Home » Eclipse Projects » Remote Application Platform (RAP) » How to use the plugin mechanism with RAP?
How to use the plugin mechanism with RAP? [message #137232] Mon, 22 June 2009 04:37 Go to next message
Originally posted by: s0181013.mail.inf.tu-dresden.de
Hello everyone,
The Maildemo.ext shows an example of using the plugin mechanism on
extending the org.eclipse.rap.maildemo with a new navigationbar from the
org.eclipse.rap.maildemo.ext plugin.
I have a View in Plugin A and have written a widget as Composite in
Plugin B. How can I accomplish Plugin B being visible in the View of
Plugin A without importing my widget class of Plugin B in Plugin A?
Re: How to use the plugin mechanism with RAP? [message #137244 is a reply to message #137232] Mon, 22 June 2009 04:59 Go to previous messageGo to next message
If you don't want to have the dependency from A to B, you could declare
your own Extension Point (kind of widget factory) where Plugin B
contributes to.
Stefan.
> Thanks
Re: How to use the plugin mechanism with RAP? [message #137258 is a reply to message #137244] Mon, 22 June 2009 05:54 Go to previous message
Hello Stefan,
first of all, thanks for your reply!
> contributes to.
If there is no dependency from A to B ... where or how can I specify
which widget will be visualized in which view?
So I need somehow identify different Widgets, preferable by their
supporting API, which is not readable in the plugin.xml file and then I
need to specify which widget will should be visualized in which view,
could a hashMap with <Widget, View> be appropriate for that?
Sincerely
Jes
Previous Topic:Ribbon
Next Topic:RAP and org.eclipse.ui.services-Extension-Point
Current Time: Tue Jul 22 08:28:03 EDT 2025
Powered by FUDForum. Page generated in 0.29104 seconds
