Home » Eclipse Projects » GEF » [Draw2d] Max dimension, layout & BlocFlow
[Draw2d] Max dimension, layout & BlocFlow [message #136592] Mon, 07 June 2004 06:10 Go to next message
Originally posted by: christophe.labouisse.mycom-int.com
I have to make a tooltip including a description. Since this description
can be of arbitrary length, though of using the flow capability of draw2d.
I did the following:
- Create a MyTooltip class extending Figure (I also try Panel),
- Add a Layout manager,
- Add a FlowPage to MyTooltip,
- Add some BlockFlow to this page.
So far everything works fine except that I cannot find a
contraints/layout/set(Min|Max|Prefered)Size combination allowing to
tooltip not to exceed a max width by "flowing" the description on several
lines if needed (It'll also be nice to "..." the text if the tooltip reach
a max height but I'll live without it).
Currently I only manage to have either a tooltip with a "right" size for
the description text but displaying the text on one loooong line instead
of breaking it, having a obscenely big size even when holding only a
couple of words and having a tooltip "clipped" to a maximum width but
keeping only a one line height.
Any hint?
PS: Using Eclipse 3.0RC1 Draw2d 20040603 (?)
Re: [Draw2d] Max dimension, layout & BlocFlow [message #136655 is a reply to message #136592] Mon, 07 June 2004 10:02 Go to previous messageGo to next message
Originally posted by: rlemaigr.ulb.ac.be
Hello christoffe,
I never used the text package nor tooltips (or almost never) so this is =
not really an "answer" you will have to wait for the specialists...
Looking at the method which shows the tooltip, it seems (I'm not 100% =
sure) that the method is giving the tooltip its preferred size.
Are you sure the preferred size which is returned by the getPreferredSiz=
e =
method of the tooltip is the one you specified ?
Maybe you could try to override the method getPreferredSize(int hinta, i=
nt =
hintb) in your tooltip class like,
public Dimension getPreferredSize(int a, int b)
return new Dimension(100,100);//for example...
just to be absolutly sure that the returned preferred size is what you =
want, just to see what happens then...That costs nothing to try...
There is also the fact that the text layout manager when he computes the=
preferred size of the text should know about the how many lines or how =
many rows (or how many pixels...don't know...) are available, I think. S=
o =
the problem may come from the "hints" given to the getPreferredSize meth=
od =
of the Figure where the text is written...
These are just ideas...nothing sure...
r=E9gis
On Mon, 07 Jun 2004 12:10:14 +0200, Christophe Labouisse =
<christophe.labouisse@mycom-int.com> wrote:
> I have to make a tooltip including a description. Since this descripti=
on
> can be of arbitrary length, though of using the flow capability of =
> draw2d.
> tooltip not to exceed a max width by "flowing" the description on seve=
ral
> lines if needed (It'll also be nice to "..." the text if the tooltip =
> reach
> Currently I only manage to have either a tooltip with a "right" size f=
or
> the description text but displaying the text on one loooong line inste=
ad
> Any hint?
Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
Re: [Draw2d] Max dimension, layout & BlocFlow [message #136667 is a reply to message #136592] Mon, 07 June 2004 10:35 Go to previous messageGo to next message
You probably don't need the block inside the page. A page is a block. To
set the width, use FlowPage#setRecommendedWidth(). The page's preferred
size may exceed that width only if you have a huge word without spaces.
"Christophe Labouisse" <christophe.labouisse@mycom-int.com> wrote in message
news:pan.2004.06.07.10.10.11.760024@mycom-int.com...
> Any hint?
Re: [Draw2d] Max dimension, layout & BlocFlow [message #136725 is a reply to message #136667] Mon, 07 June 2004 11:10 Go to previous messageGo to next message
Ok thanks for the advice.
> To
Sounds nice however this method is private (well at least in the version I
use) so I cannot call it except by resorting ugly things. I notice that
setBounds call super.setBounds I'm afraid that this won't solve my problem
since I'll probably end up with page not having the excepted behavior. Am
I wrong ?
Re: [Draw2d] Max dimension, layout & BlocFlow [message #136761 is a reply to message #136725] Mon, 07 June 2004 11:19 Go to previous message
OK, so open a bug so we can make this easier.
The workaround is to create an anonymous subclass which overrides
getPreferredSize(int, int), and calls super with the desired width.
news:pan.2004.06.07.15.10.16.800772@mycom-int.com...
Previous Topic:Strange behaviour of a Label with a Border ?
Next Topic:GEF clipboard
Current Time: Fri Jul 18 01:44:07 EDT 2025
Powered by FUDForum. Page generated in 0.29235 seconds
