Home » Eclipse Projects » Remote Application Platform (RAP) » Bug in Table.getColumnOrder() when after moving a column
Bug in Table.getColumnOrder() when after moving a column [message #136507] Tue, 16 June 2009 13:03 Go to next message
Hi all,
When I drag and drop a column, the call of Table.getColumnOrder() returns
a wrong array when the first column of the table are hidden thanks to a
scroll bar which is outside the table.
It seems that the new position of the moved column is calculated without
these hidden column.
Example : I have 10 columns, the 5 first are hidden, the other one are
visible.
Order is : [0,1,2,3,4,5,6,7,8,9]
If I move 9 before 7 I should have [0,1,2,3,4,5,6,9,7,8]
And I obtain [0,1,9,2,3,4,5,6,7,8]
If needed, I will try to extract a snippet from my code, just ask.
Loïc
Re: Bug in Table.getColumnOrder() when after moving a column [message #136569 is a reply to message #136507] Wed, 17 June 2009 09:30 Go to previous messageGo to next message
Loïc,
with the latest version from CVS I cannot reproduce what you
describe. Which version are you using?
Rüdiger
Loïc Bertholet wrote:
> Hi all,
> returns a wrong array when the first column of the table are hidden
> thanks to a scroll bar which is outside the table.
> visible.
> Loïc
Re: Bug in Table.getColumnOrder() when after moving a column [message #136606 is a reply to message #136569] Wed, 17 June 2009 11:14 Go to previous messageGo to next message
Hi Rüdiger,
I'm also using the latest version from CVS.
It is happening on FF3 and IE7.
And it only happens when some TableColumns of the beginning are hidden by
a scroll bar which is not the Table one : my Table does not have scroll
bar.
It can be the scroll bar of the ScrolledComposite or the View which
contained the Table.
I will try to provide a snippet as soon as possible.
Loïc
Rüdiger Herrmann wrote:
> Loïc,
> Cheers,
> Rüdiger
>> Hi all,
>> visible.
>> Thanks,
>> Loïc
Re: Bug in Table.getColumnOrder() when after moving a column [message #136618 is a reply to message #136606] Wed, 17 June 2009 11:17 Go to previous messageGo to next message
I think the ScrolledComposite was the thing missing.
Feel free to file a bugzilla and attach the code there.
> Hi Rüdiger,
> by a scroll bar which is not the Table one : my Table does not have
> scroll bar.
> Loïc
>> Loïc,
>> with the latest version from CVS I cannot reproduce what you describe.
>> Cheers,
>> Rüdiger
>>> Hi all,
>>> without these hidden column.
>>> are visible.
>>> Thanks,
>>> Loïc
Re: Bug in Table.getColumnOrder() when after moving a column [message #136642 is a reply to message #136618] Wed, 17 June 2009 12:35 Go to previous message
Done : https://bugs.eclipse.org/bugs/show_bug.cgi?id=280636
Previous Topic:Pictures in body.html used for branding
Next Topic:Rap (jetty server) ---> https connection how to
Current Time: Fri Jul 18 02:16:00 EDT 2025
Powered by FUDForum. Page generated in 0.07485 seconds
