Real-time update of Problems view? [message #137126] |
Tue, 01 February 2005 09:53  |
Originally posted by: none.nowhere.no
Managed make project: "make clean; make all". This takes a few minutes on
a project I'm working on; lots of code.
When errors are discovered by the GCC compiler, they show up in the
Console view in real time. However, they don't show up in the Problems
view until the entire compilation has completed.
This wastes a lot of time since when I see the first error, I usually
start looking into it while the rest of the build completes.
Any way (or plans) to improve this situation? Should I file this as a bug?
/Martin.
PS. Right now I run a silly scheme where I do most editing in Eclipse,
then switch to Emacs for the initial build-edit-build-again cycle where I
kill syntax errors. When things compile, I go back to Eclipse, refresh,
and move on from there. That's a bit tiresome...
Re: Real-time update of Problems view? [message #137841 is a reply to message #137126] |
Fri, 04 February 2005 12:24  |
Not at this point, the is no possible callback when the build starts,
so basically:
= Eclipse starts the build
= all the markers(errors) are removed
= the logs are accumulated for processing
= at the end of the build we refresh the project
since files are modified/created/added outside of Eclipse knowledege
= the accumulated errors are set on the IResource
eclipse-3.{0,1} as an automatic refresh, you should not have to do refresh
manually, look at the preference page it is probably off by default
Anyway .. good point .. an enhancement pr ??
FUDForum. Page generated in 0.03670 seconds
