Home » Eclipse Projects » GEF » Strange behaviour of a Label with a Border ?
Strange behaviour of a Label with a Border ? [message #136378] |
Fri, 04 June 2004 21:28  |
Originally posted by: rlemaigr.ulb.ac.be
the text and icon locations in a Label seem to be calculated based on th=
e =
bounds. I don't understand why and I would have expected it would have =
been based on the client area instead.
I've written a BottomLineBorder class to add a line at the bottom of som=
e =
figures and I've tried to use it with Labels, but if the line is large, =
the text is covered by my line. I've had the same problem with margin =
border. When I add a Margin border like new MarginBorder(10,0,0,0), the =
text stays at the center of the bounds and the only effect of my =
MarginBorder is to change the preferred size of the label.
In fact it's the same with other Figures like RectangleFigure...
The paintFigure method of RectangleFigure is
protected void outlineShape(Graphics graphics) {
Rectangle r =3D getBounds();
int x =3D r.x + lineWidth / 2;
int y =3D r.y + lineWidth / 2;
int w =3D r.width - lineWidth;
int h =3D r.height - lineWidth;
graphics.drawRectangle(x, y, w, h);
So if I add a border to my rectangle, the outline of the rectangle will =
be =
coverd by the border...I think it is strange and unexpected...
Is it some kind of mistake ? Or is it me that don't understand something=
Thanks for your answers,
r=E9gis
Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
Re: Strange behaviour of a Label with a Border ? [message #136689 is a reply to message #136378] |
Mon, 07 June 2004 10:43   |
the text and icon locations in a Label seem to be calculated based on the
RH> There are several places where Label calls getInsets(), this should be
equivalent to using the client area.
I've written a BottomLineBorder class to add a line at the bottom of some
RH> RectangleFigure is just a silly shape. If you want a rectangular border
which nests, use LineBorder().
Rectangle r = getBounds();
int x = r.x + lineWidth / 2;
int y = r.y + lineWidth / 2;
int w = r.width - lineWidth;
int h = r.height - lineWidth;
So if I add a border to my rectangle, the outline of the rectangle will be
Is it some kind of mistake ? Or is it me that don't understand something ?
r
Re: Strange behaviour of a Label with a Border ? [message #136702 is a reply to message #136643] |
Mon, 07 June 2004 10:45   |
RH> You are correct, getPreferredSize may return a Dimension by *reference*,
and it should never be modified by the caller. If you see a case where this
happens, please report a bugzilla. Caching is common and it is what all of
our LayoutManagers do by default. So there should be lots of examples of a
cached preferred size being returned.
<rlemaigr@ulb.ac.be> wrote in message
news:opr878foukxn9g2u@xn--pcrgis-dva.mshome.net...
Another strange thing I've just noticied:
In the IFigure interface, the description of the getPreferredSize method
says:
" Returns the desireable size for this IFigure using the provided width
and height hints.
Returned Dimension is by value. If a hint is less than or equal to 0
(usually, it's
set to -1), it means that hint should be ignored."
But the implementation of this method in the Figure class begins with:
public Dimension getPreferredSize(int wHint, int hHint)
if (prefSize != null)
return prefSize;
So the preferred size seems to be return by referrence and not by value,
so I can't modify the result without copy it before.
(In one of my Figure classes, I've redifined the getPreferredSize and the
layout methods and in the getPreferredSize method if I don't return a copy
of my cached preferredSize, it don't work at all. The parent layout
manager is ToolbarLayout.)
Is that a bug in the getPreferredSize method or a problem in its
definition in the IFigure interface ? Or it is me that don't understand
smthg ?
r
Re: Strange behaviour of a Label with a Border ? [message #136749 is a reply to message #136689] |
Mon, 07 June 2004 11:17  |
> RH> There are several places where Label calls getInsets(), this shoul=
d =
> be equivalent to using the client area.
Ok I didn't noticed that. But no it seems not equivalent and that's my =
problem, see my example here:
> I've written a BottomLineBorder class to add a line at the bottom of s=
ome
> figures and I've tried to use it with Labels, but if the line is large=
> border. When I add a Margin border like new MarginBorder(10,0,0,0), th=
e
Please try a Label with a border with an asymetrical MarginBorder like n=
ew =
CompoundBorder(new LineBorder(1), new MarginBorder (20,0,0,0)) , put the=
Label in a parent figure with a layout manager which gives the Label its=
preferred size and you will see that the text stays at the center of the=
bounds and not in the center of the client area. And if the border is =
large, the text is covered by the border...
With this border:
Label lab =3D new Label("qsdfqsdf");
lab.setBorder(new CompoundBorder(new LineBorder(1), new CompoundBorder(n=
ew =
MarginBorder (50,0,0,0), new LineBorder(1))));
I have this:
http://users.skynet.be/mon.mignon.petit.site/lab.gif ( the text should b=
e =
in the little black rectangle )
And with this border:
lab.setBorder(new CompoundBorder(new LineBorder(1),new =
BottomLineBorder(10)));
I have this
http://users.skynet.be/mon.mignon.petit.site/lab2.gif (the text should n=
ot =
be partially hidden by the black line)
r=E9gis
Current Time: Sun Aug 31 13:34:04 EDT 2025
Powered by FUDForum. Page generated in 0.04887 seconds
