Home » Archived » IAM (Eclipse Integration for Apache Maven) » Error installing q4e plugin on Eclipse 3.4
Error installing q4e plugin on Eclipse 3.4 [message #12503] Thu, 24 July 2008 14:13 Go to next message
Originally posted by: joe.chambers.cox.com
I get the following error when I try to install q4e on the Eclipse 3.4
application:
Cannot complete the request. See the details.
Eclipse Modeling Framework (EMF) - org.eclipse.emf.common will be ignored
because a newer version is already installed.
Eclipse Modeling Framework (EMF) - org.eclipse.emf.common.ui will be ignored
Eclipse Modeling Framework (EMF) - org.eclipse.emf.ecore will be ignored
Eclipse Modeling Framework (EMF) - org.eclipse.emf.ecore.edit will be
ignored because a newer version is already installed.
Eclipse Modeling Framework (EMF) - org.eclipse.emf.edit will be ignored
Eclipse Modeling Framework (EMF) - org.eclipse.emf.edit.ui will be ignored
Eclipse XML Editors and Tools will be ignored because a newer version is
already installed.
Graphical Editing Framework will be ignored because a newer version is
already installed.
WST Common Core will be ignored because a newer version is already
installed.
WST Common UI will be ignored because a newer version is already installed.
WST XML Core will be ignored because a newer version is already installed.
WST XML User Documentation will be ignored because a newer version is
already installed.
XML Schema Infoset Model (XSD) - org.eclipse.xsd will be ignored because a
XML Schema Infoset Model (XSD) - org.eclipse.xsd.edit will be ignored
Cannot find a solution where both Match[requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.zest.layouts/[1.0.0.v2 0080226,1.0.0.v20080226]]
and Match[requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.zest.layouts/[1.0.0.v2 0080115,1.0.0.v20080115]]
can be satisfied.
can be satisfied.
can be satisfied.
can be satisfied.
can be satisfied.
Any help would be appreciated.
Joe
Re: Error installing q4e plugin on Eclipse 3.4 [message #12526 is a reply to message #12503] Mon, 28 July 2008 14:26 Go to previous messageGo to next message
Have you selected the Dependency Viewer feature?
In 3.3 at least it complains if you don't have all requirements selected
> application:
> already installed.
> already installed.
> installed.
> already installed.
> can be satisfied.
> can be satisfied.
> can be satisfied.
> can be satisfied.
> can be satisfied.
> Joe
Re: Error installing q4e plugin on Eclipse 3.4 [message #12547 is a reply to message #12503] Mon, 28 July 2008 14:27 Go to previous messageGo to next message
> application:
> already installed.
> already installed.
> installed.
> already installed.
> can be satisfied.
> can be satisfied.
> can be satisfied.
> can be satisfied.
> can be satisfied.
> Joe
Re: Error installing q4e plugin on Eclipse 3.4 [message #12652 is a reply to message #12503] Wed, 13 August 2008 10:31 Go to previous messageGo to next message
Hi Joe, I'm experiencing the same problem. I looked at q4e.googlecode.com
and didn't see anything about Ganymede support. Is there any news about
this?
Brian
Re: Error installing q4e plugin on Eclipse 3.4 [message #12673 is a reply to message #12652] Fri, 15 August 2008 11:38 Go to previous message
Q4E can be installed on Eclipse 3.4, even when the update site does not
contain p2-specific metadata.
For helping you, we'll need to know which version of q4e are you
installing and which update site (releases or dev) are you using.
Thanks!
Abel Muiño
Re: Error installing q4e plugin on Eclipse 3.4 [message #566810 is a reply to message #12503] Mon, 28 July 2008 14:26 Go to previous message
> application:
> already installed.
> already installed.
> installed.
> already installed.
> can be satisfied.
> can be satisfied.
> can be satisfied.
> can be satisfied.
> can be satisfied.
> Joe
Re: Error installing q4e plugin on Eclipse 3.4 [message #566832 is a reply to message #12503] Mon, 28 July 2008 14:27 Go to previous message
> application:
> already installed.
> already installed.
> installed.
> already installed.
> can be satisfied.
> can be satisfied.
> can be satisfied.
> can be satisfied.
> can be satisfied.
> Joe
Re: Error installing q4e plugin on Eclipse 3.4 [message #566950 is a reply to message #12503] Wed, 13 August 2008 10:31 Go to previous message
this?
Brian
Re: Error installing q4e plugin on Eclipse 3.4 [message #566966 is a reply to message #12652] Fri, 15 August 2008 11:38 Go to previous message
Thanks!
Abel Muiño
Previous Topic:Eclipse IAM project plan
Next Topic:Preparing for q4e 0.6.0
Current Time: Mon Jul 21 22:03:20 EDT 2025
Powered by FUDForum. Page generated in 0.09266 seconds
