Home » Eclipse Projects » Eclipse Platform » Use features or other method to replace class
Use features or other method to replace class [message #136384] |
Fri, 26 September 2003 07:13  |
Originally posted by: scheglov_ke.nlmk.ru
Is this possible with features to replace existed class in plugin?
For example I have small patch to exclude Swing/AWT and some other classes
from code completion. But it changes existed classes from JDT Core/UI. If
I start runtime workbench, feature replaces JDT classes, but when I start
separate Eclipse - no. I think that reason is in order of plugin loading
for runtime workbench, so this is just bug that it works.
So, is there any good way do replace class? Only way I know is to change
plugin.xml and add my jar before original jar's. Does not looks as good way...
SY, Konstantin.
Advanced Eclipse SWT Designer (http://www.swt-designer.com)
Re: Use features or other method to replace class [message #136666 is a reply to message #136384] |
Fri, 26 September 2003 12:04   |
You mean, you replaced a few classes in a given plugin, wrote a feature,
installed the feature, restart Eclipse, and the new feature is not used?
Did you check Help > About > Configuration Details to see what
version of your feature is loaded?
Chris
"Konstantin Scheglov" <scheglov_ke@nlmk.ru> wrote in message
news:kENZ58BhDHA.3452@fairy.ao.nlmk...
classes
way...
> SY, Konstantin.
Re: Use features or other method to replace class [message #137365 is a reply to message #136666] |
Mon, 29 September 2003 08:09   |
Chris Laffra <Chris_Laffra@oti.com> wrote:
I mean that I want to replace several classes in JDT.
So, I create feature where I place these classes and change them.
When I start Runtime workbench, I see that classes are changed, they
work different than standard ones, so this is OK.
When I start separate Eclipse (with feature, and feature is loaded) - I see
that classes remain unchanged.
> Chris
> classes
> way...
>> SY, Konstantin.
SY, Konstantin.
Re: Use features or other method to replace class [message #137611 is a reply to message #137375] |
Mon, 29 September 2003 15:31  |
news:oO4l%23KohDHA.4044@fairy.ao.nlmk...
> > You can probably create a feature patch for JDT and install it using the
> > update manager. Take a look at the Patches section at
http://dev.eclipse.org/viewcvs/index.cgi/~checkout~/platform -update-home/doc/new_in_2.0.2.html
> Hmm... Please correct me if I am wrong, but it seams that this related
only
> with update manager? I don't want to change original jar's using update
> manager, I want to do this only by plugin (feature) installation.
A patch is not actually modifying existing features/plugins, but installs
newer patched versions. Patches are only needed when you want to update an
included feature that is not a root feature, but this may not always work,
depending on the update policy.
At worst, create a new feature (with a new feature id) that ships a newer
version of the plugin you want to change and install it. The platform will,
at runtime, pick the higher version.
> > and in the online docs
http://help.eclipse.org/help21/topic/org.eclipse.platform.do c.isv/reference/misc/feature_archive.html
> > -Dorian
> > classes
If
start
loading
change
> > way...
> >> SY, Konstantin.
> SY, Konstantin.
Current Time: Sun Aug 31 23:29:32 EDT 2025
Powered by FUDForum. Page generated in 0.04326 seconds
