Home » Eclipse Projects » eRCP » Re: Is it posssible to catch eWorkbench CLOSE event?
Re: Is it posssible to catch eWorkbench CLOSE event? [message #1040] Tue, 26 May 2009 12:10 Go to next message
Usually it is better to state what you are trying to accomplish instead of
asking how to accomplish something concrete, because the concrete thing you want
to do might not be possible, but there might be other solutions to your problem,
which are more suitable. The other problem is that I can suggest a way to do
this, but it serves no purpose to you, because you want different event. Let me
suggest some:
1) shell close event
2) menu item listener (if you are able to get access to the menu, through the shell)
3) using org.eclipse.ui.IWindowListener you will be notified when
IWorkbenchWindows are closed
There might be other ways, which I'm not aware currently of. But the best
solution to your problem you can get if you describe what you are trying to
accomplish.
P.S.
eRCP newsgroup has moved to eclipse.ercp. I'm copying this thread over.
Arunagiri.K wrote:
> Dear All,
> Is it possible to catch the workbench's close event (Exit menu item's
> event on the workbench menu)? If yes, how?
> Thanks.
> -arun
Re: Is it posssible to catch eWorkbench CLOSE event? [message #1124 is a reply to message #1040] Thu, 28 May 2009 10:04 Go to previous messageGo to next message
Thanks to Matthias & Danail.
I want to listen the CLOSE event because, if the user closes the
workbench/application unknowingly it will immediately close. I just want
to raise a confirm message, so the user can know the application is
closing and save the unsaved data if any or just cancel the close.
How can I do this?
Thanks to the great support.
-arun
Re: Is it posssible to catch eWorkbench CLOSE event? [message #499663 is a reply to message #1040] Mon, 23 November 2009 11:17 Go to previous messageGo to next message
Hi Dannail,
I just posted a new topic http://www.eclipse.org/forums/index.php?t=msg&th=158260& amp;start=0&S=d53c839c239efd3b5a176fb3ce25bccb
Could you please suggest ?
Many thanks in advance.
Re: Is it posssible to catch eWorkbench CLOSE event? [message #563026 is a reply to message #1040] Thu, 28 May 2009 10:04 Go to previous messageGo to next message
How can I do this?
-arun
Re: Is it posssible to catch eWorkbench CLOSE event? [message #564083 is a reply to message #1040] Mon, 23 November 2009 11:17 Go to previous message
Hi Dannail,
Previous Topic:eRCP application WorkbenchAdvisor
Next Topic:Animated GIF on WM
Current Time: Tue Nov 18 13:54:23 EST 2025
Powered by FUDForum. Page generated in 0.05080 seconds
