Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [EMF Compare] New metamodel API & Detecting changes to specific model elements
[EMF Compare] New metamodel API & Detecting changes to specific model elements [message #136859] |
Fri, 29 May 2009 15:11  |
I would like to upgrade some code from the Metamodel API used in 0.8.0
to the new one used in 0.9.0 (being new to EMF Compare).
The goal of the code is to detect if specific model (xml-schema)
elements have changed, so the current logic is to search for a path to
the relevant elements in the DiffModel.
I'm wondering if this is the recommended way and how does the API change
affect the algorithm (we are only impacted by the -now gone-
AddModelElement and RemoveModelElement classes).
Thanks!
Abel Muiño
Re: [EMF Compare] New metamodel API & Detecting changes to specific model elements [message #137665 is a reply to message #137576] |
Thu, 25 June 2009 05:10   |
--------------010705070302050607040807
Content-Type: text/plain; charset=UTF-8; format=flowed
Hi Abel,
I can't say for sure since I don't know how old your existing
application is. My best bet is that it's been written before we fixed
https://bugs.eclipse.org/bugs/show_bug.cgi?id=232277 . We had inverted
the "left" and "right" models within EMF Compare (intentionally at first
.... before we found out that wasn't a good thing :p). As we've set back
both side to what they should be, most "left" references are now the
"right" and vice-versa.
Hope this helps.
Laurent Goubet
Obeo
Abel Muio Vizcaino a écrit :
> Sorry to come back to this so late...
> With the information on the bugzilla you have pointed me, I was able to
> replace every check for AddModelElement to ModelElementChangeLeftTarget
> and every check for RemoveModelElement to ModelElementChangeRightTarget.
> Is this right?
> Since before the API change, AddModelElement extended
> ModelElementChange_Right_Target and now I must use _Left_, I find that
> the code which was previously using AddModelElement#getRighElement()
> does not build now.
> Can you advice on what should I use instead? (getLeftElement()?
> getRightParent?) Has this impact on the logic that was implemented in
> our plugin before the change?
> (Sorry for so many questions, but I am completly new to EMF compare and
> I am trying to evolve an existing codebase)
> Thanks!
> Abel Muiño
> laurent Goubet wrote:
>> Hi Abel,
>> We broke a good part of the diffmodel between the 0.8 and 0.9, mostly
>> to try and make it a little less complex and convoluted than it was.
>> The most impacting changes are listed on bug 233451 :
>> https://bugs.eclipse.org/bugs/show_bug.cgi?id=233451
>> Don't hesitate to let us know if this isn't enough information.
>> Laurent Goubet
>> Obeo
>>> Hello,
>>> 0.8.0 to the new one used in 0.9.0 (being new to EMF Compare).
>>> to the relevant elements in the DiffModel.
>>> change affect the algorithm (we are only impacted by the -now gone-
>>> Thanks!
>>> Abel Muiño
Content-Type: text/x-vcard; charset=utf-8;
name="laurent_goubet.vcf"
Content-Disposition: attachment;
filename="laurent_goubet.vcf"
YmVnaW46dmNhcmQNCmZuOkxhdXJlbnQgR291YmV0DQpuOkdvdWJldDtMYXVy ZW50DQpvcmc6
PGEgaHJlZj0iaHR0cDovL3d3dy5vYmVvLmZyLyI+T2JlbzwvYT4NCmVtYWls O2ludGVybmV0
OmxhdXJlbnQuZ291YmV0QG9iZW8uZnINCnVybDpodHRwOi8vd3d3Lm9iZW8u ZnINCnZlcnNp
b246Mi4xDQplbmQ6dmNhcmQNCg0K
--------------010705070302050607040807--
Re: [EMF Compare] New metamodel API & Detecting changes to specific model elements [message #137677 is a reply to message #137665] |
Thu, 25 June 2009 12:05  |
That was it,
We were using 0.8.1, so I reversed the methods and our unit tests are
all green again.
Thanks a lot!
> Hi Abel,
> Hope this helps.
> Laurent Goubet
> Obeo
>> to replace every check for AddModelElement to
>> ModelElementChangeLeftTarget and every check for RemoveModelElement to
>> Is this right?
>> does not build now.
>> and I am trying to evolve an existing codebase)
>> Thanks!
>> Abel Muiño
>>> Hi Abel,
>>> Laurent Goubet
>>> Obeo
>>>> Hello,
>>>> Thanks!
>>>> Abel Muiño
Re: [EMF Compare] New metamodel API & Detecting changes to specific model elements [message #620997 is a reply to message #136859] |
Thu, 04 June 2009 11:18  |
--------------070109060703050104000607
Hi Abel,
We broke a good part of the diffmodel between the 0.8 and 0.9, mostly to
try and make it a little less complex and convoluted than it was. The
Laurent Goubet
Obeo
> Hello,
> Thanks!
> Abel Muiño
--------------070109060703050104000607--
Re: [EMF Compare] New metamodel API & Detecting changes to specific model elements [message #621049 is a reply to message #136980] |
Wed, 24 June 2009 16:47  |
Is this right?
does not build now.
Thanks!
Abel Muiño
> Hi Abel,
> Laurent Goubet
> Obeo
>> Hello,
>> Thanks!
>> Abel Muiño
Re: [EMF Compare] New metamodel API & Detecting changes to specific model elements [message #621056 is a reply to message #137576] |
Hi Abel,
Hope this helps.
Laurent Goubet
Obeo
> Is this right?
> does not build now.
> Thanks!
> Abel Muiño
>> Hi Abel,
>> Laurent Goubet
>> Obeo
>>> Hello,
>>> Thanks!
>>> Abel Muiño
Re: [EMF Compare] New metamodel API & Detecting changes to specific model elements [message #621057 is a reply to message #137665] |
That was it,
all green again.
Thanks a lot!
> Hi Abel,
> Hope this helps.
> Laurent Goubet
> Obeo
>> Is this right?
>> does not build now.
>> Thanks!
>> Abel Muiño
>>> Hi Abel,
>>> Laurent Goubet
>>> Obeo
>>>> Hello,
>>>> Thanks!
>>>> Abel Muiño
Current Time: Sat Jul 12 21:30:36 EDT 2025
Powered by FUDForum. Page generated in 0.05878 seconds
