager$4.run(SimpleCommandEngineManager.java:208)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:346)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:291)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 830)
org.eclipse.wst.command.internal.env.ui.widgets.SimpleComman dEngineManager.runForwardToNextStop(SimpleCommandEngineManag er.java:177)
org.eclipse.wst.command.internal.env.ui.widgets.WizardPageMa nager.runForwardToNextStop(WizardPageManager.java:80)
org.eclipse.wst.command.internal.env.ui.widgets.WizardPageMa nager.performFinish(WizardPageManager.java:220)
org.eclipse.wst.command.internal.env.ui.widgets.DynamicWizar d.performFinish(DynamicWizard.java:336)
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:676)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:349)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:556)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3080)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2713)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:809 )
at org.eclipse.jface.window.Window.open(Window.java:787)
org.eclipse.wst.command.internal.env.ui.widgets.popup.Dynami cPopupWizard.run(DynamicPopupWizard.java:129)
org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:246)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Re: IWAB0024E Error in copying Webservice Utility file-Please-help very very urgent. [message #137672 is a reply to message #137260] |
Fri, 09 September 2005 08:44  |
The exception stack trace matches the one in bug 105601. Comment #11 by Kathy [1] may help: The exception will occur if, on the first page of the
Web service wizard, you select "Test Web service" but not "Generate proxy".You should be able to workaround the problem either by selecting, or
deselecting, both these checkboxes.
Thanks - CB
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=105601#c11
> thanks.
> my console output.
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
FUDForum. Page generated in 0.03634 seconds
