JSP Validation [message #136743] |
Tue, 06 September 2005 08:20  |
Originally posted by: guillaume.andreys.netcourrier.com
Hi !
I have wtp 0.7 with eclipse 3.1.
I am working in a JSP/Servlet project.
Here is my problem : wtp is not validating correctly my JSP's. For
example, if I am refactoring one methode in a class that is call in one
JSP, the validator won't detect that there is an error in this JSP. Has
there is no compilation of the JSP, that is a big problem because I will
not see that there is a problem until I am going on this page ...
If I am in one JSP, and I have an error, I can see it in the JSP, but this
will never be shown in the Problems view, neither there will be a red
crosse on the JSP.
The only error that are shown are an other problem : It's not recognizing
Personal tag lib. I have tags that are puting result in variables and I am
using that variable in the JSP. The validator is not doing the correlation
and it detect an error. That's the only one !
Can you help me ?
Here is my configuration :
In my configuration, in the validation part I have selected :
Run validation when you manually build a project
Run validation automatically when you save changes to a ressource
The two selected validations are : HTML Syntaxe Validator, JSP syntaxe
validator
And I have maximum number of validation message of the project : 200
In Project I selected build Automaticaly
Thinks
Re: JSP Validation [message #141200 is a reply to message #136743] |
Wed, 28 September 2005 23:59   |
Originally posted by: big_seal.msn.com
Alse to me .
bigseal
"Guillaume" <guillaume.andreys@netcourrier.com>
??????:9dec45d03dbbbe2487a0b4b5dd786c79$1@www.eclipse.org...
> Hi !
> crosse on the JSP.
> Can you help me ?
> validator
> Thinks
Re: JSP Validation [message #141209 is a reply to message #136743] |
Alse to me .
bigseal
> Hi !
> crosse on the JSP.
> Can you help me ?
> validator
> Thinks
Re: JSP Validation [message #141220 is a reply to message #136743] |
Alse to me .
bigseal
> Hi !
> crosse on the JSP.
> Can you help me ?
> validator
> Thinks
FUDForum. Page generated in 0.09228 seconds
