"Project does not exist" errors [message #137195] |
Mon, 26 January 2004 17:28 |
I get a recurring error telling me one of my projects does not exist. It
is a non-Java CVS project that works fine (I see it in the Package
explorer, I can check in and out of CVS, I can view the files, etc. etc.).
I thought I'd check with this list before reporting it as a bug.
Can anybody suggest where in the config files the error might stem from?
Typical error log entries:
Error Jan 26, 2004 13:56:00.485 [PROJECT NAME] does not exist.
Error Jan 26, 2004 13:55:54.672 [PROJECT NAME] does not exist.
Error Jan 26, 2004 13:55:54.672 Internal Error
Java Model Exception: Java Model Status [[PROJECT NAME] does not exist.]
org.eclipse.jdt.internal.core.JavaElement.newNotPresentExcep tion(JavaElement.java:477)
org.eclipse.jdt.internal.core.JavaModelManager.getPerProject InfoCheckExistence(JavaModelManager.java:804)
org.eclipse.jdt.internal.core.JavaProject.getPerProjectInfo( JavaProject.java:1724)
org.eclipse.jdt.internal.core.JavaProject.getResolvedClasspa th(JavaProject.java:1835)
org.eclipse.jdt.internal.core.JavaProject.getResolvedClasspa th(JavaProject.java:1815)
org.eclipse.jdt.internal.core.JavaProject.buildStructure(Jav aProject.java:262)
at org.eclipse.jdt.internal.core.Openable.generateInfos(Openabl e.java:200)
org.eclipse.jdt.internal.core.JavaElement.openWhenClosed(Jav aElement.java:488)
org.eclipse.jdt.internal.core.JavaElement.getElementInfo(Jav aElement.java:280)
org.eclipse.jdt.internal.core.JavaElement.getElementInfo(Jav aElement.java:266)
org.eclipse.jdt.internal.core.JavaProject.getJavaProjectElem entInfo(JavaProject.java:1418)
org.eclipse.jdt.internal.core.JavaProject.getNameLookup(Java Project.java:1427)
at org.eclipse.jdt.internal.core.Openable.codeSelect(Openable.j ava:147)
org.eclipse.jdt.internal.core.CompilationUnit.codeSelect(Com pilationUnit.java:268)
org.eclipse.jdt.internal.core.CompilationUnit.codeSelect(Com pilationUnit.java:262)
org.eclipse.jdt.internal.ui.actions.SelectionConverter.codeR esolve(SelectionConverter.java:223)
org.eclipse.jdt.internal.ui.actions.SelectionConverter.codeR esolve(SelectionConverter.java:152)
org.eclipse.jdt.internal.ui.actions.SelectionConverter.codeR esolve(SelectionConverter.java:161)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:12 2)
org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchR un(SelectionDispatchAction.java:216)
org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(Selec tionDispatchAction.java:188)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:842 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:509)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:461)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:408)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:847)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2311)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1992)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1506)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1482)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:246)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:139)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:47)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:85)
at org.eclipse.core.launcher.Main.basicRun(Main.java:279)
at org.eclipse.core.launcher.Main.run(Main.java:742)
at org.eclipse.core.launcher.Main.main(Main.java:581)
FUDForum. Page generated in 0.04643 seconds
