Home » Archived » COSMOS » Instance Id Constraint and record type constraint in same template,not possible?
Instance Id Constraint and record type constraint in same template,not possible? [message #12573] Thu, 19 February 2009 09:01 Go to next message
Hi ,
I am not able to run the query when I am having the instance id
constraint , record type constraint with in a same template. when I am
running the following query file ,
<query xmlns="http://cmdbf.org/schema/1-0-0/datamodel">
<itemTemplate id="template2">
<instanceIdConstraint>
<instanceId>
<mdrId>CCMDBMDR</mdrId>
<localId>Server1</localId>
</instanceId>
</instanceIdConstraint>
<recordConstraint>
<recordType localName="OS" namespace=""/>
</recordConstraint>
</itemTemplate>
</query>
I am getting the following exception.
Exception in thread "main" java.lang.NullPointerException
com.ibm.cmdbf.query.CMDBfQueryOperation.applyItemConstraints (CMDBfQueryOperation.java:485)
com.ibm.cmdbf.query.CMDBfQueryOperation.processItemTemplates (CMDBfQueryOperation.java:216)
com.ibm.cmdbf.query.CMDBfQueryOperation.execute(CMDBfQueryOp eration.java:139)
com.ibm.cmdbf.query.CMDBfQueryOperation.execute(CMDBfQueryOp eration.java:126)
at com.ibm.cmdbf.query.QueryLauncher.getResponse(QueryLauncher. java:93)
at com.ibm.cmdbf.query.QueryLauncher.main(QueryLauncher.java:64 )
I am getting the error on the applyItemConstraints method , Logically it
is wrong to have the instance id constraint record constraint with in the
same template , but the api is just throwing the null pointer exception.
Is this not possible to have the instance id constraint and record
constraint with in the same template ?
if this is not possible the API should inform the user by throwing the
custom exception something like "it is not possible to have the instance
id constraint and record constraint with in the same template"
Arunachalam.
Re: Instance Id Constraint and record type constraint in same template,not possible? [message #12593 is a reply to message #12573] Thu, 19 February 2009 19:15 Go to previous message
Originally posted by: david_whiteman.us.ibm.com
Please create a bug report for this in bugzilla.
Thanks!
David
arunachalam wrote:
> Hi ,
> <instanceId>
> </instanceId>
> <recordConstraint>
> </recordConstraint>
> </itemTemplate>
> </query>
> at
> at
> at
> at
> Logically it is wrong to have the instance id constraint record
> constraint with in the same template , but the api is just throwing the
> the custom exception something like "it is not possible to have the
> instance id constraint and record constraint with in the same template"
> Regards
> Arunachalam.
Re: Instance Id Constraint and record type constraint in same template,not possible? [message #572516 is a reply to message #12573] Thu, 19 February 2009 19:15 Go to previous message
Thanks!
David
arunachalam wrote:
> Hi ,
> <instanceId>
> </instanceId>
> <recordConstraint>
> </recordConstraint>
> </itemTemplate>
> </query>
> at
> at
> at
> at
> Regards
> Arunachalam.
Previous Topic:Instance Id Constraint and record type constraint in same template,not possible?
Next Topic:COSMOS V1.1M1 is now available
Current Time: Tue Jul 22 12:57:09 EDT 2025
Powered by FUDForum. Page generated in 0.06108 seconds
