[EMF Compare] what about cross-references of a merged eObject ? [message #137012] |
Tue, 09 June 2009 07:56  |
I am doing some trails on EMF Compare with the EMF ExtLibrary example.
When we select an object from the right-side to copy on to the left-side
(using the Compare UI) ... the cross-references of the old object are not
reflected on its copy.
Let's say there are 2 library instances.
Litrary01 (leftside): no books
Library02: has a book which is associated with an author.
When i copy the book from right to left, the author is not included. It
seems fine but infact i feel the merge can be more smart in copying the
cross-references of the copy object to the destination tree.
Does EMF Compare provide such a merge functionality off the shelf ? or
can we use an extension-point to tweak only this part of the merge.
- Chetan Kumar
Re: [EMF Compare] what about cross-references of a merged eObject ? [message #137248 is a reply to message #137072] |
Sun, 14 June 2009 14:07  |
Hello Laurent,
Thank you for yer response.
That makes sense.
laurent Goubet wrote:
> Hi Chetan,
> This behavior is intentional. We don't copy cross references to non
> existing objects (some people might want it, some others not as all use
> cases don't apply to one case or the other).
> If you copy the book, its reference towards an author is not copied
> alongside it. If you then copy the author, the reference should be
> restored as it should.
> You can tweak this part of the merge by overriding the existing mergers
> (see extension point org.eclipse.emf.compare.diff.mergerprovider ).
> Laurent Goubet
> Obeo
> Chetan Kumar a écrit :
>> not reflected on its copy.
>> Library02: has a book which is associated with an author. When i copy
>> the book from right to left, the author is not included. It seems fine
>> - Chetan Kumar
Re: [EMF Compare] what about cross-references of a merged eObject ? [message #621005 is a reply to message #137012] |
Tue, 09 June 2009 12:27  |
--------------010309000601020706030502
Hi Chetan,
Laurent Goubet
Obeo
Chetan Kumar a
Re: [EMF Compare] what about cross-references of a merged eObject ? [message #621020 is a reply to message #137072] |
Hello Laurent,
That makes sense.
> Hi Chetan,
> Laurent Goubet
> Obeo
>> - Chetan Kumar
FUDForum. Page generated in 0.04285 seconds
