Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [CDO] feature value synchronization
[CDO] feature value synchronization [message #136320] Wed, 13 May 2009 07:46 Go to next message
I have an EMF feature. The feature value must be "synchronized" with
another non-EMF feature (e.g. simple java class field). The initial idea
was to override eGet, sSet methods to synchronize the values.
Unfortunately these methods are not called when committing/loading the cdo
object.
There are methods cdoInternalPreCommit and cdoInternalPostLoad, but in
another thread I've found that "its calling semantics are not officially
specified and they could change without notice."
Are there any suggestions how such synchronization can be achieved?
In generally what I need is a call to my method when the EMF feature value
is set/get.
Re: [CDO] feature value synchronization [message #136339 is a reply to message #136320] Wed, 13 May 2009 08:04 Go to previous message
Martynas,
CDO is supported in the EMF newsgroup where you also asked this question.
Please do not cross post to multiple newsgroups at the same time. This
could cause redundant effort.
Cheers
/Eike
Martynas schrieb:
> idea was to override eGet, sSet methods to synchronize the values.
> cdo object.
> officially specified and they could change without notice."
> value is set/get.
> Thanks
Re: [CDO] feature value synchronization [message #620943 is a reply to message #136320] Wed, 13 May 2009 08:04 Go to previous message
Martynas,
Cheers
/Eike
Martynas schrieb:
> cdo object.
> value is set/get.
> Thanks
Previous Topic:[CDO] feature value synchronization
Next Topic:[EMF Compare] Pb comparing a SysML model using SVN
Current Time: Sun Jul 27 12:46:56 EDT 2025
Powered by FUDForum. Page generated in 0.04752 seconds
