Re: Perspective of visualized Structural Differences Window [message #136087 is a reply to message #136074] |
Thu, 07 May 2009 09:21 |
--------------080809070209030006090109
Hi Diana,
The inversion problem only existed in earlier 0.8 versions. What is the
version you're currently using? The latest is 0.9M7. If you're using the
latest version and still have a problem with inverted viewers, could you
send us your test files?
Note however that when comparing two files from within the workspace,
there is no "original" or "changed" : Compare takes them in alphabetical
order and displays the first on the left, the second on the right. This
means if you have "testv1" and "testv2" (v2 being obviously the changed
one and v1 the original), eclipse compare will feed EMF Compare "v1" as
the left (semantically, the changed) and "v2" as the right
(semantically, the original). This leads to differences inversions.
That doesn't seem like what you described though as you described a bug
that should have been fixed since a long time.
Laurent Goubet
Obeo
Diana Schultheis a
Re: Perspective of visualized Structural Differences Window [message #620929 is a reply to message #136074] |
Hi Diana,
Laurent Goubet
Obeo
Diana Schultheis a
FUDForum. Page generated in 0.02706 seconds
