Any way to only show label values when mouse hovers over the data point marker? [message #137128] |
Tue, 28 February 2006 14:36  |
Originally posted by: mikewulkan.flyingmoose.ca
Many charting applications allow the label values to be hidden and shown
only when the mouse hovers over the specified data marker. There are
variations where all the label values for a given series show themselves
when the mouse hovers over the series graph. Any way to do this with BIRT?
Mike
Re: Any way to only show label values when mouse hovers over the data point marker? [message #138121 is a reply to message #138041] |
Thu, 02 March 2006 09:44   |
Okay, stumbled into the solution. Just change the DataPoint values for the
series. BTW., that is a terrible dialog, there is no indication that one
must remove an entry before one can change it's attributes by adding it
back! I missed this the first time because I just selected "Orthoganal
Value" and added a prefix, which did nothing. I had to remove "Orthoganal
Value" and then add it back with the prefix specified at the same time!
Mike
"Mike Wulkan" <mikewulkan@flyingmoose.ca> wrote in message
news:du6tm1$e5s$1@utils.eclipse.org...
> Please forgive me if I am being dense, but the content of the label is
> derived from the data value of the point. I couldn't see any way to
change
> this without also changing the actual contents of the data? What I am
after
> is something like this:
> If the data value is "10" and this represents the "Number of Widgets", I
> would like the tooltip to display: "Number of Widgets: 10".
> I am very new to BIRT so more specific instructions would be greatly
> appreciated.
> Mike
> "David Michonneau" <dmichonneau@actuate.com> wrote in message
> news:du6quv$8us$1@utils.eclipse.org...
> > Yes of course. You simply change the content of the label, since the
> tooltip
> > shows the same thing as the label. Of course the label can still be set
> > invisible.
> > Thanks,
> > David
> > news:du4p6e$ndl$1@utils.eclipse.org...
> > > Thanks, that is great! Now time to get picky... is there any way to
> > > influence the contents of the tooltip? I'd like the tooltip to
display
> > > the
> > > name of the series as well as the data point value. This would make
it
> > > easier for the user by not forcing the user to refer to the legend all
> the
> > > time.
> > > Mike
> > > news:du3km5$7t2$1@utils.eclipse.org...
> > >> Yes, this can be done. You simply hide the marker value and set the
> > >> series
> > >> interactivity to show the tooltip on mouseover.
> > >> Thanks,
> > >> David
> > >> news:du28nb$d3k$1@utils.eclipse.org...
> > >> > shown
are
> > >> > themselves
with
> > >> > BIRT?
> > >> > Thanks,
> > >> > Mike
FUDForum. Page generated in 0.05285 seconds
